Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 06-02-2008
TheTomTrendy TheTomTrendy is offline
Newbie
TheTomTrendy is on a distinguished road
Question Keyboard Help
So I have a keyboard that's midi capable by a USB connection. I'd like to record my keyboard's piano sounds and others through that function and I use Audacity, but the software doesn't handle midi.
Does anyone know what I can use to record and edit midi? I don't want to go about the ways of putting a mic next to the keyboard speakers and recording room noise too.
Thanks in advance.
Old 06-02-2008
montage's Avatar
montage montage is offline
Senior Member
montage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond reputemontage has a reputation beyond repute
Perhaps one of the Cakewalk products so you could edit MIDI and audio...probably Sonar Home Studio if budget-minded.
www.cakewalk.com
Old 06-02-2008
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
If the software does not do MIDI - you're probably out of luck, unless you change software.
Assuming you can record audio - you can take the line out from the keyboard and record the sound direct (vs. mic'ing the keyboards speakers)
Old 06-02-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
if you think mid is going to be a long term issue to you then bite the bullet and get a starter version of cubase or sonar... personaly ive had eearlier versions of sonar but prefer cubase (using at present)... though admittedly the learning curve for cubase is a bit steeper...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 06-03-2008
Newbie
So how would I go about doing that? I'm not sure how the connection would work.
And if I do get another software, it should be possible to record the midi through it and then convert to wav files and send to Audacity for mixing, right?
Old 06-03-2008
2.5K Gold Member
I must assume your keyboard has some type of audio output - either 1/4". RCA or mini plug. At very least it must have a headphone out (either 1/4" or mini plug). I must also assume your computer has some kind of sound card.
So you plug a cable with a male jack into the female out of your keyboard with the other male end of the cable into whatever female input of your computer interface (soundcard). You may have to buy some adapters to convert 1/4" to mini plug etc.
You should now be able to send an audio track into your computer - to be converted from analog to digital. I have never used Audicity and I have no idea what your computer setup is.......but since you are planning on recording, I must assume you have some basic analog/digital conversion capabilities and that Audicity can except that type of data.
If you do purchase software that can process MIDI - you would still need to get audio into your computer if you want to create wav files.
MIDI does not create analog sound. MIDI simply tranfers various performance data (note on, note off, etc.). The software records the MIDI data and then sends it back to a MIDI instrument (or to samples). When the MIDI instrument receives the performance data back it then responds by creating the analog sound (no different than if you were pressing the keys on a MIDI keyboard. But - you still need to record that analog sound.
using an MTR with Keyboard? rjmatthews Keyboards and Sound Modules 2 03-28-2006 06:44
New keyboard for studio! First time keyboard buyer endserenading81 Keyboards and Sound Modules 6 05-28-2004 07:31
computer keyboard with midi keyboard attached JR#97 MIDI Mania 3 02-10-2003 17:58
my keyboard ate my cat .. now my keyboard is sick JMarcomb MP3 Mixing Clinic 3 06-23-2002 16:53
