Track 1 won't play back on different 38.
Hi guys,
Quick question. I recorded some drums on track 1 and guitar on track two on a Tascam 38. During overdub I could hear the drums to track the guitar. But when I played it back on a different tascam 38, track 1 did'nt play. The vu meter didn't register sound either. I put it back on a the 38 I recorded with and the drums were there. Is this a head alignment issue? |
I should note
that track two came out loud and clear on both decks!
Could be an alignment problem, but you say track two is fine... Perhaps channel one is simply not functioning on the second 38. It happens. You could take it apart and check out the board for channel 1.
Also, avieth is right that the 2nd machine may not have a functioning 1st channel. Don't worry about the 2nd machine for now. --- |
boy I am red. . . .
it turned out to be a jack and patch bay problem. My new question is why doesn't the VU function when the jack isn't working?
The bad jack is probably shorting out the channel. If you run into this again, you could take the tape, FF it onto the take up reel then place the take up reel in the supply position and track 1 would show up on track 8 playing backwards.
| Does Otari BQ play half-track stereo as well as 4-track quad? | L-Dawg | Analog Only | 1 | 12-08-2005 06:42 |
| No play back in Cubase LE | Hiccup Master | Cubase User Forum | 10 | 06-02-2005 07:27 |
| No mono play back? | Pier Calacino | Cakewalk / Sonar Forum | 8 | 05-18-2005 10:17 |
| Play Back Chord. | chrishisey | Newbies | 2 | 10-27-2004 19:24 |
| 1rst track wont play back when rec second | indiefolk | Cakewalk / Sonar Forum | 2 | 01-17-2003 23:17 |
