Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 06-09-2008
ninecomponents ninecomponents is offline
Registered User
ninecomponents is on a distinguished road
Angry tascam portastudio 424 help!
i'm kind of new to four-tracking, so please bear with me.
i just bought a used tascam portastudio 424 and have been having some trouble. i've been plugging my guitar into an amp and plugging the line out into one of the four track inputs. i find that i get some scratchy popping sounds with this at higher volumes and when i record vocals (also through an amp and into the 4-track) it's even worse. the sound will crackle when it peaks and sometimes the audio pick-up will drop off completely (so that even though i may be singing, i hear nothing and the monitors show nothing being picked up).
am i pushing my machine to hard? do i have to just play everything through the amp and mic it separately through a direct mic that goes only into the 4-track?
thanks for your help.
Old 06-10-2008
Whale Bone Whale Bone is offline
Senior Member
Whale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond repute
Those inputs are fairly high gain. Perhaps the line-level output of your amp is too hot. Try plugging your guitar directly into the Tascam, and also the mic, and see if you can get a good sound. I used to play bass and guitar directly into my 424. I also used a 57 mic with just a hi-Z/low-Z adapter and got a decent signal.
If you are scratching out a demo, then maybe it doesn't matter if you eliminate the amp, but if you want the amp's sound, I'd mic it instead.
Also, the pots might be dirty. I'd turn them through their full range, many times each, especially the gain pots. That may help some of the scratchiness.
Old 06-11-2008
andyhix's Avatar
andyhix andyhix is offline
www.miterecords.com
andyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond repute
That was my guess as well - based on the descriptor "scratchy". Get some TV tuner cleaner (radioshack), and clean all the pots as best you can. Use a rubber band or shoelace or something, to turn them back and forth several times rapidly to work the cleaner in and break up any gunk in them.
Does this happen on all channels? Does it happen at a lower gain? at buss recording mode as well as direct? Try to further isolate the problem, and you can narrow down the potential fixes.
Old 06-11-2008
Senior Member
Good thought.
Made me wonder: is the problem only on playback of recorded material, or is it what you are monitoring through the headphones or the line outs also? That would help distinguish between the tape head and the mixer sections.
Tascam Portastudio 424 fun Jagular MP3 Mixing Clinic 53 03-04-2008 19:48
Tascam Portastudio 788 burn Free Ads for Music / Recording Equipment 0 06-02-2002 15:46
Tascam 564 Portastudio UnkleSlam Free Ads for Music / Recording Equipment 2 08-14-2001 15:31
Tascam 788 Digital Portastudio VS Tascam Porta02 CJ Newbies 2 11-20-2000 03:03
TASCAM 244 Portastudio Sam Jones TASCAM User Forum 0 01-16-2000 09:28
