Go Back   Home Recording > User Forums by Brand > Pro Tools Forum
Reply    Audiofanzine Digidesign Digidesign News Digidesign Medias Digidesign Tests Digidesign Articles Digidesign User Reviews Digidesign Classifieds Ads
Old 05-13-2008
James O. James O. is offline
Registered User
James O. is on a distinguished road
The dreaded 9093 error, M Box fried somehow???
Hello, this is my first post here, if it's the wrong forum please move and all that.
I'll try to keep this brief, but I'm pretty certain I won't. Apologies in advance.
So I've been running ProTools LE 7 with an M Box 2 on my ThinkPad laptop for a while now without any real problems (despite expecting them). I recently had to trade mine in for a basically identical model (school-issued... if you choose to buy the thing they make you give it back and give you another. Don't ask me why). I get the new one and install ProTools again. I don't record anything new onto it, but I do open a rather elaborate session and manage to remix the song without any trouble at all.
A couple days later I hook up my new electronic drumset to the M Box. The drum module is an Alesis DM5, which I had no problem with while setting up. However, I run one of the stereo outs (only one, as I was just testing at this point to make sure something would come through) into the TRS in the first input of the M Box. I'm able to record for a few seconds before I get the classic 9093 error. I then proceed to try every different method of communicating between the drums and the M Box; running out of the AUX outputs, running into the direct in line, even running it through the headphone jack of the Alesis and into the M Box. Same error.
So I start plugging mics into the M Box and continue getting the same error. It's simply not recording for more than a couple seconds (if that) before giving me the error. I reinstalled ProTools several times with no luck, I even tried installing it on another (practically identical) laptop with the same error message (this time the Alesis never touched the set up at all). I found numerous possible fixes online, but nothing I've tried so far as worked.
So my questions are
1.) Is it possible that the drum module could've damaged the M Box somehow? If so, does Digi (or anyone else) repair them?
2.) Is there something I'm doing wrong when it comes to connecting the devices? If it IS my box, and if I DO get it repaired, am I basically just going to have the same problem all over again?
I've managed to run other devices into the box without trouble, though admittedly nothing as elaborate as a full electronic drumset. I've considered doing a total reformatting of my drive, but since I experienced the same problem on a completely different laptop it leads me to believe it wouldn't make any difference.
If I should give more specs on my laptop and/or what fixes I tried please let me know and I'll do the best I can to explain.
Sorry for the length. Any help is massively appreciated... it's killing me to be sitting on my hands when I could be working on these things.
Thanks,
-James
Old 05-13-2008
wreckd504 wreckd504 is offline
Force of Nature
wreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond reputewreckd504 has a reputation beyond repute
Sorry to state the obvious, but even though it might look the same it may not have the same mainboard, controller chipsets, hard drive speeds, ram speed or is it the same windows service pack, correct pace drivers...the list goes on.
You mentioned you hadn't recorded anything on this new PC but had been able to play a session back? Have you been able to successfully record yet on this PC? Does playing back sessions still work?
[DUC standard response]
To enable other users to help you, please include all of your system details when posting an issue; Pro Tools hardware, Pro Tools software version, CPU, OS version, Motherboard make/model, chipset, amount of RAM, type of hard drives used, etc.
- SiSoftware's Sandra Lite application can be used to post your full system profile.
http://www.sisoftware.net/index.html...64&langx=en&a=
I seriously doubt your mbox is fried. I had a plethora of errors when I upgraded to my new pc, but after googling the exact errors and finding out some weird stuff I got it working after a day or two. I immediately thought I'd bought an incompatible motherboard or something else...start with the basics first.
-post up the sisoftware specs
-post up the exact text of the error
Then I say we go from there.
A good tool once you've ruled out the obvious things
http://www.digidesign.com/index.cfm?...4&itemid=25974
www.myspace.com/heavyrainproductions
Old 05-13-2008
Registered User
Apologies. I'm not sure of everything that needs to be posted here, so please let me know if I've neglected anything that would be needed.
<<< Computer Overview >>>
< Processor >
Model: Genuine Intel(R) CPU T2300 @
1.66GHz
Speed: 1.66GHz
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Mobile, Dual-Core
Internal Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size
L2 On-board Cache: 2MB, ECC, Synchronous, ATC, 8-way, 64 byte
line size, 2 threads sharing
< System >
System: LENOVO 9457A49
Platform Compliance: Intel Centrino Mobile Technology
Mainboard: LENOVO 9457A49
Bus(es): PCI PCIe IMB PCMCIA CardBus USB FireWire/1394
i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
System BIOS: LENOVO 7CET47WW (1.02 )
Total Memory: 1016MB DDR2
< Chipset >
Model: Legend 955XM/945GM/PM/GMS/940GML Express
Processor to DRAM Controller
Front Side Bus Speed: 4x 166MHz (664MHz)
Total Memory: 1GB DDR2
Shared Memory: 8MB
Memory Bus Speed: 4x 166MHz (664MHz)
< Video System >
Adapter: Mobile Intel(R) 945GM Express Chipset Family
(128MB, PCI, PS 2.0)
< Physical Storage Devices >
HTS541060G9SA00 60GB (SATA150,:56GB (C
HL-DT-ST RW/DVD GCC-4244N (ATA:N/A (D
< Logical Storage Devices >
Hard Disk (C: 56GB (NTFS) @ HTS541060G9SA00 60GB (SATA150,
2.5", 5400rpm, 7MB Cache)
CD-ROM/DVD (D: N/A @ HL-DT-ST RW/DVD GCC-4244N (ATAPI33, DVD+
-R, CD-RW, 2MB Cache)
< Peripherals >
LPC Hub Controller 1: Legend 82801GBM (ICH7-M) LPC Interface
Controller
LPC Hub Controller 2: Legend 82801G (ICH7 Family) SMBus Controller
Audio Device: Legend 82801G (ICH7 Family) High Definition
Audio
Audio Codec: Analog Devices ??? (1981)
Audio Codec: Conexant Systems ??? (2BFA)
Serial Port(s): 1
USB Controller 1: Legend 82801G (ICH7 Family) USB Universal
Host Controller
USB Controller 2: Legend 82801G (ICH7 Family) USB Universal
Host Controller
USB Controller 3: Legend 82801G (ICH7 Family) USB Universal
Host Controller
USB Controller 4: Legend 82801G (ICH7 Family) USB Universal
Host Controller
USB Controller 5: Legend 82801G (ICH7 Family) USB 2.0 Enhanced
Host Controller
FireWire/1394 Controller 1: Legend PCIxx12 OHCI IEEE 1394 Host Controller
CardBus/PCMCIA Controller 1: TI PCIxx12 Cardbus Controller
System SMBus Controller 1: Intel 801xx/63xx SMBus
< Operating System(s) >
Windows System: Microsoft Windows XP (2002) Professional
5.01.2600 (Service Pack 2)
Platform Compliance: x86
<<< Mainboard >>>
< System >
Manufacturer: LENOVO
Model: 9457A49
Family: Thinkpad R60
Version: Thinkpad R60
Serial Number: LVAL889
< System Chassis >
Type: Notebook
Can be locked: No
Version: Not Available
Serial Number: Not Available
Asset Tag: No Asset Information
< Mainboard >
MPS Version: 1.40
Model: 9457A49
Serial Number: 1ZBWL67K2KK
< On-board Devices >
IBM Embedded Security hardware:Other (Disabled)
< System Memory Controller >
Error Correction Capability: None
Number of Memory Slots: 2
Maximum Installable Memory: 2GB
Bank 0/1 - DIMM 1: SO-DIMM Synchronous DDR2 512MB/64
Bank 2/3 - DIMM 2: SO-DIMM Synchronous DDR2 512MB/64
< Chipset >
Revision: A4
Bus: Intel AGTL+
Maximum FSB Speed: 4x 200MHz (800MHz)
Width: 64-bit
I/O Queue Depth: 12 request(s)
Maximum Bus Bandwidth: 5.19GB/s
< Chipset 1 Hub Interface >
Type: DMI (Direct Media Interface)
Version: 1.00
Number of Ports: 4
In/Out Width: 4-bit / 4-bit
Multiplier: 3/1x
Speed: 1x 100MHz (100MHz)
< Logical/Chipset Memory Banks >
Bank 0: 256MB DDR2 5-5-5-15 8-20-5-3 1T
Bank 1: 256MB DDR2 5-5-5-15 8-20-5-3 1T
Bank 4: 256MB DDR2 5-5-5-15 8-20-5-3 1T
Bank 5: 256MB DDR2 5-5-5-15 8-20-5-3 1T
Shared Memory: 8MB
Supported Memory Types: DDR2
Channels: 2
Maximum Memory Speed: 4x 167MHz (668MHz)
Multiplier: 1/1x
Width: 64-bit
Memory Controller in Processor:No
Refresh Rate: 7.80µs
Power Save Mode: No
Fixed Hole Present: No
Maximum Memory Bus Bandwidth: 10.38GB/s
< APIC 1 >
Version: 2.00
Multiplier: 1/2x
Maximum Interrupts: 24
IRQ Handler Engaged: Yes
Enhanced Support: Yes
< Memory Module 1 >
< Memory Module 2 >
< Environment Monitor 1 >
Model: Intel Core CPU [P1, C2, M1]
Version: 14.08
Mainboard Specific Support: No
< Temperature Sensor(s) >
CPU Temperature: 67.00°C td
< System Bus(es) on Hub 1 >
Version: 2.30
System Bus 0: PCI
System Bus 2: PCIe 1.00 x1 2.5Gbps
System Bus 3: PCIe 1.00 x1 2.5Gbps
System Bus 4: PCIe 1.00 x1 2.5Gbps
System Bus 12: PCIe 1.00 x1 2.5Gbps
System Bus 21: PCI66
System Bus 22: PCMCIA/CardBus
< LPC Hub Controller 1 >
Model: Legend 82801GBM (ICH7-M) LPC Interface
Controller
Revision: A3
ACPI Power Management Enabled: Yes
Advanced TCO Mode Support: Yes
Advanced TCO Mode Enabled: No
High Precision Timer Enabled: Yes
Number of Precision Timers: 3
System Timer: 14.32MHz
Delayed Transaction Enabled: Yes
< LPC Hub Controller 2 >
Model: Legend 82801G (ICH7 Family) SMBus Controller
Revision: A3
< Audio Device >
Model: Legend 82801G (ICH7 Family) High Definition
Audio
Revision: A3
Type: HD (High-Definition) Audio
Version: 1.00
Number of In / Out / Bi-Direct:4 / 4 / 0
Number of Serial Data Streams: 1
< Audio Codec >
Model: Analog Devices ??? (1981)
Revision: A1
Version: 1.00
Audio Channels: 4
< Audio Codec >
Model: Conexant Systems ??? (2BFA)
Revision: A1
Version: 0.09
< USB Controller 1 >
Model: Legend 82801G (ICH7 Family) USB Universal
Host Controller
Revision: A3
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
Supported Speed(s): Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled: No
< USB Controller 2 >
Host Controller
Revision: A3
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 3 >
Host Controller
Revision: A3
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 4 >
Host Controller
Revision: A3
Version: 1.10
Interface: UHCI
Channels: 2
Speed: 48MHz
< USB Controller 5 >
Model: Legend 82801G (ICH7 Family) USB 2.0 Enhanced
Host Controller
Revision: A3
Version: 2.00
Specification: 1.00
Interface: EHCI
Channels: 8
Companion Controllers: 4
Supported Speed(s): Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support: 64-bit
< FireWire/1394 Controller 1 >
Model: Legend PCIxx12 OHCI IEEE 1394 Host Controller
Revision: A1
Version: 1.10
Interface: OHCI
Channels: 64
Speed: 400MHz
< CardBus/PCMCIA Controller 1 >
Model: TI PCIxx12 Cardbus Controller
Revision: A1
< System SMBus Controller 1 >
Model: Intel 801xx/63xx SMBus
Version: 0.02
Specification: 2.00
Advanced TCO Mode Enabled: Yes
Slave Device Enabled: Yes
PEC Support: Yes
Speed: 100kHz
< Expansion Slot(s) >
ExpressCard Slot 1: PCIe x1 Hot-Plug Available
CardBus Slot 1 (1h): PCMCIA/CardBus 32-bit +5V +3.3V PCMCIA
CardBus ZoomVideo ModemRing PME Hot-Plug
Available
< Port Connector(s) >
Not Available - Infrared: Infrared
Not Available - External Monit:Video / DB-15 pin female
Not Available - Microphone Jac:Audio / Mini-jack
Not Available - Headphone Jack:Audio / Mini-jack
Not Available - Ethernet: Network / RJ-45
Not Available - USB 1: USB / USB
Not Available - USB 2: USB / USB
Not Available - USB 3: USB / USB
<<< Mainboard Configuration >>>
<< System BIOS >>
< General Information >
Version: 7CET47WW (1.02 )
Date of Manufacture: Tuesday, April 11, 2006
Plug & Play Version: 1.00
SMBIOS/DMI Version: 2.40
(EE)PROM Size: 2MB
< General Capabilities >
Can be Updated/Flashed: Yes
Can be Shadowed: Yes
Is Socketed: Yes
Supports Plug & Play: Yes
Supports ESCD: Yes
Supports Enhanced Disk Drive: Yes
NEC PC-98 Spec Compatible: No
< Power Management Features >
Supports APM: No
Supports ACPI: Yes
Supports Smart Battery: No
< Boot Features >
Supports Selective Booting: Yes
Supports CD/DVD Boot: Yes
Supports PCMCIA/CardBus Boot: No
Supports LS-120 Boot: No
Supports ZIP Boot: No
Supports i2o Boot: No
Supports FireWire/1394 Boot: No
Supports BIOS Boot Block: Yes
Supports Interactive Network B:No
<<< Processors >>>
<< CPU 1 [Processor 0, Core 0, Thread 0] >>
< Processor >
1.66GHz
Speed: 1.66GHz
Bus: Intel AGTL+
Package: FC µPGA479M (Socket M)
Rated Speed/FSB: 1.66GHz / 4x 166MHz
Multiplier: 10/1x
Minimum/Maximum Multiplier: 6/1x - 10/1x
Generation: G8
Name: CD1Y (Yonah) Mobile Core Duo 65nm 1.5-2.6GHz
0.85-1.3V
Revision/Stepping: E / 8 (0)
Stepping Mask: C0
Microcode: MU060E0839
Core Voltage Rating: 1.263V
Min/Max Core Voltage: 0.713V - 1.263V
Maximum Physical / Virtual Add:32-bit / 32-bit
Native Page Size: 4kB
< Co-Processor (FPU) >
Speed: 1.66GHz
Type: Built-in
< Cache Information >
Internal Data Cache: 32kB, Synchronous, Write-Thru, 8-way, 64 byte
line size
Internal Instruction Cache: 32kB, Synchronous, Write-Back, 8-way, 64 byte
line size
L2 Cache Multiplier: 1/1x
< Upgradeability >
Socket/Slot: None
Upgrade Interface: None
Supported Speed(s): 1.67GHz
< Processor Power Management >
Processor Throttling Support: Yes
Throttle Range: 14% - 100%
Version: 14.08
< Power Rating(s) >
CPU Core Power: 22.43W
<< CPU 2 [Processor 0, Core 1, Thread 0] >>
< Processor >
1.66GHz
Speed: 1.66GHz
Bus: Intel AGTL+
Multiplier: 10/1x
Generation: G8
0.85-1.3V
Stepping Mask: C0
Speed: 1.66GHz
Type: Built-in
line size
line size
< Upgradeability >
Socket/Slot: None
Version: 14.08
< Power Rating(s) >
CPU Core Power: 22.45W
I'm running ProTools LE7 with an MBox 2.
In response to your questions, yes, at first I had no trouble at all playing back and bouncing out tracks in ProTools. However, I had not tried recording at this point, so I'm not sure what would've happened had I done so. It wasn't until I attempted to record the electronic drums that I encountered this error after just a couple seconds of successful recording:
"The operating system held off interrupts for too long. If this occurs often, try increasing the 'H/W Buffer Size' in the Playback Engine Dialog. (-9093)"
Afterwards this is the only response I receive when trying to play back OR record (at most ProTools will play back for a few seconds before erroring out again). As you might expect, raising the buffer size simply gives me this error:
"Audio processing is conflicting with other CPU tasks. If this occurs often, reducing the 'H/W Buffer Size' in the Playback Engine Dialog may help prevent the problem. (-9129)."
I have visited the Digidesign help site as well as some other forums and tried the following potential fixes:
- Disabling ClearType Font Smoothing
- Updating the Intel Ultra ATA storage controller to the Standard Dual PCI IDE controller.
- Setting the drive to operate in DMA mode when available.
- Creating a new hardware profile.
- Disabling device drivers.
None of these seemed to help at all.
Thanks,
-James
Old 05-14-2008
Force of Nature
I'll have a more detailed look tomorrow, but in the meantime - how do you have your mbox connected? Ie onboard usb? add on pcmcia usb port card?
Either way, could you try using a different port just to humor me? I have this thing on my firewire card where 3 of the four ports will give me that 9093 error, but one doesn't. I won't even tell you how long that took me to work out. I'll check out some of the other specs you posted up when I get a sec tomorrow
Old 05-14-2008
Registered User
Connected via onboard usb, yes.
I saw this mentioned somewhere else and gave it a try with no luck. I just tried each port again just to be sure, same error.
Old 05-17-2008
Force of Nature
A few things
Do you have another computer (friends or otherwise) to test the mbox still works? I mean, it is not likely it got damaged, but just to be thorough and rule that out.
I can't find anywhere on the digidesign website where the Thinkpad R60 is supported. This doesn't mean it won't work, it isn't however a good start. They support the r40 and r50, so maybe they just haven't caught up yet. Never the less I noticed your laptop uses a legend usb chipset. I've never heard of that, the chipset's generally recommended are NEC or Texas Instruments. In saying that, I've got a really cheap dodgy firewire card running my 002 at the moment that doesn't have those chipsets, however I did have to go through about 5 or 6 pci firewire cards I had squirreled away before I got one that worked.
Also have you downloaded the latest pace drivers?
From the DUC troubleshooting
Pace Drivers
You want to make sure you have the most current version of these drivers.
-Visit the PACE website at:
http://www.paceap.com
-Below where it says "END USERS" on the right side of the page, there is a 'Download Drivers' drop down menu
-Click on the menu and select 'Mac OS X Extensions'
-This should start downloading 'macextsx.dmg'
-Once this file is downloaded, double click on 'macextsx.dmg'
-This should bring up a temporary disk called 'InterLok Extensions Installer'
-Open the 'InterLok Extensions Installer' disk, and double-click 'InterLok Extensions Install'
-Proceed through the installation
-Restart your computer when installation has finished
Curious to see what the issue is.
Also found this on the digidesign website
http://www.digidesign.com/index.cfm?...1&itemid=21610
http://www.digidesign.com/index.cfm?...1&itemid=18921
worth a try
Old 05-17-2008
Registered User
I actually just got it working today. I installed another version of ProTools (7.3) and it worked flawlessly. This could very well have the result of having outdated drivers.
By the way, if you're still curious, I did actually try it on another computer and received the same error with the same box.
Odd that the R60 isn't supported. I ran PT fine on an R60 since last fall. In truth, I was surprised from the start that my laptop supported PT so well, I was expecting massive trouble and, other than this, it's been fine despite some fairly elaborate projects.
I'll keep an eye on those pace drivers as well. Knowing about that could save me a lot of trouble down the road.
Thanks for the help and for the suggestions,
-James
Old 05-18-2008
Force of Nature
glad to hear you got it sorted, I know first hand how frustrating it can be!
the dreaded usb route notbradsohner Digital Recording & Computers 10 05-19-2004 18:27
the dreaded pro tools skipos Newbies 13 07-17-2002 07:03
the dreaded delta 66 dobro Digital Recording & Computers 17 08-23-2001 20:39
Dreaded Garage! moelar2 Studio Building & Display 24 07-16-2001 15:56
The dreaded hiss!!! Baad_gurl Newbies 5 04-07-2000 09:11
