Old 04-08-2008
fattmudge fattmudge is offline
Newbie
fattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond reputefattmudge has a reputation beyond repute
changing bit rate after tracking
I accidentally recorded my tracks in 16 bit instead of 24. I have the option to change the bit rate to 24, but is that the same as recording in 24 bit?
Thanks
Old 04-08-2008
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
first, it's bit depth. bit rate is something different.
and no. You can't gain bit resolution that's not there. Converting it to 24 will give you a 24 bit file, but with a lot of useless, blank information to give you those extra 8 bits. Those extra bits won't do anything but give you a bigger file size though.
There's nothing wrong with your 16 bit file though. Don't worry too much about it as long as it sounds good to your ears.
www.redlabaudio.com
Old 04-08-2008
Newbie
cool... thanks
Old 04-08-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
If nothing else, (A) you can record any additional tracks in 24-bit. 16 & 24's can live together just fine as long as they're all the same sample rate and (B) your software is very likely throwing calculations in 32 bit float. Still, 24 bit for next time. But not the end of the world.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 04-10-2008
suprstar's Avatar
suprstar suprstar is offline
it aint ez bein' green...
suprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond reputesuprstar has a reputation beyond repute
What they said ^^^^^. It's like taking a thumbnail of an image, and blowing it up. It gets pixelly and blocky and blurry. You'll be getting the audio equivalent of that.
Old 04-10-2008
not quite to that extreme. It's not ruining the quality of his recording...it's just not helping anything. To keep your image analogy, it'd be like taking a picture that was taken on a camera phone...opening it in photoshop and saving it as a TIFF file in hopes of increasing the image quality. The only thing it will do is make the file size bigger...you'll still have the original quality you started with.
www.redlabaudio.com
Changing sampling rate in pro tools? Necromaniac Mixing / Mastering 2 04-14-2007 12:25
Constant bit rate or Variable bit rate mp3 encoding? mbouteneff Cakewalk / Sonar Forum 4 09-16-2006 20:42
Recording at 24/96K vs. 16/44.1?? WERNER 1 Recording Techniques 88 06-02-2006 20:24
When to Dither?.. please help Enzo66 Recording Techniques 10 02-28-2006 12:03
bit vs sample rate ohthatguy Other Equipment and Reviews 1 08-09-2004 23:40
