Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-06-2008
Epicureous's Avatar
Epicureous Epicureous is offline
Cabron
Epicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond reputeEpicureous has a reputation beyond repute
Vocal mix...
I’m having issues with making my vocal tracks fit well into a mix… I want to be able to, let’s say, whisper and to still have that come through clearly; even if there’s a screaming guitar in the background or (vox) placed off to one side of the mix. The reason for asking is my vox tracks have a lot of dynamics and I want to make sure they/that actually come(s) through the mix, without having to compress the hell out of them (which is what I’m currently doing; sounds bad)… or having to turn the volume up or down in the middle of the note; to me that sounds just as bad as compression. It’s also causing a frequency overload on some notes and when I go to turn that specific frequency down the notes sound muffled… I do move closer on quite notes and further away on loud notes so I don't have to use as much compression but it still doesn't seem to help.
I’m fairly new to this mixing thing…
myspace(.)com /epicureous
Here’s a track I mixed down give me some “mixing” pointers (not musicality pointers I could care-less what you think about my style)… As a side note: I didn’t use any effects (I’m tired of people telling me I did).
Equipment used in the vocal mix:
Blue 8-ball (I know it’s not the right mic for my voice)
Presonus Firepod
Nuendo 3
USR compressor and eq (plug-in)
When I get back to the states I’ll buy better equipment, but you use what you have…
Old 04-06-2008
Talldog's Avatar
Talldog Talldog is offline
Pain in the ass
Talldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond reputeTalldog has a reputation beyond repute
Could you do two vocal tracks? One for the soft and one for the loud.
Old 04-08-2008
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Compresion and volume automation are the tools used to lessen dynamics. You just need to learn how to use them better.
Old 04-09-2008
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
And you have the option to pull down the background tracks in spots to help the vocal poke through.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 04-22-2008
whiskeyfoot whiskeyfoot is offline
Newbie
whiskeyfoot is on a distinguished road
i'm still learning myself, but what i'm kindof finding so far, is that its the other instruments that are standing out too much, and probably not the vocal...i started moving things around a bit (panning), kindof 'widening' the whole scene, and then i found the vocal has its own little spot in the mix instead of just using the volume control alone (whether compression or anything)
i'm totally a newbie...so i'm throwin what i've been learning out there!
-j
Old 04-22-2008
Grungeon Grungeon is offline
moo
Grungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond reputeGrungeon has a reputation beyond repute
Some more ways you can make the vocal stand out are:
*Eqing a hole for the vocals to sit in. That way, soft or loud, the vocals has its own space.
*Pushing the guitar back into the mix with reverb. Or bringing the vocals further forward with a reverb with pre-delay.
For an example of screaming guitars with still room for clear vocals, you can look at Fear Factory's Demanufacture album with a spectrum analyser.
Old 04-22-2008
gdavi1 gdavi1 is offline
Senior Member
gdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond repute
what if you did two tracks like someone suggester or just cut your single take track into two tracks one loud and one soft.
and then using a little ducking to make the vocals sound presentable?
Old 04-23-2008
IronFlippy's Avatar
IronFlippy IronFlippy is offline
Dedicated To My Member
IronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond reputeIronFlippy has a reputation beyond repute
Good mike technique should help you more than anything. Splitting the take is a common method, especially for trying to get a slightly different sound for different parts of a song.
I can't listen to that much Wagner. I start getting the urge to conquer Poland.
Old 04-23-2008
Epicureous's Avatar
Cabron
Yeah I started playing with a spectrum analyzer after I made the post to see where I could make a bit of a hole for the Vox... And after looking around this site (and others), I stopped using a compressor on the vox and just started using subtractive eq'ing... and using the fader to make up for the dynamics... Sounds a lot more real to me (less processed)...
The reason I was hav'n trouble was the tracks I was recording were premixed (sent to me from other bands; they just wanted vox for reference material), so I had no choice on where the guitar were placed in the mix. When I record my own tracks I have no problem with the vox tracks...
Sgt pepper 4-tracks? Got em? I do... poopchute Analog Only 174 09-05-2009 23:51
Automation EQ and Automation manually walters Mixing / Mastering 22 08-18-2006 21:50
NEWBIES - FINAL ARTICLE - VOCAL, ORCHESTRAL AND CHOIR recording tips. manning1 Newbies 0 01-07-2004 13:54
Music - please rip apart Greenshoe MP3 Mixing Clinic 20 07-29-2003 00:49
How to sit a vocal in the mix? FUNKY Mixing / Mastering 15 08-06-2001 02:28
