Old 03-19-2008
insanescott insanescott is offline
Newbie
insanescott is on a distinguished road
Using Outboard effects
I am using a Mackie Onyx Mixer and Sonar. Recently, I have been looking into getting a rackmount reverb and a rackmount compressor.
Would it be possible to record mic>mixer> computer, and then run my recorded data through the reverb or compressor instead of using vst compressors and reverbs?
Or, will I only be able to run mic>rack effect>mixer> computer and not have the freedom to use the rack effects as I would a vst effect?
Thanks in advance.
Old 03-19-2008
carlosguardia's Avatar
carlosguardia carlosguardia is offline
Dedicated Member
carlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond reputecarlosguardia has a reputation beyond repute
you can use outboard effects with Sonar. It does depend on your sound interface, however, but the answer to your Q is yes!
Planeta C Recording Studio. San Jose, Costa Rica.
Old 03-19-2008
Newbie
Do you know how to hook this up correctly and how to make it work? Thanks.
Scott
Old 03-19-2008
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
You need to give us the entire run down on your set up. Sound card, SONAR version,outboard gear, mixing board (in the pc or external?), patch panels or direct connecitons to the sound card(s).
We're flying in the dark here.
She's not the boss of me
Old 03-19-2008
Newbie
I am using a Mackie Onyx 1640 using the firewire out...no sound card is used in the recording and playback process. Sonar version 7.....no outboard gear yet, but was looking a couple of vintage compressors and reverbs. That's all the information ive got.
Old 03-20-2008
Newbie
Can Anyone help? Thanks.
Old 03-20-2008
punkin's Avatar
Thats what your sends and busses are for. On a per channel basis, you'd use your send out to the effects unit then the return to bring the effected signal back to the channel.
Busses are kind the same thing but on a larger scale in that you mix several channels down to a buss and use the send/return on the buss to pipe the mixed signal through your effects unit.
Get a copy of the manual for your unit. Look at the block diagram.
This is a pretty good read; http://www.tweakheadz.com/choosing_a_mixer_p2.htm
Here's a little diagram showing an effect unit inserted in a channel strip; http://www.soundonsound.com/sos/jul0...ectsfig2.l.jpg
Here's the whole article; http://images.google.com/imgres?imgu...3Doff%26sa%3DN
The connections for the effects "aux" in/out are done on the back (go all the way to the bottom); http://www.mackie.com/home/showimage...640_top_lg.jpg
But seriously, the owners manual and the diagrams in there are the best place to start.
Cable suggestions for running outboard gear through effects loop of my amp? SappyHad Guitars and Basses 1 01-29-2005 15:48
effects w/ computer recording hubb_99 Digital Recording & Computers 6 01-21-2005 16:19
Outboard effects for PC recording A1A2 The Rack 1 08-22-2002 17:18
do i need outboard effects with my DAW consciouspilate The Rack 7 07-09-2002 15:10
outboard effects Stoney Newbies 0 06-28-1999 16:52
