Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-22-2008
flextone flextone is offline
Junior Member
flextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond reputeflextone has a reputation beyond repute
akai s3000 sampler help with technique
Hi,
Just got an akai s3000 to compliment my mpc3000 and was wondering if i can do something like this:
What i want to do is make a sample loop, and then gradually shorten the length of the loop in real time so it plays faster and faster. Now, in the loop window in my s3000, the length field changes in extremely small increments (ms) so i can't really do it that way.
Any other way of achieving this? maybe LFO > loop length? Can that be done on an s3000? Any ideas?
Thanks
Flextone
Old 03-23-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
why not just map it across the whole key range and then sequence the notes every one or half (or however extreme you want) octave
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 03-23-2008
Somnium7's Avatar
Somnium7 Somnium7 is offline
Noise Criminal
Somnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond reputeSomnium7 has a reputation beyond repute
The only sampler I can think of that can do this is the Casio FZ-1/FZ-10M which can add up to eight loops per sample.
Another idea would be to adjust the loop end point while playing the sample in edit mode and record the result.
If you could see crime in a mans face we wouldn't have any mirrors - H. Bogart
Somnium7
Somnium7 on MySpace
Old 03-24-2008
Junior Member
Somnium7,
that's exactly what i want to do but the loop length can be moved only in milliseconds and it takes forever to move the cursor from one point to another using the data wheel, basically it has no effect that way.
i guess akai wanted the user to dial in the desired value and then fine tune it with the data wheel. that's not what i need.
Old 03-25-2008
X man Da Legend's Avatar
X man Da Legend X man Da Legend is offline
Vinyl Hugger
X man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond reputeX man Da Legend has a reputation beyond repute
probably wtih a lot of copying
Myspace
Sonar Home Studio 7, Reason 4, Recycle 2, Behringer BCF2000, Ensoniq EPS, Roland Alpha Juno 2, KRK Rokit 5 Monitors, Stanton str8-60 Turntable and Stanton DJ Mixer, Roland XP-30, Korg Tr rack, Korg M3R, Stanton S.252, Lexicon Alpha
Old 03-25-2008
Somnium7's Avatar
Noise Criminal
Originally Posted by flextone View Post
Somnium7,
On my S6000 I can change the number of samples during scrolling with the datawheel by using the left/right arrows to change from tens to hundreds to thousands in the samples field. Check to see if your Akai has this feature. Can you change the value where it shows "time: OFF mS"? See pic...
That damn FZ-1 would allow you to trigger a sample via Midi in edit mode and you could adjust start or end points by the entire sample length in real time without glitching. That machine rocked for this sort of stuff.
My advice is to make several copies of the sample and give each a different loop and then map them out into a program. Yeah it's alot of work....
However, I am not an expert with the 3000 and it may have features I am not aware of. Maybe try posting your problem here...
http://akaipro5k6kuser.proboards30.com/
I'm sure some of the real old-heads there know more about your Akai than I do.
Somnium7
Somnium7 on MySpace
Old 03-26-2008
Junior Member
thank you for your reply and the nice screenshot! my loop screen looks exactly like that but i don't underdstand what do you mean by "samples field", where is it? i can't see such a fiels in the screenshot. yeah i can change the value where it says OFF, what now? i don't get it, is this the samples field?
I've posted a question at that forum you linked me to, thanks.
Old 03-26-2008
Somnium7's Avatar
Noise Criminal
That's what I was wondering myself. When you change that value does it change the speed of scrolling to move the loop point?
Somnium7
Somnium7 on MySpace
Old 03-26-2008
Junior Member
from the s3000 manual(s3000xl actually, no manual for the s3000):
Each number field is separately accessible allowing you a great
deal of flexibility in editing such large numbers. For example, to make a big change to the
start point, move the cursor to the 1 using the +/< key found on the numeric keypad - as
you move the DATA wheel, you will increment in big jumps. This is good for getting
someway into the sound with little effort. When you are close to where you want to be,
move the cursor one position right using the -/> key to edit the start point in smaller
increments.
i'll try it out and let you know!
Old 03-26-2008
Somnium7's Avatar
Noise Criminal
Well that sounds promising. Pretty similar to how I do it on my sampler using the left/right cursor keys.
Somnium7
Somnium7 on MySpace
Old 03-26-2008
Junior Member
SUCCESS!!! THANX!!!
now,
if i could only use an external midi controller to adjust the loop length...
possible?
  #12
Old 03-26-2008
Somnium7's Avatar
Noise Criminal
SUCCESS!!! THANX!!!
now,
possible?
Good for you! Glad you got it working.
You'll need to find the Midi specs for your sampler and see if you can map a controller to that parameter. I honestly can't say off hand if it's doable.
Somnium7
Somnium7 on MySpace
  #13
Old 03-26-2008
Junior Member
ok, i'll figure it out,
thanks anyway for your help, this bbs saved my ass once again!
flextone
  #14
Old 03-26-2008
Somnium7's Avatar
Noise Criminal
flextone
Glad to be of help
Happy sampling!
Somnium7
Somnium7 on MySpace
Mid Side & Blumlein Technique karma101 Recording Techniques 3 09-13-2006 15:07
Akai Z8 Sampler rayh Free Ads for Music / Recording Equipment 0 02-16-2005 16:59
AKAI S2800 Sampler Question Graphcorp Keyboards and Sound Modules 1 01-05-2005 14:47
Akai S950 & Akai S3000 Judge DJ & Hip Hop Production 0 02-25-2003 17:16
Akai sampler control Hobbes Cakewalk / Sonar Forum 0 10-10-2002 03:16
