Old 04-18-2008
Soundmind??'s Avatar
Soundmind?? Soundmind?? is offline
Dedicated Member
Soundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond reputeSoundmind?? has a reputation beyond repute
Inverters/ups sytems.
Inspired by a recent thread, thought I'd get some help here. I've been planning to install an inverter to get the studio off the grid, especially during storm season. I have a 1500 Watt modified sine inverter, will this be sufficient, or do I need to go with a pure sine inverter.
Old 04-19-2008
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Should be fine, I'd expect, assuming that's enough wattage for all your gear. If you try it and you hear 60 Hz buzzing, you'll know that it isn't sufficient (and/or that you should get gear with better filter caps in the power supply.... )
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
