Old 03-07-2008
guitar zero's Avatar
guitar zero guitar zero is offline
What's On Tap?
guitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond reputeguitar zero has a reputation beyond repute
Compression/Pre Amp Question
I'd like to use an ART PRO VLA two channel compressor in my recording. This unit is labelled as a "tube levelling amplifier". Would it be of any benefit adding a pre amp to the signal chain, or would that be redundant?
Any thoughts?
Thanks
Old 03-07-2008
M10K M10K is offline
Senior Member
M10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond reputeM10K has a reputation beyond repute
Hmm...dunno...the search function is your friend though.
Old 03-07-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
That doesn't even make any sense... One is a preamp, one is a dynamics processor... The two have nothing to do with each other.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 03-07-2008
bigwillz24's Avatar
bigwillz24 bigwillz24 is offline
One Turd at a Time...
bigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond reputebigwillz24 has a reputation beyond repute
yes ...
Old 03-07-2008
What's On Tap?
Sorry,
I realize pre amps and compressors serve different functions, I'm just trying to figure out if this is a combination unit, since it's labelled an amplifier, and sold as a compressor. I'm just a little confused by the labelling. Is levelling amplifier another name for compressor?
Old 03-08-2008
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
Yes.
It was used more back in the 50s/60s but as units from that era are now revered (the LA-2A being a good example) it's become de rigeur to use that name again.
If you were wanting to use it in the recording chain with a mic then the mic signal would still need to be pre-amplified before hitting the compressor (or "levelling amplifier" ).
"Just give the great unwashed a pair of oversized breasts and a happy ending, and they'll 'oink' for more every time."
C. M. Burns
http://www.shuttleworths.co.uk/micloop.gif
Old 03-08-2008
random effect random effect is offline
Junior Member
random effect will become famous soon enough
yea i got the pro vla and the mpa gold preamp. the two work great together (especially after swapping the tubes for a mullard and a jj in the mpa and two mullards in the vla... nice entry level setup. I would even go as far as to say that it will take you right up to the point of sonic quality just below the big bucks... give it a try and tell me what you think.
Old 03-08-2008
What's On Tap?
The signal is getting clearer
Thank you very much, that clears things up for me. Random, I've also been looking at the MPA Gold as a pre amp. Good reviews, solid name brand, sounds like you are confirming my impression that for the money, it will be hard to beat.
Zero Out
Old 03-08-2008
What's On Tap?
Hey Random, I'm curious why you would put a different type of tube in each channel of your pre amp? Are you just aiming for variety of sounds?
Zero
amp schematics dragonworks Guitars and Basses 1 02-20-2007 11:53
How do you get guitar feedback when an amp is out of the question? dogbiscuit Recording Techniques 32 05-30-2006 11:17
ROG-type amp design question GreenDank Keyboards and Sound Modules 1 01-13-2006 08:48
amp question? dkimcohn Recording Techniques 2 12-26-2005 21:56
an odd amp question little guy Guitars and Basses 33 07-26-2005 14:26
