Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 06-11-2008
jman1986 jman1986 is offline
Senior Member
jman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond reputejman1986 has a reputation beyond repute
Pro tools volume
ok I am having trouble getting a loud enough sound in pro tools m-powered 7.4. I can get a guitar sound but the volume is low and it clips sometimes. The trim is low and stuff. any ideas? how do u get a good volume with like no clipige?
Old 06-11-2008
8bus 8bus is offline
Junior Member
8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute8bus has a reputation beyond repute
Try going to new tracks, option ,select stero> audio> Master Fader>create and shold have a new master Fader.
Old 06-11-2008
Farview's Avatar
Farview Farview is online now
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Recording level and volume are two different things. When you are recording, you need to fill up the input meters about half way. Spikes and transients can be above the half way point, but the bulk of the signal needs to sit there.
If you are having a hard time hearing the guitar over the rest of the music, turn the other stuff down. Unless you recorded it at the level I just described, you recorded it too hot. As you add tracks that are too hot, the mix will get out of contol volume-wise.
Recording level, monitoring level, and mix level are three different things that have nothing to do with each other.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 06-11-2008
Senior Member
hmm ok i will give that a try on my next guitar tracking tommorow. yes i normal get the signal level about half way or even above it, wel at least on the latest song i did. And the overall volume wasn't that low either.
Old 06-11-2008
Farview's Avatar
The point is that the recording level and the listening volume are two different things. Don't turn up the record level so you can hear something over the mix.
Jay Walsh
Practicing volume and performance volume jndietz Recording Techniques 8 03-24-2007 07:41
Pro tools + Reason rewire problem....pro tools dropping notes. quietb03 Recording Techniques 1 02-08-2007 12:48
Mixer volume vs. PC recording volume RecordingMaster Recording Techniques 4 09-14-2005 13:28
I usually play with my guitar volume knob all the way up, and control the volume with monty Guitars and Basses 24 07-13-2004 20:14
Live volume vs. recording input volume A Drummer Digital Recording & Computers 11 02-13-2002 16:11
