Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 03-10-2008
dm303102 dm303102 is offline
Newbie
dm303102 is on a distinguished road
Cubase realtime VST Effects
Hi,
I just got a Yamaha i88x and started using Cubase SX. How could I use one of the VST effects on my guitar input to hear it while I am playing in real-time? Also, while I am on the topic, how could I record with an effect on my input in real-time while playing previously recorded tracks in my monitor from Cubase? Would I have to worry about latency issues? Thanks
Old 03-10-2008
altitude909's Avatar
altitude909 altitude909 is offline
Best Advice Ever: RTFM
altitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond reputealtitude909 has a reputation beyond repute
Latency will be the greatest problem here.
for playing live:
turn your ASIO buffer all the way down to the lowest setting available. Set your input channel to whatever channel your preamp is plugged into, set the out to whatever your monitors are plugged into. Turn monitoring on, and select the plugin you want to use from the inserts list. turn OFF the PDC (plugin delay compensation)
You dont need to record the effect per say. Just record the dry signal with a plugin active so you will hear the effected signal but will be recording dry. That way, you can always go back and tweak the plugin parameters if you need to adjust anything and still have the dry recording intact. You will want to turn the PDC back on after you actually record the audio. Cubase will only record the tracks that are armed so you can play back what ever tracks you want to play along with. If you are micing your cabinet you will want a headphone mix otherwise if you are just using a pre to interface with the i88, you can just play back everything over the monitors when recording
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual
Cubase VST delay compensation KeithCF Cubase User Forum 1 04-21-2005 14:54
Cubase VST: Panning & Stereo Separation rio452001 Cubase User Forum 0 12-23-2004 07:58
Cubase VST 5 with Rewire 2.5 rouge2004 Cubase User Forum 3 08-17-2004 10:28
Roland VM3100 Pro with Cubase VST 32 5.0 TBigdrum Roland, Boss, VS Series Forum 0 08-08-2004 21:36
Midi realtime effects dcau Cakewalk / Sonar Forum 1 08-05-2001 02:26
