Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-11-2008
rush1974 rush1974 is offline
Newbie
rush1974 is on a distinguished road
MIDI Cable lenght question
hi guys . . just wondering what is the max length you can have your midi cables at . I have to run the cable from 1 room to the other and the length i need is about 40 to 50 ft . can midi cables be that long . i know i can by a cupling and connect them but don't want to have any joinings .
also, instead of using an adaptor and joining 2 20ft cables , i was thinking of making my own 50ft cable using the network data cable and putting connectors at both the ends . can you use network cables using only 5 wires from there with connectors at the end instead of the actual midi able .
will that work .
thanks
Old 03-12-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
The spec is 50ft but it really depends on the devices involved. I would look for an old JL cooper midi repeater on ebay, they pop up fairly frequently
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Old 04-03-2008
tangerine's Avatar
tangerine tangerine is offline
grumpy bastard
tangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond reputetangerine has a reputation beyond repute
midi spec 1.0 suggests 15 metres maximum length.
I give espskully the splats
Old 04-03-2008
um, 15m = 50 ft
Old 04-04-2008
tangerine's Avatar
grumpy bastard
Originally Posted by altitude909 View Post
um, 15m = 50 ft
You didn't put the m.i.d.i standard though.
You can transmit m.i.d.i. over a LAN connection from one computer to another increasing the distance that m.i.d.i. is transmitted
midi cable question dmbfan1981 MIDI Mania 3 03-17-2007 19:54
Do it yourself USB MIDI cable? STAT1STICK Studio Building & Display 3 06-03-2006 17:44
Completely MIDI CONFIG Illiterate Outhabox MIDI Mania 4 03-10-2006 10:43
Midi track with Sonar & Audigy’s Interface?? carlosfl Cakewalk / Sonar Forum 6 06-25-2005 11:16
Quick Question sarkastic714 MIDI Mania 1 09-21-2004 06:21
