Inserting external Comp
Hi,
I'm trying to route a recorded track through an external comp. I have set the output for the existing track to 3-4, taken output 3 of my interface(presonus firebox) inputed it into my comp, output of comp into interface input 3(line in), created a new track, assigned it to inout 3 and put it into record mode. Signal passes fine and comp is working great. However when I go try to record I get "error 12345", any thoughts? Secondly, is there a better way to insert the comp onto the existing track through a bus/aux? If so please advise. Thanks so much.
Tascam Series 70 4 track 1/2" B&O Beocord 2400 Macbook Logic 7 SeventhCircleAudio N72 Preamps AKG/Neumann Mics |
I use the I/O plugin. It's under the utility section of the plugin list. Pretty easy to use, select the outputs you use to send the signal, and the inputs you're using to bring them back in. Logic I think accounts for the delay automatically. Acts just like your using a software plugin, only you get to use your hardware in the path
Thanks, I'll give it a shot.
| Comp Track or composite tracks | walters | Recording Techniques | 4 | 05-28-2005 22:15 |
| External Harddrive for Laptop advice needed | dvcox | Other Equipment and Reviews | 2 | 03-17-2005 13:20 |
| External Hard Drive for Laptop | drathbun | Cakewalk / Sonar Forum | 9 | 12-03-2004 02:03 |
| Mic pre & comp question ? | cjacek | Recording Techniques | 2 | 03-17-2004 13:18 |
| 840ex and external mixers | grachus | Roland, Boss, VS Series Forum | 2 | 12-10-2001 17:05 |
