Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 03-17-2008
Jack Real Jack Real is offline
Dedicated Member
Jack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond reputeJack Real has a reputation beyond repute
Mixing bass
Hi
I have recorded my bass through a Korg bass effect and I also have the direct signal. I noticed that when I mix the 2 signals together, I can get presence and fullness but I'm not sure if I'm not creating phase issues. Is it o.k. to use the 2 signals in a mix and is there a way to proceed to avoid phase issues ?
Thanks,
Jack Real
Old 03-17-2008
mrT's Avatar
mrT mrT is offline
Force of Nature
mrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond reputemrT has a reputation beyond repute
Mixing 2 bass signals is pretty common. If you hear phase issues just line up the two waves so the peaks are in the same place.
Dishonest lifelong misspeller and theif...
Graphic
When Your Horse Dies, Get off It...
-David Petrie's tomb stone.
Old 03-17-2008
Dedicated Member
Hi
I did that and it corrected the phase issue, thanks.
Now, do you know what is the use of the direct signal, is it to add presence to the bass ? Should I pan the two bass signal slightly or delay the wet signal by 5 ms ?
Thanks,
Jack Real
Old 03-17-2008
Concrete_Lake Concrete_Lake is offline
Junior Member
Concrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond reputeConcrete_Lake has a reputation beyond repute
Don't pan them, unless you want to create an effect, and delaying the wet signal is just going to re-introduce the phase issues. The reason people record both DI and amp, or any other combination, is for choice when it comes to mixing. You can either use one, or you can blend them. EQ one and not the other, compress one of them and not the other- there's a huge number of combinations to produce the sound you want.
Old 03-17-2008
Dedicated Member
Hi
Thanks for the answer. I will try that and see if I can get the sound that I want.
Thanks again.
/Jack Real
Old 03-21-2008
BenignVanilla BenignVanilla is offline
Senior Member
BenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond reputeBenignVanilla has a reputation beyond repute
This post caught my eye...I recorded some bass tracks for my band the other night, and we experimented with different mic setups, and finally ended up with just going direct. I then double the tracks, kept one clean and panned, and then panned the other in the other direct but closer to center, with some cleanup and reverb.
I like the idea of the Direct plus Mic. Have you used this successfully?
Old 03-21-2008
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
do you know what is the use of the direct signal?
Another good use of DI bass is to re-amp the signal.
Ive heard you are meant to use a re-amp box but these can be pricey but Im sure it can be done well without one...
Eck
Million dollar ears.
CRYSTAL MIXING
MY BAND
Recording Settings Chart or something.... zenabi Mixing / Mastering 19 01-21-2006 08:07
Mixing Bass wordizbon Mixing / Mastering 29 04-28-2004 08:01
First time mixing a bass guitar with an acoustic guitar randyfromde MP3 Mixing Clinic 8 04-06-2004 20:43
How many people mixing in parallel rooms without bass traps malcolm123 Mixing / Mastering 17 09-08-2003 08:21
bass mixing milkweed Mixing / Mastering 4 01-05-2003 14:03
