Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 05-26-2008
spkldgecko spkldgecko is offline
Newbie
spkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond reputespkldgecko has a reputation beyond repute
help with latency - Cubase Le
I have a Lexicon Lambda USB interface that was bundled with Cubase Le at the time of purchase. My computer has the following specs - 60 Gig HD - 512 RAM - 2 Gig CPU Celeron. I can record, play, etc. with a midi keyboard with no problem. However, if try to record my Roland V-Drums as either an instrument in or as a Midi device, I get horrible latency and muddy playback, to boot. Anyone out there know a solution. If its a matter of more RAM, I'm maxed out on slots and would have a pretty good expense to double it and I don't want to go that route unless I know for sure that that is the problem. Thanks.
Old 05-27-2008
dementedchord dementedchord is offline
Psychotic State alumni ch
dementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond reputedementedchord has a reputation beyond repute
seems to me there's no reason that it should have a harder time with v-drums than akeyboard... infact should be perhaps a bit easier... and dont understand why it would be muddy... you didnt say but i'll bet this is a laptop right?? though kind of convoluted there may be a work around for the latency issue if it plays back properly when not recording... is this true??? in otherwords when you play back a drum track it's in time none of the latency is present...midi instruments have the ability to turn off local sounds... this keeps it from playing twice while hitting it... it would trigger when you played it and then trigger again when it recieved the returning signal from the puter... make sense so far??? so what you might try is turn local ON and record with the track muted for playback... this way you'll only hear the initial triggering... then unmute the track and see if it plays back normally...
another issue you may be experiencing is the hard drives in alotta laptops are trash... and recording to a second hard drive is a neccessity...
37.8% of all statistics are made up on the spot...
hey give a guy some room... people are trying to evolve here... for crying out loud...
Old 05-27-2008
Newbie
Thanks for the info. It is a tower computer - I kept it when I recently got a new one. The muddiness may be due to other factors in the recording chain that I haven't addressed yet. But there is a definite latency problem with monitoring and recording. A lot of crackles to go along with it. I have tried every combination of buffer size, number of clusters, and CPU usage and can't get it to record properly. The sad thing is that I'm a drummer and have no musical skills in any other instrument. I was thinking that it may be that the computer I'm using can't handle this particular input for some reason. Anyway, if anyone has a solution, I sure would appreciate any input. Thanks again.
Old 05-28-2008
when you said it maxed out the ram at 512 i took it as a clue for the laptop... my bad...
Old 05-28-2008
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
Aside from adding RAM you might want to try another hard drive and dedicate it just to record to. They're pretty cheap these days.
Originally Posted by chessrock
There's this thing on our site ... called "the Newbie section." And it's really cool. And even if your name isn't NYMonrningstar, you can still get a lot out of it. .
Old 05-29-2008
also check your systray... how many other services are running while you are recording??? turn them off if unnecessary to operation...
Old 05-29-2008
Newbie
Thank you NYMorningstar and dementedchord for your suggestions. I will try them and see if any of it makes a difference.
Cubase LE latency? GroovyGroundhog Cubase User Forum 3 07-24-2006 23:18
Cubase SX Latency on XP jakpetrov Cubase User Forum 1 01-05-2004 15:30
latency in cubase newbie00 Cubase User Forum 5 11-03-2002 14:23
Cubase latency again!!!! HELP!!!! c_r_a_z_y Newbies 7 10-22-2002 20:42
Latency in Cubase 5 Slightly_Imp Cubase User Forum 3 03-17-2001 12:12
