tubing an mp
I have an art tube mp and was thinking of replacing the tube. I have no experience with tubes so i'd like to know what kind i have to replace it with and if there's one particularily good one for the mp. Also how would i go about replacing it, assuming that it's worth it?
Those tube preamps aren"t even real tube preamps, they are actually 95% solid state and the tube is used in a "Starved Plate" configuration just to add harmonic Distortion which some poeple think is the "Tube Sound" but it is Just extra Noise and Preamps are supposed to be Noise free ,as much as possible.... I would simply save up your money and get a better preamp as a new tube isn"t going to make any real differance...... Cheers
M-Audio Delta 44 + Delta 1010LT 5 Piece Drum Kit w6 Cymbals Custom Made Bass Guitar Custom Made Les Paul Guitar Mackie Traction Studio 2.1 P-4 PC w 512mb DDR 80gb HD Sell you used Equipment Here: http://www.proaux.com/phpprobid/index.php |
is a pro mpa (not the gold) the same way? cause it sounds good to me..
myspace.com/earthandpoets myspace.com/fallofgomorrah |
No, The Pro MPA is a different animal ,It is actually a real Tube Preamp that uses a High Voltage Power supply..The Art Tube MP is a cheapo $50 unit that uses a 9-12v Adapter the Pro MPA is a Real Tube preamp.. Changeing out the Tubes on this unit could Yeild some Improvement if good quality tubes are used.....
Good luck
| Tubing a '69 Twin | Big Kenny | Guitars and Basses | 0 | 08-21-2007 16:35 |
| Replacement Padding or Tubing for Guitar Stands | Zaphod B | Guitars and Basses | 9 | 04-03-2007 10:57 |
| mic cables and soldering - teflon tubing | thexflamesxburn | Microphones | 1 | 02-05-2006 05:09 |
| Microphone flexible tubing | Kjfish | Microphones | 0 | 09-27-2003 17:23 |
| Heat shrink tubing questions | scodu | Studio Building & Display | 5 | 02-14-2003 14:31 |
