Old 04-02-2008
Mongoo Mongoo is offline
Dedicated Member
Mongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond repute
DIY Bass Traps & other Room Treatment?
I thought I read a while back that you can make some great bass traps from fiberglass boards covered in burlap or something. Anyone know what I'm talking about and know the specifics? What are some other things I should do to my room to enhance the overall treatment? As it is right now I have 4 pieces of wedge foam about 2'x3' probably 3" thick that I've just got tucked into a corner of an open closet attached to the room. Where should I place these to best utilize them? & How many bass traps do you think I'll need, should they be in the top/bottom corners of the room or mid way along the corner edge? Any other thoughts?
Thanks
Old 04-02-2008
aidan_m's Avatar
aidan_m aidan_m is offline
Budding Rock Star!
aidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond repute
Check the studio buiding forum, loadsa useful info there:
http://homerecording.com/bbs/forumdisplay.php?f=20
Old 04-02-2008
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb
Room treatment is a deep subject, and a complete answer requires far more than will fit into a single reply here. So here's the short version. All rooms need:
* Broadband (not tuned) bass traps straddling as many corners as you can manage, including the wall-ceiling corners. More bass traps on the rear wall behind helps even further. You simply cannot have too much bass trapping. Real bass trapping, that is - thin foam and thin fiberglass don't work to a low enough frequency.
* Mid/high frequency absorption at the first reflection points on the side walls and ceiling.
* Some additional amount of mid/high absorption and/or diffusion on any large areas of bare parallel surfaces, such as opposing walls or the ceiling if the floor is reflective. Diffusion on the rear wall behind you is also useful in larger rooms.
For the complete story see my Acoustics FAQ.
There's a lot of additional non-sales technical information on my company's site - articles, videos, test tones and other downloads - here:
www.realtraps.com
--Ethan
The acoustic treatment experts
are these materials decent for DIY bass traps? Hi_Flyer Studio Building & Display 3 09-02-2007 18:41
Bass traps from control room into "live room"??? Nate74 Recording Techniques 2 06-01-2007 12:27
Room treatment advice ! hitmusic Studio Building & Display 3 07-07-2006 09:20
Bass Traps (Room corners) mjbee Studio Building & Display 12 06-21-2006 18:40
A little mix before my DMP3 & Bass traps jeff0633 The Rack 0 04-03-2004 01:45
