Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-29-2008
bdemenil bdemenil is offline
Force of Nature
bdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond repute
pre-roll post roll
How do you setup cubase to preroll in the way that protools does - ie, on a punch to actually begin recording before you press record - so that you can stretch the sound file back if you hit record a bit late
Old 03-30-2008
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
I don't remember off hand where exactly it is, but there is an option that you can use to set how much time in advance of hitting record that Cubase stores. I have mine set to 3 seconds. This way if you are a little late, or just wish you had started a little earlier you can still have that stuff
Dealer for Peluso Microphones, Blue Microphones and CBI cables....
http://www.myspace.com/xstaticstudios
Old 03-30-2008
Force of Nature
Thanks - if you remember how to set that up please let me know
Old 03-30-2008
eyema_believer's Avatar
eyema_believer eyema_believer is offline
Bondservant
eyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond reputeeyema_believer has a reputation beyond repute
In SX3, go to your punch-in time, hold the "alt" key while clicking on the "L" on the transport bar.... go to punch-out time, hold "alt" and clcik the "R" on the transport bar. now, click the little weird line thingy below the "L" and "R" so they light up... then record-enable your track, then rewind to your desired playback start position, press play, but not record .... it will punch in and out automatically... it's pretty sweet.
Old 03-30-2008
With some shortcut keys, setting punch in and punch out positions is much quicker then described above. All you have to do is set a left and a right locator. I have my shortcuts set up so that "i" is punch in activate, and "o" is punch out activate.
As far as prerecord goes, under the preferences menu select record. 6 lines down is an option called "retrospect record". Check that. The last line on the page is to enter how many seconds you want to prerecord.
Old 04-14-2008
Force of Nature
thanks - found 'audio pre record' setting
using a preamp, Pre A/D or dare I say Post A/D? thedude400 The Rack 4 02-20-2006 08:26
second post: problem with C1 and new pre tokyofan Microphones 0 01-12-2006 19:39
To pre or not to pre. Chewie Newbies 7 11-15-2004 18:50
Pre or Post recording Rustang Recording Techniques 7 07-01-2003 03:40
EQ Pre or Post Compression ?? Twangman Newbies 4 08-28-1999 11:21
