Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-05-2008
Diddii Diddii is offline
Newbie
Diddii is on a distinguished road
order of things! i need help.
when you have finished recording and start mixing and editing on what tracks do you often begin with?
My band consists of: Vocal, guitar, bass, organ and drums?
On what should i begin?
should i mute every other track when im editing each track?
Give me any tip/advice you got.
thanks.
Old 04-05-2008
tubbabubba22 tubbabubba22 is offline
Newbie
tubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond reputetubbabubba22 has a reputation beyond repute
i usually get the drums and bass level set first. then make sure you can hear the vocals over those two. then slowly bring up everything else until you can hear it, but not so much that it overpowers the vocals.
Old 04-07-2008
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
I like to make sure that the drums can cut through more than anything, especially since they set the rhythm. After that, I bring up the other instruments while using the vocals as a reference point. I want my vocals to be quieter than my drums, but louder than my instruments.
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
Old 04-07-2008
joeym's Avatar
joeym joeym is online now
Mediterranean Maniac
Location: in that beautiful room with the little flashing lights!
joeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond reputejoeym has a reputation beyond repute
I always start mixing as I go along after tracking each instrument. That way, when i get to the actual mixing stage, I have less to do....
In the actual mixing stage I start with the drums and the vocals first, then bring in the guitars and afterwards the bass to fill up the bottom, and then I just go from there...
Old 04-07-2008
joeym's Avatar
oh yeah...the first few takes at very low volume, too.
Old 04-07-2008
ripingitar's Avatar
ripingitar ripingitar is offline
Senior Member
ripingitar is on a distinguished road
I start with drums , first I get the kick sounding right, eq, gate and comp normally . Then the snare.. oh s I normally leave alone just pan wide of course . then I pan and maybe eq toms a bit. Next ill check my bass and drums together make sure theres no conficting frequencys and set the level . then guitars do the same and pan to taste . the lastly I do vocals, prob eq, compress, and delay and or reverb. Then since my monitors suck ill mix a rough mix and listen in my car and a couple other systems . then go back and ajust.
PRO
Plugin Order RD423 Mixing / Mastering 3 03-13-2005 11:17
out of order! zallen25 Other Equipment and Reviews 11 03-06-2003 10:41
The ORDER. Thanks...now how about the order while mixing? DinoD The Rack 1 07-25-2002 17:12
A comprehensive listing of order... Chris Fallen Newbies 2 06-13-2002 12:54
Things I should Know analog4 Songwriting, Singing & Vocals 2 04-15-2002 03:49
