Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 04-01-2008
solo2racr's Avatar
solo2racr solo2racr is offline
SUCK, SQUEEZE, BANG, BLOW
solo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond reputesolo2racr has a reputation beyond repute
Guitar Wiring - HBucker/Single coil
I'm getting close to the point to where I am going to have to wire the Lap Steel I'm building. I am using 2 pickups with the bridge being a 14.1 ohm bucker and the neck being a 9.98 ohm single coil (reverse wound & polarity). I have 4 500k pots and a Gibson style 3 way switch . Any suggestions on how to wire this thing up? Diagrams are helpful
Thanks
Old 04-02-2008
solo2racr's Avatar
No takers on this one huh?
Old 04-02-2008
tkingen's Avatar
tkingen tkingen is offline
Banjos Rock
tkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond repute
Go to seymourduncan.com and check out the wiring diagrams.
I like Miles Davis and I like violins, but right now I need a Telecaster with Don Mare DonOcasters through a Deluxe Reverb turned up to 10 - almost a John Hiatt quote
Old 04-02-2008
solo2racr's Avatar
I have checked out the wiring diagrams there and probably 3 or 4 other places as well. NOTHING for one SC & one HB config. The only 2 pickup diagram has been for dual buckers (IE:Gibson wiring). This looks like the route I will end up going. I am thinking tone control for each and a master vol. like this
Old 04-02-2008
tkingen's Avatar
Banjos Rock
There's a sc/humbucking diagram in the the Tele wiring section. It uses a push/pull pot to split the humbucking. That might be a cool option for your lap steel -
http://www.seymourduncan.com/support...1sing_pushpull
Old 04-02-2008
solo2racr's Avatar
I saw that one. If I had a 4 wire HB, that would probably be the way I would go. What I have is a stock Alnico from an LP (2 wire).
Old 04-03-2008
tkingen's Avatar
Banjos Rock
Wouldn't any two pickups/two wire diagram work? You might want a pair of 250k pots for the single coil.
Old 04-03-2008
solo2racr's Avatar
Yea. Any wiring schematic for a 2 pickup setup would work. I was hoping to find someone that has done a setup like this either in a reg. guitar, lap steel, etc. and had some tips for wiring and/or setup. There are alot of different configs for 2 pickup systems so I guess I'll just have to expieriment.
I'm gonna try a 500K pot for the single but I know they DO work better with a 250K pot. We'll see what happens.
Thanks.
Sgt pepper 4-tracks? Got em? I do... poopchute Analog Only 174 09-05-2009 23:51
nylon strings on a steel string guitar andyhix Guitars and Basses 29 12-19-2006 13:30
1938 Lap Steel: Pics, Questions. Interesting Story Easto Guitars and Basses 1 06-11-2005 14:31
Steel Guitar sounds LeeJ Recording Techniques 8 03-24-2005 13:27
Western Steel Guitar without having one? six Guitars and Basses 12 03-24-2005 03:05
