Yamaha DTXPLORER and Software, MIDI Help is needed.
Alright, I searched and looked and tried and am getting no were fast with this.
I have a Yamaha DTXplorer electronic drum kit and am using garageband for its synths and such. When I am playing the pads on my kit some are perfectly assigned and work but some pads like my snare don't trigger anything(Yes the pad works with the drum brain). I cant reassign the pads to different notes in the brain(Which sucks). Is there an easy way to do this such as a MIDI utility? I have battery 3 but I need to install it. Just wondering if that would be easier to assign sounds to pads..... Any thoughts? Thanks -Blaze
Analog! Shmanalog! I want my Digimon!....... Oh! thats were my hand was!
any sampler would be the way to go (i.e. battery). Chances are that the drums are laid out by way of a GM map so you may want to check if there is a way to map them on a chromatic scale which would make setting up a sampler patch a little easier
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
I checked that out but no go on the chromatic scale... But after I installed battery(Didn't really have a use for it till now), It was pretty easy to assign a pad to the drum cells in Battery...
Thanks for the help and info. -Blaze
| Ok... DTXplorer | Jayme | Drums and Percussion | 4 | 10-13-2006 13:52 |
| Help With Yamaha Aw4416 Needed | Call-Of-Ktulu | Newbies | 5 | 04-24-2006 10:30 |
| Yamaha Aw16G - help needed with wav please! | trisho41 | Other Equipment and Reviews | 3 | 09-15-2005 07:07 |
| ok, scrap the dtxplorer, what about the Roland td3k? | Jayme | Drums and Percussion | 0 | 04-18-2005 04:53 |
| Only MIDI sequencing needed, not audio recording. Best software? | jeffy_2003 | Digital Recording & Computers | 0 | 01-26-2001 22:29 |
