Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 05-24-2008
Pleasurehead Pleasurehead is offline
Newbie
Pleasurehead is on a distinguished road
Compression going in.
Hi,
Can anyone tell me if there is a way to compress in cubase SX3 when going in? or is there a plugin that can do this for me?
Thanks
Old 05-24-2008
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
I am not sure if Cubase will let you compress through the software before the signal is actually recorded or not. However, unless you have an outboard compressor I can not see any possible reason why you would wnat to do this. In order for Cubase to compress the signal on the way in it seems that the compression would still have to be done after the A/D conversion. If you are compressing to tame peaks, then you really would not be gaining any benefit because the A/D converter will have already clipped. Basically, I can see several reasons to not do this, but no reasons to actually do it. What was your intent for doing this?
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 05-24-2008
Newbie
Yes of course you are dead right. I hadn't thought it out properly. The only way is .. out board. Thanks
Old 05-25-2008
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
You might as well not compress on the way in anyway. If you do, and you don't like what you've done, you can't undo it. Might aswell compress afterwards. It's not like you don't have a buttload of headroom to play with anyway with digital.
That said, sometimes vocals could be helped with light compression on the way in if you're expecting a reasonable dynamic performance.
My music being somewhat instrumental at this point, I think the only thing I ever compress on the way in is bass guitar, and that's only because my pre has a comp bult in, and even then that bass track is put quite low in the mix next to a track I didn't compress on the way in. And that's if I don't just throw it away, which I often do.
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 05-25-2008
The bottom line as far as I am concerned, is the compression should be used for tone and timbre shaping on the way in and not for dynamics control. If you are using it to guard against a clip then you are only covering up a problem and not addressing the source of the problem. Proper gain staging and technique = never NEEDING to compress on the way in.
Bus compression versus track compression Yareek Mixing / Mastering 6 11-08-2006 17:57
compression. b4 or after? cliff richard Newbies 2 06-04-2004 15:04
outboard compression vs. dsp card compression Jaguar The Rack 3 03-20-2004 11:19
Compression theletterq Drums and Percussion 0 10-03-2002 15:12
I need a little compression... and I am sick of Software Compression faabud The Rack 13 04-02-2001 15:58
