Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 03-31-2008
stupid_brian's Avatar
stupid_brian stupid_brian is offline
Newbie
stupid_brian is on a distinguished road
Angry Palm muting too loud
Hi, I have a small problem, when i record distorted guitar, my onyx mixer picks up the palm muting LOUDER than the actual strumming, which if anyway it should be vice-versa.
I`ve had some nice recordings from exactly the same set up i`m using now but this is just irritating now, I`ve already tried:
different head
different speaker
Different mic
Different mic positions
different amp placements
fiddling with EQ
changing compressor settings
any help would be REALLY appriciated
Crazy flowing mantide migrations engorge the big ventricle of heart broken america
Old 03-31-2008
WhiteStrat's Avatar
WhiteStrat WhiteStrat is online now
Go Speed Racer, Go!
WhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond reputeWhiteStrat has a reputation beyond repute
I don't think your mixer is amplifying your palm mutes. It's just capturing what's coming it's way. You listed all the variables you've tweaked--except one: technique.
It's gotta be in the way you're playing...
Old 03-31-2008
tarnationsauce2's Avatar
tarnationsauce2 tarnationsauce2 is offline
Welcome to the jungle.
tarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond reputetarnationsauce2 has a reputation beyond repute
I'm not sure what kind of music your playing.
In metal mixing a lot of people use a multiband compressor, but disable all bands except for a lower band that centers at the palm mute bass range.
Check out this thread: http://www.ultimatemetal.com/forum/p...alm-mutes.html
Old 03-31-2008
adferrendelli adferrendelli is offline
Newbie
adferrendelli is on a distinguished road
Did you try your pickup position. it might change it a little.
Old 03-31-2008
Newbie
I palm mute with picking hand right next to the bridge, i`ve had no problems with this technique before, the problem started a few months ago.
I`ll try the multiband compressor which tarnationsauce2 mentioned. But i`ve never had to use one before, i just dont know why its happening NOW.
And adferrendelli, i`m using the bridge pickup, like i always have done. I was thinking origionally it maybe bass resinance so choosing the neck pickup really isnt a way round given its lower tone.
Old 03-31-2008
WhiteStrat's Avatar
Go Speed Racer, Go!
The neck pickup may be darker than the bridge pickup, but it also wouldn't be right under your hand when you're doing the palm mutes. Given your description of your technique, the problem might be having the active pickup right under the point of the strings that are resonating most.
At least give the neck pup a try.
Old 04-01-2008
Myriad_Rocker's Avatar
Myriad_Rocker Myriad_Rocker is offline
Registered Text Offender
Myriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond repute
It could be that it's the bass frequencies that a palm mute induces that is causing this. Maybe you should turn your bass down a bit. Let the bass guitar pick up the duty of the low end. You'll still get the same impact.
Myriad Rocker
My Web Design/Production Company: Myriad Productions
My Band: Black Leaf Clover
Originally Posted by theblackBay View Post
I’m currently "one" of the best song writers in the world
Old 04-01-2008
wbcsound's Avatar
wbcsound wbcsound is offline
Senior Member
wbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond reputewbcsound has a reputation beyond repute
I agree with the above post, use a multiband compessor to your advantage. It's always easier to take a little away instead of trying to add something back.
Old 04-01-2008
wbcsound's Avatar
Senior Member
Maybe due to the position of your amp within the room. If it's anywhere near a corner, your bass frequencies will be greatly enhanced. I've placed amps in a corner plenty of times to get a little more girth out of a smaller sounding amp
Old 04-01-2008
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
daz probably it....
audio?
seriously, give me negative rep.
Old 04-01-2008
steve.h's Avatar
steve.h steve.h is offline
Somewhere Out There...
steve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond reputesteve.h has a reputation beyond repute
Whoa whoa whoa, back the fuck up here. There are a few VITAL questions that need to be answered for anybody to help:
1 - What amp are you using?
2 - What kind of cab are you using?
3 - What settings are you using?
Your recording chain is NOT the problem, PERIOD! My guess is you've got your guitar/amp sounding FULL BY ITSELF, which will sound like ASS-BUTT-POOP-DUMP in the mix. If your bass knob is anywhere more than 3, you're fucking yourself.
Answer these questions, we'll supply you with answers
www.myspace.com/ironthrones - my sweet metal band
www.myspace.com/stevehenningsgard - my recordings
  #12
Old 04-01-2008
cellardweller's Avatar
cellardweller cellardweller is offline
Subterranean Sovereign
cellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond repute
I assume you mean 3 o'clock?
  #13
Old 04-01-2008
steve.h's Avatar
No, I mean 3 as in 3/10. There's no reason to track any more bass than that: that's the bass guitar's job! You're gonna run a high-pass at around 100hz anyway, why add shit that you're not gonna hear?
  #14
Old 04-01-2008
jndietz's Avatar
jndietz jndietz is offline
The Way It Moves
jndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond reputejndietz has a reputation beyond repute
Turn the bass knob down on your amp. It'll get rid of that boominess.
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here
  #15
Old 04-01-2008
Alex Grismore Alex Grismore is offline
Newbie
Alex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond reputeAlex Grismore has a reputation beyond repute
maybe try re-amping? Keep your original guitar tone for most of the song- However, when you re-amp .... just tweak the amp/guitar/mic placement(etc.) and replace just the loud palm muting sections.
Mulitband compressor should help also. Good luck.
  #16
Old 04-01-2008
WhiteStrat's Avatar
Go Speed Racer, Go!
Wait a minute! I think we've all missed something obvious! Have you checked the volume on your palm?
  #17
Old 04-01-2008
drfringe drfringe is offline
Junior Member
drfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond reputedrfringe has a reputation beyond repute
I'd strip down the chain, just try the amp, clean, adjust the mids, and the bass levels. I would guess it's something in the low end, judging from the eq that most metal bands use.
  #18
Old 04-01-2008
Ironklad Audio Ironklad Audio is offline
1K Silver Member
Ironklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond reputeIronklad Audio has a reputation beyond repute
+1 to turning down the low on the amp, adjusting your playing technique, and using a multi-band set from about 60-240hz
a quick sidenote to turning down the lows...not only do you not want a bunch of low end rumble being captured by the mic that you're only going to have to cut out later, but turning down the lows gives the amp more headroom to pump out the mids and "highs"...as i'm sure a lot of people here know, it takes more energy to amplify low frequencies, so get that shit out of there.
  #19
Old 04-01-2008
Rofl!
  #20
Old 04-01-2008
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
...aaaaaaaaannnnnnd this thread is in the mic forum ...WHY?
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
  #21
Old 04-01-2008
steve.h's Avatar
Because he thought the mic might have been the problem?
  #22
Old 04-02-2008
PhilGood's Avatar
Juice Box Hero
OK. Continue. It just seemed to develop into a guitar or recording technique thread.
  #23
Old 04-02-2008
steve.h's Avatar
See, that's the fun part: you never know where any given thread is gonna end up!
  #24
Old 04-02-2008
Junior Member
right on
if you're recording into a PC you can probably playback while viewing the eq, and determine where the eq levels are peaking during the playback and either reduce these frequencies, or use a limiter or compressor to "attack" at certain times, but I'd recommend eliminating the source rather than the other way around.
  #25
Old 06-03-2008
Newbie
Talking
Right, thanks for all the input guys but i finally got it sorted tonight, dunno exactly what it was but, somewhere between:
-changing the strings
-turning the amp master down
-making a "loose" wall around the amp with spare carpet (stood upright) i thought it may absorb some boom or at least not reflect it
-turned treble on amp up
So, im chuffed now...no compressors needed =D
Music - please rip apart Greenshoe MP3 Mixing Clinic 20 07-29-2003 00:49
Mic-ing a LOUD guitar amp? guitarist Microphones 21 07-23-2003 17:20
a booth for me and a box for my loud mac? boze Studio Building & Display 23 11-29-2002 14:47
MXL V67 positioning for loud vocals... jeronimo Microphones 2 09-16-2002 18:02
getting the vocals loud enough. Whisperingcreek Newbies 3 07-09-1999 11:03
