Old 04-01-2008
neffi7 neffi7 is offline
Newbie
neffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond reputeneffi7 has a reputation beyond repute
Would you recommend these amps my Monitors??
so i have a Behringer B2030P http://www.behringer.com/B2030P/index.cfm?lang=eng and i am looking to get some amps for it. let me add i am not too sure about how the specs work as i am new to home recording....i have seen these Alpine car amps for a good price http://www.alpine-usa.com/US-en/prod...model=MRP-F250 not sure if i can use car amps for a studio but excuse my lack of knowledge here...pls i need some advice as to whther this is a good combination...pls let me know..if not...i can do with some suggestion for amps.....the specs i can search for and things of that such
thanks a lot
Old 04-02-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
No, you aren't going to want an automotive amplifier running your monitors.
There are tons (literally) of "extremely budget-friendly" amps at the normal outlets -- Behringer, Alesis, Samson, Art... If you want to step up the game considerably, you can look for used amps -- Bryston, Rotel (the high-current lines), Hafler.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 04-02-2008
solo2racr's Avatar
solo2racr solo2racr is offline
SUCK, SQUEEZE, BANG, BLOW
solo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond repute
Lets say that I already have (I do) a nice clean(VERY low ripple) 12V 20A power supply, Two older Phoenix gold amps (M25 & M50 - transparent and sweet sound) and a nice old active xover. What would be the down side from using this as opposed to buying purpose built monitor amps?
Old 04-06-2008
Steenamaroo Steenamaroo is offline
Dedicated Member
Steenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond reputeSteenamaroo has a reputation beyond repute
check the output specifications on your golds, and compare that to the output specs of a samson/alesis/whatever,
i don't know if there's a difference, but if there is, that's the way to find it.
i got an alesis ra100 (they do an ra150) for like,£80.
cheap and cheerful. two ins, two outs two volumes and an on/off,,
but that's what you want isn't it?
whasamatayou?
Low Voltage Blown Monitors? tpresz Other Equipment and Reviews 1 06-04-2006 23:37
First Timer Question: Monitors and Amps davyar Newbies 2 02-19-2006 14:49
are the samson rubicon monitors a bunch of hype? jugalo180 Other Equipment and Reviews 16 10-01-2005 14:50
Please help! Recommend me a pair of powered monitors <$350-$400? policenauts03 Mixing / Mastering 2 05-31-2005 21:57
Question regarding Monitors + Power Amps jpark Newbies 1 06-24-1999 16:28
