Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 04-27-2008
Seafroggys Seafroggys is offline
Force of Nature
Seafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond reputeSeafroggys has a reputation beyond repute
Bouncing Tracks in Cubase LE
I am making a "synth-only" track for an album I'm working on, and am using VST synths. LE is limited to only two VST instruments per session, so I figured I would record two Midi tracks and bounce them into two audio tracks, delete the midi tracks and re-record more stuff.
I looked in the help file but can't figure this out. My only option is to export it and import it back in, but that seems to be rather silly. Isn't there a way to real time record or something what is being played?
I have a Presonus Firestudio btw.
Old 04-30-2008
apush apush is offline
Senior Member
apush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond reputeapush has a reputation beyond repute
I think you route the sound thru a bus and then route the bus as an in? no? never tried anything like this. seems doable.
Old 04-30-2008
Force of Nature
I tried doing the bus method, couldn't get it to work.
Doesn't matter though, this is already old news. I figured after no one responded after 12 hours, it would be quicker if I just exported each track and put them back in
Old 05-01-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
For the 2 track limitation that is it. There is no need to bounce audio tracks in Cubase since there already is an audio track of the vst created as soon as you add the track, it just does not draw a waveform since it is a realtime track being fed from the VSTs output. In your case however, being limited to two tracks is the problem so exporting is the way to go.
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 05-01-2008
Force of Nature
^^^Isn't that exactly what I had said?
copying anologue tracks to cubase thru ALESIS 16 usb,.. dobrocop Alesis Forum 2 02-08-2008 04:39
Just another thread! Gorty Roland, Boss, VS Series Forum 314 08-27-2007 04:39
Ok So Lets Review This Bouncing Of Tracks? MikeDMusic Recording Techniques 9 08-28-2005 17:35
How do I use my 01v reverb on dry tracks in cubase? boze MP3 Mixing Clinic 4 03-29-2003 19:01
bouncing tracks metaldroid Recording Techniques 10 12-16-1999 22:53
