Old 03-26-2008
Lomas Lomas is offline
Senior Member
Lomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond reputeLomas has a reputation beyond repute
Compressors
I know how they work and I know the parameters, except for one thing. People say, when describing compressors, that they lower loud parts and raise quiet parts. It's the last part that I don't get. If I put a signal through a compressor with a 2:1 ratio, any part of the signal that exceeds the threshold will be lowered by half.
But how does it raise the low signal, unless I use make up gain? The thing is I thought that make up gain is supposed to be used to compensate for change in volume compared to the uncompressed signal, to not be confused by that change in volume.
Is it really a good idea to compress and then use make up gain to increase volume instead of compressing and then raising the fader on a mixer or sequencer? Or doesn't it matter where it's done in this case?
I understand how, if you lower loud parts and then increase the volume you are in a way raising the quiet part and lowering the loud part. Just checking to see if I missed something else.
Old 03-26-2008
aidan_m's Avatar
aidan_m aidan_m is offline
Budding Rock Star!
aidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond reputeaidan_m has a reputation beyond repute
Compressing lowers the louder bits (then add gain to compensate)
Limiting brings up the quiet bits.
Explained much better here:
http://homerecording.com/bbs/showthread.php?t=74122
Old 03-26-2008
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Originally Posted by Lomas View Post
...Is it really a good idea to compress and then use make up gain to increase volume instead of compressing and then raising the fader on a mixer or sequencer? Or doesn't it matter where it's done in this case?
Apparently in some designs make up is part of the built in function -aside from a separate output gain. (or perhaps it is how the relative relationship of threshold point and gain are defined) IIRC 'Valley People might have done it as 'built in'(?)
As a practice matter I wouldn't think it would matter if it was built in or where it was done.
Look at it like this too- Half the time if you're just knocking off some tops' there's not much in the way of gain or preceived volume to be 'fixed', and you just go on to making the moves you will do on the balance fader anyway. When there is a audible loss, the make-up knob is good for doing a/b quality comparisons at equal loudness.
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 03-26-2008
Senior Member
I guess it's like I thought then.
Isn't limiting the same thing as a compressor only with a ratio of at least 10:1?
Old 03-26-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Compression lowers the louder parts - Limiting *LIMITS* the louder parts - It does NOT make the quiet parts louder - It STOPS the louder parts cold. Adding gain makes the quiet parts louder (and the louder parts disappear forever).
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 03-27-2008
Senior Member
So it isn't true that limiting is the same thing as a compressor but with a ratio of at least 10:1
If it is, then theoretically a limiter can let a signal stay over the threshold, right?
Old 03-27-2008
With high ratios they are comp/limiters, but many compressors have attack times that aren't strictly 'brickwall. So you might be looking at matching the unit to the the source (or job) in application.
For example a vocal comp set 10-1 is 'limiting -ie be set up to work mostly on the peaks and be fast enough for that, but wouldn't do the job of a peak stop or clipper'.
I believe so. (Let's call in some help here... Some times it's enough just to do an amount of control that's needed with some amount of overshoot being exceptable.
Compressors during recording hubb_99 Recording Techniques 52 01-02-2008 20:40
Opinion of VST Compressors joswil44 Recording Techniques 18 04-18-2007 14:06
4 or 8 channel compressors cusebassman The Rack 14 10-17-2006 21:53
16 compressors cooker Roland, Boss, VS Series Forum 0 01-21-2005 05:10
Behringer compressors: Pro XL series tomleblanc The Rack 8 06-14-2003 20:10
