Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 05-19-2008
Jmoog's Avatar
Jmoog Jmoog is offline
Newbie
Jmoog is on a distinguished road
Tascam 38 question
Hello I just recently acquired a Tascam 38 8-Track recorder. I am using it with a Mackie Micro series 1202 12 channel mixer which I am also pretty unfamiliar with.
I've recorded a track on the Tascam and now I am trying to do an overdub onto the Tascam while also monitoring the pre-recorded track through the Mackie mixer. So at this point I am receiving the pre-recorded track through the Mackie and also sending out the new track back to the Tascam through the Mackie. I have tried this using several different routing configurations but I am always getting "bleed" from the track I am monitoring into the track that I am overdubbing.
My question is how would I route my cables in order to overdub onto the Tascam while monitoring tracks already recorded on the Tascam without the pre-recorded tracks "bleeding" into the new track? The mixer has 4 "channel insert" jacks on the back and I have been using them but I am still having a bleed problem. Can anyone help?
I Love Mellotrons
Old 05-31-2008
eddiemunster666 eddiemunster666 is offline
Newbie
eddiemunster666 is on a distinguished road
This might help.....
Go to the mackie site an look at the manuals: http://www.mackie.com/pdf/1202vlzpro_om.pdf
This manual was the closest I could find to your description. It shows how to do a direct out with a mono plug. Go to the "Channel Insert" topic and look at how they connect using the mono plug. I think if you plug the mono plug all the way into the insert and feed this directly to your tascam 38 your problem should be solved.
Tascam 488 question analog aaron TASCAM User Forum 2 04-28-2008 05:11
tascam Question rushfan33 TASCAM User Forum 2 11-11-2003 20:48
an old tascam question nl553 Newbies 6 05-27-2002 15:23
overdubbing question, volume question, 4 track (tascam 424mk3) skweeks Recording Techniques 2 01-10-2000 11:29
Tascam 424, volume question, overdubbing question skweeks TASCAM User Forum 2 01-05-2000 09:48
