Go Back   Home Recording > Special Forums > DIY, Mods, and Homebrew
Old 05-08-2008
antichef's Avatar
antichef antichef is offline
unfocuser
antichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond reputeantichef has a reputation beyond repute
4136 opamp replacement
OK - I started a thread in "the rack" about an old EQ unit I'm working on. It uses 4136CP opamps, and they kind of suck. Since we now have this forum, I'll post my now-more-specific question here.
I found this:
http://www.cimarrontechnology.com/in...PROD&ProdID=35
this is an adapter which "Adapts two SO8 dual op-amps to RC4136 quad op-amp footprint (14-pin DIP)."
What's confusing me is that I still see 14 holes on the top of the adapter, so I'm having a hard time picturing two identical ICs plugged into it (unless each has a single line of 7 pins).
the question -- um, what's a SO8 dual opamp? Any recommendations as to which one(s) would be a good replacement?
Old 05-08-2008
Somnium7's Avatar
Somnium7 Somnium7 is offline
Noise Criminal
Somnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond repute
SO8 is a surface mount technology package type. I would avoid it unless you have very steady hands and good eyes.
That adapter is meant to replace a DIP package - not what you need.
If you could see crime in a mans face we wouldn't have any mirrors - H. Bogart
Somnium7
Somnium7 on MySpace
Old 05-08-2008
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
I found this:
SO8 is surface mount. You probably don't want to mess with that. I assume your 4136 is DIP-14? You don't need an adaptor. How about 5534 as a replacement?
Old 05-08-2008
Somnium7's Avatar
Noise Criminal
I believe he is dealing with the SIP version. This would be more useful...
http://www.capitaladvanced.com/9000ser.htm
But again SMT...
Between a rock and hard place i think.
Somnium7
Somnium7 on MySpace
Old 05-08-2008
antichef's Avatar
unfocuser
oh jeez thanks - I guess that's what those 8 little pads are for
The reason I think I need an adapter is this quote:
"The supply pins are different to most common quad opamps you will come across so you can't just swap directly. On the 4136 pin 11 was positive and pin 7 negative."
from this thread: http://www.diyaudio.com/forums/showt...hreadid=120496 (I'm not a member over there )
could this mean I'm doomed? I should have said that the 4136CPs are nicely socketed in 14pin sockets now.
Old 05-08-2008
Faithful Departed
But again SMT...
Ooooh, SIPs, eh? Is that right, anti? I have some SIP 5532s laying around, but not 5534s, there are hardly any SIPs left these days. Hard to find, anyway. And if this opamp does have a strange pinout, the adaptor boards will have to have traces cut and jumped . . . this is gonna be quite a project!
Edit: for some strange reason I thought 5534 was quad not single . . . yeah, probably go with one of those adaptor board and reroute the traces, I had a look at the 4136 pinout and it is waaay different. . . SMT work isn't that hard, it's rework that's a bitch. You'll need a good iron and a flux pen though.
Old 05-08-2008
antichef's Avatar
unfocuser
dang it, my ignorance condition is acting up again -- the existing opamps are not surface mount - they have 14 pins in two rows and are sitting prettily in 14 pin sockets, begging to be plucked out by my chip puller.
(hopefully that's clear -- I'll post an out-of-focus picture as soon as it gets from my phone to my blog)
edit: here's the pic:
Old 05-09-2008
Faithful Departed
Those are DIPs. You still have the pinout problem.
Old 05-09-2008
antichef's Avatar
unfocuser
thanks! -- so I either need to find an adapter like the one I linked to, but that supports a DIP, or make one or something like that.
Old 05-09-2008
Faithful Departed
And cut and jump most all of the traces . . . how much do you love this box, anyway?
Old 05-09-2008
antichef's Avatar
unfocuser
good point -- but it's the journey, not the destination that I have in mind. Anyway, thanks! I'll update this thread at some point if/when I make some progress.
  #12
Old 05-09-2008
Somnium7's Avatar
Noise Criminal
Before you start cutting traces check this out.
http://www.larsenassociates.com/ariesadapterlist.html
Part # 18046
I used to work for that company back in the way back days and don't care to recommend them to anybody for personal reasons but that particular adapter is exactly what you need.
I'm sure they can point you to a distributer for purchasing or you can ask them for some free samples
Somnium7
Somnium7 on MySpace
  #13
Old 05-09-2008
antichef's Avatar
unfocuser
wow -thanks! I'll get in touch with them.
Assuming I get some of those, any recommendation for a 14 pin DIP quad op-amp to replace those old clunkers? The 5534 is single?
  #14
Old 05-09-2008
Faithful Departed
Yeah, sorry. Well, there's my old standby OPAx134, 4134 in this case. But I don't really know exactly what is called for here. I'm guessing speed and distortion are more important than noise, since this is a line-level circuit, but I dunno . . . maybe something quieter? Just be sure you get something unity-gain stable.
  #15
Old 05-09-2008
Somnium7's Avatar
Noise Criminal
+1 on his suggestion 0.00008% distortion/noise is quite admirable. Even the lowly TL074 would be a significant improvement to the original part though.
Somnium7
Somnium7 on MySpace
  #16
Old 05-09-2008
Faithful Departed
I figured he might as well be spendy on the Burr Brown chip since the adaptor will probably cost more
  #17
Old 05-09-2008
antichef's Avatar
unfocuser
I filled out the contact form at the adapter place - we'll see what they say. I put some 4134s and also some new 4136s (supposed to be a little better than the old ones - my fall back plan ) in my cart at mouser. Whenever stuff comes in, maybe I can do a before/after clip.
  #18
Old 05-25-2008
Somnium7's Avatar
Noise Criminal
Yeah Aries always had that off-the-hook premium pricing despite the fact they pay such grossly substandard wages to their workers and use automated assembling.
I thought the idea there was to offer more competitive pricing
Somnium7
Somnium7 on MySpace
  #19
Old 05-25-2008
antichef's Avatar
unfocuser
Aries never did write me back Maybe I need to pretend to be a big shot who might buy a bunch of stuff.
Replacing VTB1 Opamp? dickiefunk The Rack 75 09-27-2009 18:24
ATTN: Chessrock - Aphex 107 opamp replacement sleep over jack The Rack 11 09-15-2005 22:40
What is an "Opamp" Jerry W The Rack 10 11-13-2003 12:59
dmp3 opamp, what is it? eeldip The Rack 7 02-15-2003 17:53
Where to buy OPA2132 opamp? Slackmaster2K Microphones 5 12-14-2001 15:50
