Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 03-27-2008
cellardweller's Avatar
cellardweller cellardweller is offline
Subterranean Sovereign
cellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond repute
How easy would it be?
How easy would it be to blow a speaker running my 50 watt Shingle Rectumfrier head into an Avatar 2x12 w/V30's?
Never really considered it as I've always had both 2x12's available....
If I push more than the 60 watts per speaker, I risk damage...right?
How can I safely guesstimate the peak power of the amp???
Old 03-27-2008
Zaphod B's Avatar
Zaphod B Zaphod B is offline
President, Ramrod Club
Zaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond reputeZaphod B has a reputation beyond repute
You dont' know the power output of the amp?
If it's a tube amp you can get pretty close by counting the output tubes.
Zaphod B
Two-Headed President of the Galaxy (in exile)
Tunes at http://www.soundclick.com/cowtowntommyboy
"I have educated. I know what asshole is. "
Old 03-27-2008
Topcat53 Topcat53 is offline
Newbie
Topcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond reputeTopcat53 has a reputation beyond repute
Without getting long winded and going into a lot of detail, the answer depends on what kind of music you're playing. In a typical rock or blues setting, there should not be an issue running a 50 watt amp into a cab with 2 V30's. (I'm assuming the impedance matches the amp?) The voice coils and cones are high quality enough to stand up to that pretty easily. The original Marshall 100w heads were often matched to a 4x12 cab with Greenback 25's and did just fine.
The two dangers you run are overheating the voice coils or delivering too much shock pulse load to the speaker and driving the voice coil through the cone. If you're playing involves paint peeling gain settings with a distortion pedal on top of that and you don't give the speakers a break to cool down, you could overheat the voice coils to the point that they melt down. Or, if you are detuning and setting the amp to get that pant leg moving low end thump, you could deliver enough shock pulse load to drive the voice coil through the cone if you hit a power chord hard enough.
Old 03-27-2008
Well, I've always hoped I wasn't that shouda-been-a-bass-player kind of guy, but I do own a 7 string!
I think I have my answer; that except under extremely brutal (cue Nathan Explosion) circumstances 60 watt of speaker should handle 50 watt of amp!
Old 03-27-2008
donkeystyle donkeystyle is offline
This place sucks now. Bye
donkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond repute
according to ted weber, a tube amp dimed can produce 20% more power than it's rating.
So if you're diming the thing, you do risk some damage. I doubt you should be concerned though.
This place is garbage.
Old 03-28-2008
Sloan's Avatar
Sloan Sloan is offline
Force of Nature
Sloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond reputeSloan has a reputation beyond repute
Just hope the speakers explode in a badass fireball.
sloanstewart.com
Old 03-28-2008
or if they collapsed into "the most brutal gift of all.....NOTHING!"
Old 03-28-2008
legionserial's Avatar
legionserial legionserial is offline
Dead
legionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond reputelegionserial has a reputation beyond repute
Yeah, maybe you'll create a black hole which slowly but thankfully wipes out the human race.
"Introduce a little anarchy. Upset the established order, and everything becomes chaos. I'm an agent of chaos.
Oh, and you know the thing about chaos? It's fair..."
Old 03-31-2008
g blaze g blaze is offline
Newbie
g blaze is on a distinguished road
ok
jajaja u crazy man
Easy Listening ? Jack Real MP3 Mixing Clinic 5 07-10-2003 15:54
Yamaha Synth - Easy way to change patch selections? GringoKC Keyboards and Sound Modules 3 03-03-2003 17:44
EASY question BigPapaFly Cakewalk / Sonar Forum 2 02-27-2003 11:10
It Ain't Easy Bein' Me chrisharris MP3 Mixing Clinic 53 12-21-2002 12:26
Getting Burned by Easy Creator Steve M Newbies 4 06-08-2000 16:21
