Old 03-01-2008
Gone 6 days now Gone 6 days now is offline
Newbie
Gone 6 days now is on a distinguished road
sobell tape machine inputs. Help!
I have a an old tape machine from the 60's which I feel like using for some (insert buzz word) "lofi" effect. the problem is that the machine only has phono input and outputs, so how would i connect a mic to this?
Old 03-01-2008
jpmorris's Avatar
jpmorris jpmorris is online now
Tape Wolf
jpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond reputejpmorris has a reputation beyond repute
Depends on the mic. If it's XLR and needs 48v phantom power, get a cheap mic preamp. You might find one with phono connectors, if not, buy or build a 1/4" jack->phono lead.
If the mic has a 1/8" or 1/4" plug, you'll just need an appropriate female jack -> male phono lead.
If the mic is one of these 'plug-in-power' ones that requires a 1.5v source, you'll probably be better off buying another mic as it won't work for this.
Old 03-02-2008
Newbie
Thanks for the advice, I made a phono to jack lead and hooked up the mic but there is another problem, the tape records but no signal is heard during play back. Is it because the microphone needs a power source, it is a cheap £1 mic.
Old 03-02-2008
jpmorris's Avatar
Tape Wolf
You might be able to bodge it by placing a 1.5v battery in series with the input - I think I've seen it done like that before. But you'd probably be better off just getting a cheap dynamic mic, or anything else that doesn't need plug-in power.
Old 03-02-2008
Dr ZEE's Avatar
Dr ZEE Dr ZEE is offline
Anti-Pro Circles Insider
Dr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond repute
Originally Posted by Gone 6 days now View Post
I have a an old tape machine from the 60's ...
What brand /model?
the tape records but no signal is heard during play back....
How do you know that "the tape records"?
it is a cheap £1 mic.....
what exactly mic is it, brand/model?
/later
Dr ZEE
MZE | ZDL | DZW
Old 03-02-2008
Dr ZEE's Avatar
uh, I've found your older post. some 60s Sobell machine. Had to do some "investigative work" to figure out what the question is about.
Now, where is my "paycheck" ?
still have no clue what exactly machine we are talking about. the mystery still there.
...woking on it
/later
Dr ZEE
MZE | ZDL | DZW
Old 03-02-2008
Newbie
it is a sobell festival from the 60's and i know it can record because there is two lights each with writing above them. They say play and record. I did get the machine to record but it makes a low beep sort of noise when i talk into the microphone, which is unbranded.
Old 03-02-2008
Dr ZEE's Avatar
are those "lights" with writings above them moving (green or blue) or just lamps?
Does this recorder have two input jack - one "LINE" (or "High") and the other "MIC" (ot "LOW")
If so, can (or could) you record some line-lavel audio (like from CD-player / tuner / tape recorder / mixer output etc) and play it back fine? (assuming using "Line" input jack)
I also assume that your recorder has Vacuum Tubes in it? Correct?
Dr ZEE
MZE | ZDL | DZW
Old 03-03-2008
Newbie
The inputs on the machine are: mic, rad, p.u and speaker. The lights are two lamps, they do not glow blue or green, and it does not say play it says pilot, sorry for any mistake. there are two mullard tubes in the machine but I cannot remember the serial number of them.
Old 03-03-2008
Dr ZEE's Avatar
uh, cool
so, first of, the fact that those lamps come "ON" does not really mean much in term of your recorder's "health".
Pilot - "shows" you that the unit is "ON"
"Record" lamp shows you that the machine is in "record" mode (mechanically speaking ), but it does not really mean (it does not indicate) that the recording actually occurs.
ok,
so, I guess "rad" - means "radio" (?), so I guess this is "High" level input.
So did you try to record something from a CDplayer or a tuner or mixer output, using that "rad" input jack?
If not, then try and see if you get sometheing recorded and then play it back.
If you can accomplish that, then the machine is ok, and the problem is in your microphone (or microphone connection).
I am just trying to sort of figure out if your recorder actually works.
Also, I don't know a thing about your recorder, so it's just my guessing.
Dr ZEE
MZE | ZDL | DZW
Old 03-03-2008
Newbie
I have not recorded a cd on to it yet but i am planning to do so, also the record light only flashes when i speak at a certain volume. Thanks for all the info Dr Zee and I will get a pic of the machine up tonight
  #12
Old 03-03-2008
Newbie
Success!! I played a cd through the rad input and can hear the music through the sobell speaker. Now a new problem as poked its ugly head. the record switch only works in the middle between on and off which means i cannot get the play switch in full play position. I suppose i will just have to crack it open and see what i can do. Also some pics
  #13
Old 03-03-2008
Dr ZEE's Avatar
Be very careful when opening up the machine.
Turn it off and UNPLUG the power cord.
Also, even after you turn it off and unplug , the Power Supply's electrolytic capacitor(s) can still hold DANGEROUS charge for long time.
Do NOT touch ANY contacts with hand. NEVER touch contacts with both hands - USE ONE HAND if you have to touch some contact(s), (keep the other in the pocket ), wear some rubber bottom shoes. Actually if you have rubber gloves - put them on.
This is not a joke.
Read this thread (maybe more than you need to read or know, but it does not hurt):
http://www.diyaudio.com/forums/showt...threadid=30172
Now, if the REC lamp is "flashing to the music" then I am not sure what kind of lamp is it nor what technical idea/circuit serves it -
all I'm aware of is one of these: http://www.akh.se/tubes/eyes.htm
post some photos, that would be great.
Dr ZEE
MZE | ZDL | DZW
  #14
Old 03-04-2008
Newbie
Thanks for the safety checks, i didn't know it could be that serious. I tried uploading pictures ut they were too big, i will have to try and cut the size down.
  #15
Old 03-04-2008
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Yeah, I too was surprised by the warning posted by the good Doc. Not that I would go into a machine that deep but it's good to know about the dangers!
  #16
Old 03-04-2008
Dr ZEE's Avatar
The Danger is there,
AND!
My name isn't Albert,
Dr ZEE
MZE | ZDL | DZW
  #17
Old 03-04-2008
jpmorris's Avatar
Tape Wolf
In the absence of photos, I'd guess it's either a magic eye, or simply an overload indicator. To a degree how dangerous the recorder's internals are depends on the technology used. A 1960s recorder could either be valve or transistor. If it's transistorized, it should be reasonably safe (with the exception of the power supply, and possibly the motors). If it's a valve unit it could be running to hundreds of volts and the warnings above apply in full force.
Could you upload the pictures to photobucket or something?
  #18
Old 03-04-2008
Dr ZEE's Avatar
maybe something like dm160: http://www.r-type.org/exhib/aai0056.htm
i've never seen those in person.
Dr ZEE
MZE | ZDL | DZW
  #19
Old 03-10-2008
Newbie
Sorry i have not replied in a while but my internet was broken, the wonders of technology. Does anyone know a site I can upload pictures, the smallest resolution on my camera is still too big. the machine was built in 1961 and is indeed a valve circuit.
  #20
Old 03-10-2008
jpmorris's Avatar
Tape Wolf
Try http://www.photobucket.com
You'll have to register, though, but if it thinks the files are too big it will automatically resize them for you.
  #21
Old 03-10-2008
Newbie
here is a link to the first one
http://i248.photobucket.com/albums/g...w/DSCF2995.jpg
more coming
Duuuuude...my tape got totally baked last night Whoopysnorp Analog Only 7 12-30-2007 09:19
Incorporating Analog tape into DAW (thoughts) sushi-mon Recording Techniques 21 05-19-2006 17:41
Playing 3-3/4 IPS tape on 7 IPS Machine RJ_HighRisk Newbies 6 10-10-2005 13:40
Wilco's Jeff Tweedy on analog tape shortage Bigsnake00 Analog Only 10 07-22-2005 18:48
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
