Just wondering if theres a way i can pan audio across the whole stereo field, for example the start of a drum beat be in the left speaker, then pan across to the right???? I cant seem to find a way of doing this,
Help much appreciated Thanks |
Automation.
Basically, you'll see a couple of buttons on each track. "R"(read automation) and "W"(write automation). Hit the "W" so it is lit up. Press play, and do your pan manually. Then stop. Go back to the start. Hit "W" so it's not lit up anymore, then hit "R" to light it up. When you play the tune it will play back with the automation you just did. The help file should have more detail.
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos. Oh, and you know the thing about chaos? It's fair..." |
You should also be able to draw your pan automation (although not a thing I've needed to do, so not 100% sure). That way you can get a smooth, even pan movement.
Right-click on the track-name area and select 'show automation', and that should open up a pan automation track. (although not in front of my Cubase right now, so apologies for any slight errors...)
Cubase SX3, Pro Tools M-powered 7, Sound Forge 8, Mackie 1402 + 802 VLZ3, Rode NT1a + NT5 matched pair, ATH-M30 h/phones x 3, Roland XV5050, Yamaha Motif Rack ES, Korg 05R/W, Samson C-control, Event TR8s, lots of VSTis and samples... |
| Stereo Field | Disposable | Mixing / Mastering | 5 | 07-15-2004 06:25 |
| Reversed Stereo Field Using Giga Studio | Phyl | Digital Recording & Computers | 2 | 05-24-2004 06:06 |
| Building a computer specifically for Cubase from scratch | anppilot1 | Cubase User Forum | 2 | 10-02-2003 23:42 |
| Stereo Field... lola vs. powerman | cat-eggs | Mixing / Mastering | 0 | 01-17-2003 18:40 |
| Left Handed Drummer & Stereo Field | CMiller | Drums and Percussion | 7 | 04-04-2002 14:38 |
