Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 05-27-2008
junglefacejake9 junglefacejake9 is offline
Registered User
junglefacejake9 is on a distinguished road
Normally, when I'm doing a multi track song(and I'm probably doing this wrong), I'll lay the first one down, switch it to safe, plug the mic into the 2nd track's slot, set track 1 to tape and track 2 to mic and record. And every single time I have done this, there's a lower quality duplicate of track 1 underneath track 2, even when track 1 is turned off.
I'm guessing it's recording me monitoring it and playing over it. I don't want this to happen; what could I be doing wrong? I usually set it on Direct, though I know this is wrong now, but the manual says that will cause "bleed through" and I know what that is(definitely not this); am I just dumb and not using the tape cue like I should? Or is it a problem with my unit? A friend of mine owns one and doesn't know a thing about tape cue yet doesn't have this problem, so I'm lead to believe it's not that either. Help.
edit: i should note it does this for track 1 and 2 into 3 and tracks 2 and 3 into 4 etc.
Old 05-27-2008
TheOwnageMaster TheOwnageMaster is offline
Registered User
TheOwnageMaster is on a distinguished road
Tie a string around your nuts.
Old 05-28-2008
nopainkiller's Avatar
nopainkiller nopainkiller is offline
Thunderkicks McStrum'em
nopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond reputenopainkiller has a reputation beyond repute
I'm not sure I understand your problem. The way I use it, I keep the mic plugged into the first channel the whole time. Then when I want to record another track I set the track to 2 and turn the panning to the right channel. If I want to record on the third track, I switch it to the third, then turn the 1-2 button off, and press the 3-4 button. If u want to listen to the tape while recording, you have to have the tape cue button pressed in the monitor section. You don't have to switch jacks for different tracks, you just assign that channel to a certain track. You record tracks 1, 2, 5, 6 on the 1-2 buttons, and 3,4,7,8 on the 3-4 buttons.
If that's not yer problem, then you're setting the input on the channel you just recorded to tape, so it's sendning the tape signal to the track you are recording, which is impossible if you were recording track 1 to 2.
Old 05-28-2008
oh heh, I have the 488mkII tho. sorry. dunno if it's much different
Old 05-29-2008
analog aaron analog aaron is offline
Swami King of Poppers
analog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond reputeanalog aaron has a reputation beyond repute
What you need to do is Keep your input plugged into channel 1 and turn the PAN to the R. (or if you really want to you can use any of the inputs, just pan the channel you want to use to the persective track, trk 1 L, trk 2 R, trk 3 L, trk 4 R) Switch the track 1 (that you've already recorded) to the mic input position - not off- not tape -IF you are going to leave your Mic or plug into the channel one input) Press the cue button and turn the cue knob on channel 1 to the right. This will be your volume of track one. Set it loud enough to hear it but not too loud that you can't hear your overdub onto trk 2. Set track 2 to record. and the last step........Become Phil Spector.
Old 05-29-2008
danw's Avatar
danw danw is offline
cheap bastard
danw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond reputedanw has a reputation beyond repute
I also use the direct mode because I never liked that whole panning thing, and I haven't had that kind of a problem.
Here's a silly question: are you sure it's actually recording the duplicate onto the new track, and you're not just hearing the tape cue of the first track? If you have the tape cue on, my understanding is that you will hear the track even if it's turned off.
Old 05-29-2008
andyhix's Avatar
andyhix andyhix is offline
www.miterecords.com
andyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond reputeandyhix has a reputation beyond repute
Make sure your heads are clean and you are using decent quality tapes, and that you are not recording too loud. Not sure that any of that will help, but you should do it anyway.
Next step: try the pan/bus recording method and see if you have the same problem.
Dumb question, but are your headphones just cranked up too loud or not providing good isolation?
Old 05-30-2008
Registered User
"I also use the direct mode because I never liked that whole panning thing, and I haven't had that kind of a problem.
Here's a silly question: are you sure it's actually recording the duplicate onto the new track, and you're not just hearing the tape cue of the first track? If you have the tape cue on, my understanding is that you will hear the track even if it's turned off."
Glad someone else uses Direct so I don't feel so lost about this panning stuff! Yes, I'm sure it's recording the duplicate. When Track 1 is fully off, it lingers in the background of Track 2. When both are on, Track 1 is piled onto itself in this low quality mess of horrible. Track 2 is turned off, and everything sounds fine again. So it's not headphones or tape cue(I have tape cue off because I don't really get that either!)
My tape quality is good and my hands are clean and everything's alright so I'll try analog aaron's thing! That sounds right.
Old 05-30-2008
Panning
Using the panning method is THE ONLY WAY to insure that your input's
strongest signal will go to the ONLY track you choose. This is the only way to minimize track bleedthrough/crosstalk (whatever the hell they call it).....SOOO......use the panning method and I promise, it'll all PAN out in the end...Ahahahahahaa..Ha......Ha.....cough.....sniff...Sorry...It's too early for bad jokes Let-tuce (I can't stop myself) know how it works out!!
Old 05-30-2008
andyhix's Avatar
www.miterecords.com
Yep, for what it's worth, I used the direct method for years. It is clearly the more intuitive way to record. 1 goes to 1, etc. However, I kept hearing over and over about the buss method, and finally tried it. It was somewhat of an epiphany. You no longer have to unplug/replug to record your next track; you don't need to reset the trim and input levels. All you do is spin the pan knob to the other side, put track 1 on safe, and put track 2 on Buss R, and you are ready to record the next track. Once you start doing that, other benefits of the built in mixer (different routing options, etc.) in the 424 will start to become apparent.
I highly encourage all users of such portastudios to start differentiating in their mind between Channels and Tracks. The mixer section of the unti has 8 input CHANNELS. These CHANNELS can be routed any number of ways to the 4 TRACKS that are on the casette tape. There's no reason that TRACK 1 should only be fed by CHANNEL 1.
Old 06-25-2008
busby99 busby99 is offline
Newbie
busby99 is on a distinguished road
I believe your mistake is.....
When you're finished recording on track 1 you said you switch the track #1 input switch to "tape". That's where your problem lies. When you record track #2 it's not only recording through the mic, but it's also recording track #1 as well. Instead, once you've finished recording to track #1, that input switch should be set to "Off". You can hear track 1 playback while you're recording track #2 by using the tape cue control on track 1 and switching the "effect 2/tape cue" switch to the right (tape cue) position. I've forgotten many times to put one of those switches back to the "off" position and have had to re-record more than a few a few tracks because of that.
I'd like to echo some of the other replies here that said it's easier to use the buss and leave the mic plugged into track one. The instructions in the manual for doing that aren't quite clear, but once you fool around with it for a while you should be able to understand the concept.
  #12
Old 06-25-2008
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow
Originally Posted by busby99 View Post
you said you switch the track #1 input switch to "tape". That's where your problem lies. use the tape cue control on track 1
How many posts missed this point completely?
Thanx!
Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!!
637 songs by 191 bands.
  #13
Old 06-27-2008
MCI2424's Avatar
MCI2424 MCI2424 is offline
1K Silver Member
MCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond reputeMCI2424 has a reputation beyond repute
Thanx!
I'm guessing everyone but this one?
"Tascam, Fostex or Studers don't make hit records...........people do"
MCI2424 - 2007
whats the difference between a Tascam 424 MkII and a 414 MkII? dennnis Analog Only 8 05-08-2008 12:18
Tascam 122 MKII Recording Levels?? MiXit-G Analog Only 8 02-21-2005 00:07
TASCAM 414 MKII - How to get good vocal recording without using reverb or compression peacepiper TASCAM User Forum 11 10-23-2004 05:30
Tascam 414 mkii band recording Abbott TASCAM User Forum 3 01-25-2002 16:24
4 Track Blues - Tascam 424 MKII alfugazi Recording Techniques 5 05-24-2000 16:26
