which portastudio?
so I am thinking of getting one of these 4 track tape recorders. any suggestions?
also, I'm guessing I would need to get an external preamp to put mics through it? |
1- There have been many different Portastudios. If you think you can get by with only 4 tracks, some good machines to consider from the used market are the Tascam 424, 464, and 644. If you want something a little more portable, check out the Tascam 414.
Should you need 8 tracks, the best unit is the 688, although it's a little more complicated to use, so make sure you get a manual for it. The other option for 8 tracks on cassette in a Portastudio format is the Tascam 488. 2- You shouldn't need an external pre-amp, with a few exceptions: a- You need phantom power for your mics, at which point it may be worth it to invest in a better pre-amp that provides phantom power as well. b- You're using one of the Portastudios that only has 1/4" inputs, rather than XLR. However, with the correct adapter, an external pre-amp would not be needed. The 424, 464, 644, and 688 all have XLR inputs. -MD Last edited by themaddog; 03-18-2008 at 05:36.. Reason: Punctuation |
am buying a 424 off someone today. I look forward to it!
I've got one and love it! Good luck and have fun with it!
<insert witty and more appropriate comment here>
You'll enjoy it. Give a holler if you have any questions. If you have the chance to test it out before purchasing it, I highly recommend it.
Good luck! -MD |
I am getting a hum from the tape. is that normal?
is it more like a high pitched "hiss" than a low pitched hum? if its a hiss, then yes, tape hiss is normal and to be expected. try using the dbx noise reduction if that is a problem, or try hitting the tape harder to increase the signal to noise ratio.
did you get a manual with the recorder? if its a hum, it could be something else. it could even bad wiring in your building. |
My 424 has always hummed and hissed.
But it's still a whole lot of fun making hummy, hissy recordings! ![]() |
yeah it's hum. if it was a hiss I wouldn't be inquiring since I know they hiss and I also love hiss. but it's really like a ground loop sounding hum. I had ground loop problems with my powered monitors too, so I wouldn't be surprised if it's a house electricity related thing. any chance of it being a problem with the actual machine?
Always a chance, but if you're monitors are also having the same trouble...
-MD |
but wait, wouldn't I hear a hum from it all the time and not just from the tape if it were a ground loop issue?
| Portastudio 144 Compatability | rice80 | TASCAM User Forum | 8 | 10-30-2004 15:55 |
| Portastudio live recording good! Mixdown Not! | k1enneth | TASCAM User Forum | 4 | 09-30-2004 09:41 |
| Mixing Down From Portastudio to Computer | bferber | Recording Techniques | 6 | 09-05-2003 04:53 |
| Help novice compare portastudio to computer recording | tahmus | Digital Recording & Computers | 10 | 12-14-2002 23:18 |
| question on Tascam 246 | vragle41 | TASCAM User Forum | 11 | 10-26-2001 14:36 |
