3 prong power cord
Hey y'all,
I've got a '65 Gibson GA-5 Skylark that I love, and I need to replace the two-prong cord with a grounded 3-prong. I know the green wire goes to ground (on the chassis), and I know the black wire is hot and the white wire is neutral, but how do I tell from looking at the schematic which is hot and which is neutral? I've attached a pic of the schematic and then some pictures of the wires. Can you tell me which one goes where, and how this is explained on the schematic? Thanks so much for any help! P.S. I have done some work on amps, and I know how to discharge the electricity from it and all that.
famous beagle Last edited by famous beagle; 10-16-2008 at 08:35.. |
Here are some more pictures.
Is the 2 prong plug polarized? If it is then the wire that has the ribs on it that goes direct to the switch is the neutral (I think it is the neutral anyway, but if the plug is polarized than it is definite).
The hot goes through the fuse, ALWAYS.
And remember to discharge those caps before you go mucking about in there. Light "Cowards can never be moral." M.K. Gandhi
"It's not about who killed my son, it's about what's killing our children." -Aqeela Sherrills http://www.theforgivenessproject.com/ |
Oh, and while you're in there, get rid of the "ground" switch. It's other common name is a Death Switch.
There is no ground switch, and the 2-prong plug is not polarized.
Light: Ok, so you're saying, from looking at my photo (which shows, from left to right, fuse, lamp, power switch), that the hot wire is the one on the left that goes straight to the fuse first? Thanks
famous beagle |
If it were me in there with a soldering iron I'd rewire it so......
Black hot wire goes to fuse to switch to transformer White neutral wire goes to transformer (ignore SW1B in diagram). The cap to ground could stay in this leg or be removed. Green ground wire to chassis |
famous beagle |
The switch should be in the hot leg. If left in the neutral, when the amp is switched off and left plugged in there will still be voltage going to the transformer and possibly to the chassis. The amp won't be powered up like this, but the chassis could be floating at the line voltage. Putting the switch in the hot leg isolates the voltage from getting in that far. The reason the fuse is before the switch is to protect if the switch should ever short to the chassis or elsewhere, which is generally not likely to occur. It will also help if you should miswire something and inadvertantly have a short circuit.
![]() Sorry about missing the lamp, it wasn't in the schematic. It may have been an add-on later. See note below about the lamp. The sketch below may clarify how it's put together better. Edit: Looking closer at the picture of your switch, I don't see the cap that's shown in the schematic, so don't worry about the cap. Also the schematic shows a lamp in the filament suppy voltage. This got rewired to a neon pilot on the 120vac supply side of the circuit. Last edited by arcaxis; 04-01-2008 at 08:56.. Reason: Added info |
So I know I'm reading this right (I'm still learning schematics): (All directions given are in relation to my "AC power cord full" picture) 1 The new black wire will go to the bottom post of the fuse. 2 Then a wire goes from the top post of the fuse to .. the top left post of the switch? Aww crap ... I'm getting confused. I'm still learning how to read schematics, and without a layout, I still have trouble. Would it be an easy matter of telling me which wires need to be rewired to where? If it's too much trouble, don't worry about it. I appreciate the help you've given already. Thanks
famous beagle |
Does this help??
You will need an added point to tie the wires to the neutral. I don't know what you've got to do this. Ideally a terminal strip similiar to what I've got shown would be good and if it had a lug on it for the ground wire all the better. It would be preferable to solder the connection, but you might be able to use a twist on connector like electricians use for house wiring and make sure it's really secure.
#12
famous beagle |
#13
famous beagle |
#14
Radio Shack might have this on the shelf http://www.radioshack.com/product/in...entPage=search |
#15
Thanks
famous beagle |
#16
Oh .. wait ...
How about just using a floating lug and covering it with electrical tape after everything's soldered to it?
famous beagle |
#17
Not pretty looking, but probably would work. A piece of heat shrink tubing over might be better.
#18
I can do that. But that's the right concept, right? The connection will just be floating and not attached to anything?
famous beagle |
#19
Yup.... as long as it's floating and not touching anything else.
Can't talk you into making it look nice? ![]() |
#20
I'll use heat shrink tubing, but actually, I prefer to have it covered with something, just to provide peace of mind so I know it's not going to touch anything. And if it's gonna be covered, I think there's gonna be a bit of ugliness to it anyway.
famous beagle |
#21
hey if you want to go to all this trouble i have no real problem with it.... but actually it doesnt matter which way the voltage goes through the primary of that tranny... sorry... it doesn't... the fuse can be on the "send" or "return" side of the wiring and still do it's job just as well... BTW Never force a primary AC line to ground you're asking for problems... and possibly death... carry on...
37.8% of all statistics are made up on the spot... hey give a guy some room... people are trying to evolve here... for crying out loud... |
#22
#23
famous beagle |
#24
Yeah. Agreed. It should go through the fuse as soon as the hot side goes into the chassis. Then, it should ideally go into the switch followed by the transformer, but realistically, it doesn't make much difference whether it goes into the transformer first or the switch.
#25
is that scenario possible??? on a theoretical level i suppose... as a practicle matter??? i've seen lotsa amps with lotsa problems but i dont think i've ever even heard of a primary shorting like that... if it had there would have been deaths and fires before from 2 prong jobs... again i have no problem if you want to do it this way... just not "that much" of a problem.... ok??
| pedal board power brick for moogerfooger pedals? | blindmelon | Guitars and Basses | 2 | 08-27-2007 18:55 |
| facts about speaker power ratings | gusfinley | Guitars and Basses | 18 | 01-07-2005 15:49 |
| Help!! - Double Phantom Power ?? | Carlos | Microphones | 13 | 05-26-2000 09:42 |
| Computer Problems...Help!!! | LTG | Digital Recording & Computers | 22 | 10-27-1999 19:43 |
