Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 05-31-2008
thajeremy's Avatar
thajeremy thajeremy is offline
registered abuser
thajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond reputethajeremy has a reputation beyond repute
locking effects....
I know in Adobe Audition, you have the capibility of locking effects to help save on system resources....is there a similar function in protools?
Old 05-31-2008
Steenamaroo Steenamaroo is offline
Dedicated Member
Steenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond repute
not that i am aware of,sorry.
whasamatayou?
Old 06-01-2008
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
you can by using Audio Suite or just bouncing to a new track
www.redlabaudio.com
Old 06-04-2008
thajeremy's Avatar
registered abuser
Yea...thats what I started doing....the tracks that I knew I had the way I wanted them...I just used the Audio Suite and made the changes, and processed and went about my buisiness...I was able to clear out about 12 plugs which made a big differance....
Old 06-04-2008
Dax Productions Dax Productions is offline
Senior Member
Dax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond reputeDax Productions has a reputation beyond repute
What I like to do here is buss to a new track and record through to the new track, then hide and make inactive the old track. This way its simple to go back and make a quick change if I'm not happy later.
Old 06-04-2008
thajeremy's Avatar
registered abuser
when you say record to the new track...you mean bounce right?
Old 06-05-2008
it's kind of the same thing. Bouncing usually refers to the Bounce to Disk command. Bouncing to a new track just avoids the whole process of having to import or even convert your tracks back into Pro Tools. You just change the outputs of the tracks to a bus and set the input of a new track to that same bus. Then press record.
www.redlabaudio.com
Old 06-05-2008
Grungeon Grungeon is offline
moo
Grungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond repute
Thanks for that tip. Does that mean you can "bounce" multiple tracks at once, by using several buses? That would have been handy a few weeks ago.
Old 06-05-2008
sure. if you have 12 tracks with a bunch of plugins on them...create 12 new tracks and bus the tracks individually to them. Or maybe mix and match them by bouncing all the guitars together, all the drums together, etc. Then you can just disable the original tracks so you still have them in case you need to go back and change something.
www.redlabaudio.com
Old 06-06-2008
thajeremy's Avatar
registered abuser
this will come in handy for sure....
Old 06-06-2008
Senior Member
Yup! It's a great way to manage voices on an LE or M-Powered system. Or even on an hd system if you're running out of processing power.
locking in vocals? KonradG Newbies 20 08-04-2006 16:59
Locking? myniecechloe Cool Edit Pro / Adobe Audition Forum 1 10-12-2003 00:46
Locking tracks Leroy Pimpdaddy Cubase User Forum 3 10-10-2003 09:07
Now Sonar is locking up. 64Firebird Cakewalk / Sonar Forum 3 09-14-2002 03:11
PA9 locking up. 64Firebird Cakewalk / Sonar Forum 11 09-05-2002 08:12
