Old 04-05-2008
colacentral colacentral is offline
Registered User
colacentral is on a distinguished road
Need to know about mixing down to tape decks
Hey; I imagine most people reading this will quickly realise how ignorant of all this malarkey I really am, but you don't learn if you don't ask questions, so, with that said:
I've recently purchased a Tascam cassette four-track, and will be looking to mix down to a tape deck for the purpose of bouncing the tracks. My question is: when searching for tape decks to purchase online, how do I know they'll be compatible and connect to the four-track? Are they any alternatives to tape decks that will accomplish the same goals that I could consider (bearing in mind that I don't have much money to spend)? E.g. are there fairly inexpensive decks that mix down to cd-r and will connect to an old four-track?
I may be completely missing some fundamental point here, so apologies. But I want to make sure I fully understand what I'm buying before I spend anything, without any regrets later.
Thanks to anyone who can help!
Old 04-05-2008
ErichS ErichS is offline
Senior Member
ErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond reputeErichS has a reputation beyond repute
You could do this just as well on your computer (assuming your sound card has a "line in" connection). You could use a free audio editor such as Audacity or almost free Reaper to bounce your sub mix then play it back to a track on the Tascam.
If you are not comfortable with this approach, just about any tape deck should work. It will just need to have line in and line out connections.
Old 04-05-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
"Just as well" is an understatement... I'm an analog nut, but 4-track cassette went the way of the dinosaur for a very, very good reason.
Don't get me wrong - It was a great pre-prod tool - But it sounded like crap.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 04-06-2008
Registered User
Thanks.
I'm really trying to get started using dials and knobs with something more hands-on, and this is what I can afford for the moment. I really dislike sitting behind a computer and using software for everything; I feel a disconnection there and my mind begins to wander.
However, I've taken on board your point. I plan on upgrading when I can afford it but at the moment I find the four-track more simple, engaging and fun than computer software. I suppose that for most people it's the other way around.
Old 04-06-2008
I'd say a lot of people find "hands-on" more satisfying. But a four-track cassette deck will degrade the sound *SOOOOOOOOOOOOO* much that it's normally not a fair trade.
It's not going to be subtle in most cases - It's going to be a very, very obvious step in the wrong (very noisy also) direction.
Old 04-06-2008
TimN's Avatar
TimN TimN is offline
Junior Member
TimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond reputeTimN has a reputation beyond repute
Massive master is right--the sound is bad to begin with, but after bounce down to another machine? Forget it. Buy a cheap mixer, and start using a computer (the mixer so you can twiddle some knobs). You can fiddle with live sound to further satisfy your need to mix in the real world (it works for me!).
Old 04-07-2008
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
I still use a 4 track but in conjunction with Cakewalk pro Audio.
Bouncing down to & back from a stereo cassette recorder isn't a good idea.
I've mixed down to a stereo cassette without probs but bouncing down & back would involve issues with speed, noise reduction systems & quality. You'd have to precisely match your 4 track's high speed recording, match the NR system etc etc before it'd start to be a useful idea.
I download to cake through an 8 IN soundcard. When I was learning I mixed down to stereo inside the PC & a wave recorder prog. Eventually I mixed into cakewalk & finally upload indiv tracks.
What you suggest is achieveable but even in the heyday of analogue they used matched machines.
See if you can buy a duplicate 4 track, have both serviced and timing adjusted etc. & you can do what you want beautifully.
I have a pair of Yamaha MT100s for those times when I come over total analoguish.
Cheers
rayC
soundclick, unearthed, mspace & utub
Old 04-07-2008
Nightfire's Avatar
Nightfire Nightfire is offline
Aspiring Idiot
Nightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond reputeNightfire has a reputation beyond repute
If you want hands on, try a control surface
http://www.musiciansfriend.com/produ...der?sku=701763
http://img.photobucket.com/albums/v3...Rodder/che.jpg
Do you see the flags of freedom, what color are they now? Do you think that you believe in yours more than they do in theirs somehow? - Neil Young
Questions from a complete beginner (who just bought 5 tape decks!) Herr Joachim Analog Only 1 04-27-2006 16:57
calibration/service places in Ohio? puttinitonwax Analog Only 6 03-23-2006 08:14
2" tape decks DaveDrummer Recording Techniques 9 12-08-2003 20:02
Urgent Advice With Analog Tape Copying Needed! janek Analog Only 5 02-26-2002 15:55
tape decks: low end sansui vs. low end teac MrLip Analog Only 5 07-07-2000 04:32
