MMC to tright transport controls?
I have an Allen & Heath GS3V...it's the one with 1 million midi buttons. Says in the manualthere are dedicated function buttons for controling tape machine transport buttone via MMC. Can I use these to work the transport in Cubase SX3?
How would I go about it? I'm really clueless about midi. I have an Emu Xmid 1x1 that I use to get my eDrums in there to trigger ezdrummer but thats about all I know how to do. I'm guessing I'll be needind a 2x2, something like a midisport. Just wondered if it was even possible. Alex |
Yes and no. I have gotten it to work with my TM-D1000 but the problem is that MMC transport controls generally behave differently than DAW transport controls and using them to control a DAW is cumbersome at best and really annoying at the worst. IE, MMC controls are just like a tape deck so if you hit FFW, you have to hit stop to make it stop. Gets old quick.
If you want to try it, go to devices/device setup, hit the + in the left hand corner and add a generic remote. Read the help file to set it up If you are looking for a super cheap and good remote for cubase, look for a JLcooper CS-10 that was made for an old mac with the RS422 connection only (no midi). I paid $25 for mine and it was mint in box. These are pretty useless now since no one uses RS422 anymore. New CS-10s with midi are $570 btw, so this is a good quality device. Now the neat thing is, the way that serial connection worked was that it just sent midi over RS422. What you can do, and this is how I run mine, is just to get an old Mac serial to midi adapter, which are also dirt cheap ($7 for mine) and bus powered, and just plug it into the "to host" port on the remote and viola! $570 remote for $32 ![]() There is a remote template built into cubase and it works perfectly! ![]()
"Default is the value selected by the composer overridden by your command." - Roland TR-707 Manual |
MAC? I'm PC based
you missed my point. The way that old macs worked with midi is that they would send it out via the serial port as a standard midi stream so all that you have to do to get it to work with anything midi is to put a mac to midi adapter on the end of the remote to convert it back to standard midi. It will work with anything that has midi, not just an old mac
ok, so I've managed to get the MMC buttons to work for the transport.
I even tried the ADD GENERIC REMOTE and by using the learn function in the setup panel I have the 16 faders on the GS3V moving the faders in SX3, only problem is....when I move a fader up on the board the corrisponding fader moves down in cubase and vice versa. I know there must be a simple parimeter I can change somewhere to fix this but I don't know where? |
try using the learn function and move the fader from - to + (or vice versa) and see what it does
man this is realy frustraiting.
No matter where I start or stop the fader when pressing the learn key it's still working backwards. Up is down & down is up ![]() |
odd. have you looked at what it actually is transmitting?
Yes. I have a program called midi-ox that tells me the HEX, DEC and SysEx values of each move. I just don't know where to put these values in cubase
so what is the fader sending? does a value increase or decrease when you move it up/
Here's exactly what it is sending....
Fader 1 from unity to full open then back to unity TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 0000AC65 1 -- AF 00 37 16 C -1 Key Aftertouch 0000AC66 1 -- AF 40 4B 16 E 4 Key Aftertouch 0000AC91 1 -- AF 00 21 16 C -1 Key Aftertouch 0000AC91 1 -- AF 40 35 16 E 4 Key Aftertouch 0000ACB5 1 -- AF 00 05 16 C -1 Key Aftertouch 0000ACB5 1 -- AF 40 27 16 E 4 Key Aftertouch 0000ACDF 1 -- AF 00 43 16 C -1 Key Aftertouch 0000ACDF 1 -- AF 40 24 16 E 4 Key Aftertouch 0000AD08 1 -- AF 00 1D 16 C -1 Key Aftertouch 0000AD08 1 -- AF 40 22 16 E 4 Key Aftertouch 0000AD31 1 -- AF 00 5A 16 C -1 Key Aftertouch 0000AD32 1 -- AF 40 1F 16 E 4 Key Aftertouch 0000AD5F 1 -- AF 00 58 16 C -1 Key Aftertouch 0000AD60 1 -- AF 40 1D 16 E 4 Key Aftertouch 0000AD85 1 -- AF 00 33 16 C -1 Key Aftertouch 0000AD85 1 -- AF 40 1D 16 E 4 Key Aftertouch 0000ADAD 1 -- AF 00 1B 16 C -1 Key Aftertouch 0000ADAD 1 -- AF 40 1D 16 E 4 Key Aftertouch 0000ADDD 1 -- AF 00 5A 16 C -1 Key Aftertouch 0000ADDD 1 -- AF 40 1C 16 E 4 Key Aftertouch 0000ADFF 1 -- AF 00 42 16 C -1 Key Aftertouch 0000AE00 1 -- AF 40 1C 16 E 4 Key Aftertouch 0000AE29 1 -- AF 00 11 16 C -1 Key Aftertouch 0000AE29 1 -- AF 40 1C 16 E 4 Key Aftertouch 0000AE58 1 -- AF 00 38 16 C -1 Key Aftertouch 0000AE58 1 -- AF 40 1B 16 E 4 Key Aftertouch 0000AE7D 1 -- AF 00 07 16 C -1 Key Aftertouch 0000AE7D 1 -- AF 40 1B 16 E 4 Key Aftertouch 0000AEAA 1 -- AF 00 2E 16 C -1 Key Aftertouch 0000AEAB 1 -- AF 40 1A 16 E 4 Key Aftertouch 0000AED1 1 -- AF 00 49 16 C -1 Key Aftertouch 0000AED1 1 -- AF 40 19 16 E 4 Key Aftertouch 0000AEFE 1 -- AF 00 3F 16 C -1 Key Aftertouch 0000AEFE 1 -- AF 40 18 16 E 4 Key Aftertouch 0000AF23 1 -- AF 00 4E 16 C -1 Key Aftertouch 0000AF24 1 -- AF 40 17 16 E 4 Key Aftertouch 0000AF4F 1 -- AF 00 50 16 C -1 Key Aftertouch 0000AF4F 1 -- AF 40 16 16 E 4 Key Aftertouch 0000AF74 1 -- AF 00 5F 16 C -1 Key Aftertouch 0000AF74 1 -- AF 40 15 16 E 4 Key Aftertouch 0000AF9F 1 -- AF 00 55 16 C -1 Key Aftertouch 0000AF9F 1 -- AF 40 14 16 E 4 Key Aftertouch 0000AFC9 1 -- AF 00 00 16 C -1 Key Aftertouch 0000AFC9 1 -- AF 40 14 16 E 4 Key Aftertouch 0000AFF1 1 -- AF 00 45 16 C -1 Key Aftertouch 0000AFF2 1 -- AF 40 13 16 E 4 Key Aftertouch 0000B01A 1 -- AF 00 22 16 C -1 Key Aftertouch 0000B01B 1 -- AF 40 13 16 E 4 Key Aftertouch 0000B04A 1 -- AF 00 59 16 C -1 Key Aftertouch 0000B04A 1 -- AF 40 12 16 E 4 Key Aftertouch 0000B06E 1 -- AF 00 36 16 C -1 Key Aftertouch 0000B06E 1 -- AF 40 12 16 E 4 Key Aftertouch 0000B098 1 -- AF 00 13 16 C -1 Key Aftertouch 0000B098 1 -- AF 40 12 16 E 4 Key Aftertouch 0000B0C0 1 -- AF 00 4F 16 C -1 Key Aftertouch 0000B0C1 1 -- AF 40 11 16 E 4 Key Aftertouch 0000B0EB 1 -- AF 00 1E 16 C -1 Key Aftertouch 0000B0EB 1 -- AF 40 11 16 E 4 Key Aftertouch 0000B119 1 -- AF 00 51 16 C -1 Key Aftertouch 0000B119 1 -- AF 40 10 16 E 4 Key Aftertouch 0000B13E 1 -- AF 00 2A 16 C -1 Key Aftertouch 0000B13E 1 -- AF 40 10 16 E 4 Key Aftertouch 0000B165 1 -- AF 00 5D 16 C -1 Key Aftertouch 0000B166 1 -- AF 40 0F 16 E 4 Key Aftertouch 0000B197 1 -- AF 00 23 16 C -1 Key Aftertouch 0000B197 1 -- AF 40 0F 16 E 4 Key Aftertouch 0000B1B9 1 -- AF 00 50 16 C -1 Key Aftertouch 0000B1B9 1 -- AF 40 0E 16 E 4 Key Aftertouch 0000B1E2 1 -- AF 00 2E 16 C -1 Key Aftertouch 0000B1E2 1 -- AF 40 0E 16 E 4 Key Aftertouch 0000B20F 1 -- AF 00 5C 16 C -1 Key Aftertouch 0000B20F 1 -- AF 40 0D 16 E 4 Key Aftertouch 0000B237 1 -- AF 00 2B 16 C -1 Key Aftertouch 0000B237 1 -- AF 40 0D 16 E 4 Key Aftertouch 0000B25D 1 -- AF 00 5E 16 C -1 Key Aftertouch 0000B264 1 -- AF 40 0C 16 E 4 Key Aftertouch 0000B28B 1 -- AF 00 06 16 C -1 Key Aftertouch 0000B28B 1 -- AF 40 0C 16 E 4 Key Aftertouch 0000B2B7 1 -- AF 00 4E 16 C -1 Key Aftertouch 0000B2B7 1 -- AF 40 0A 16 E 4 Key Aftertouch 0000B2DD 1 -- AF 00 2D 16 C -1 Key Aftertouch 0000B2DE 1 -- AF 40 09 16 E 4 Key Aftertouch 0000B308 1 -- AF 00 34 16 C -1 Key Aftertouch 0000B309 1 -- AF 40 08 16 E 4 Key Aftertouch 0000B32D 1 -- AF 00 49 16 C -1 Key Aftertouch 0000B32E 1 -- AF 40 07 16 E 4 Key Aftertouch 0000B358 1 -- AF 00 58 16 C -1 Key Aftertouch 0000B358 1 -- AF 40 06 16 E 4 Key Aftertouch 0000B383 1 -- AF 00 02 16 C -1 Key Aftertouch 0000B383 1 -- AF 40 06 16 E 4 Key Aftertouch 0000B3AB 1 -- AF 00 17 16 C -1 Key Aftertouch 0000B3AB 1 -- AF 40 05 16 E 4 Key Aftertouch 0000B3D3 1 -- AF 00 46 16 C -1 Key Aftertouch 0000B3D4 1 -- AF 40 04 16 E 4 Key Aftertouch 0000B403 1 -- AF 00 16 16 C -1 Key Aftertouch 0000B403 1 -- AF 40 04 16 E 4 Key Aftertouch 0000B427 1 -- AF 00 43 16 C -1 Key Aftertouch 0000B428 1 -- AF 40 03 16 E 4 Key Aftertouch 0000B452 1 -- AF 00 19 16 C -1 Key Aftertouch 0000B452 1 -- AF 40 03 16 E 4 Key Aftertouch 0000B47A 1 -- AF 00 53 16 C -1 Key Aftertouch 0000B47A 1 -- AF 40 02 16 E 4 Key Aftertouch 0000B4A3 1 -- AF 00 29 16 C -1 Key Aftertouch 0000B4A4 1 -- AF 40 02 16 E 4 Key Aftertouch 0000B4D2 1 -- AF 00 3F 16 C -1 Key Aftertouch 0000B4D3 1 -- AF 40 01 16 E 4 Key Aftertouch 0000B4F8 1 -- AF 00 0E 16 C -1 Key Aftertouch 0000B4F8 1 -- AF 40 01 16 E 4 Key Aftertouch 0000B51F 1 -- AF 00 42 16 C -1 Key Aftertouch 0000B51F 1 -- AF 40 00 16 E 4 Key Aftertouch 0000B549 1 -- AF 00 12 16 C -1 Key Aftertouch 0000B549 1 -- AF 40 00 16 E 4 Key Aftertouch 0000B572 1 -- AF 00 00 16 C -1 Key Aftertouch 0000B573 1 -- AF 40 00 16 E 4 Key Aftertouch 0000BBC7 1 -- AF 00 2A 16 C -1 Key Aftertouch 0000BBC7 1 -- AF 40 00 16 E 4 Key Aftertouch 0000BBF2 1 -- AF 00 02 16 C -1 Key Aftertouch 0000BBF3 1 -- AF 40 01 16 E 4 Key Aftertouch 0000BC18 1 -- AF 00 39 16 C -1 Key Aftertouch 0000BC19 1 -- AF 40 01 16 E 4 Key Aftertouch 0000BC47 1 -- AF 00 1D 16 C -1 Key Aftertouch 0000BC48 1 -- AF 40 02 16 E 4 Key Aftertouch 0000BC6F 1 -- AF 00 07 16 C -1 Key Aftertouch 0000BC70 1 -- AF 40 03 16 E 4 Key Aftertouch 0000BC93 1 -- AF 00 50 16 C -1 Key Aftertouch 0000BC94 1 -- AF 40 03 16 E 4 Key Aftertouch 0000BCC4 1 -- AF 00 46 16 C -1 Key Aftertouch 0000BCC5 1 -- AF 40 04 16 E 4 Key Aftertouch 0000BCEA 1 -- AF 00 1F 16 C -1 Key Aftertouch 0000BCEB 1 -- AF 40 05 16 E 4 Key Aftertouch 0000BD17 1 -- AF 00 11 16 C -1 Key Aftertouch 0000BD17 1 -- AF 40 06 16 E 4 Key Aftertouch 0000BD3E 1 -- AF 00 03 16 C -1 Key Aftertouch 0000BD3F 1 -- AF 40 07 16 E 4 Key Aftertouch 0000BD67 1 -- AF 00 5E 16 C -1 Key Aftertouch 0000BD68 1 -- AF 40 07 16 E 4 Key Aftertouch 0000BD92 1 -- AF 00 16 16 C -1 Key Aftertouch 0000BD93 1 -- AF 40 09 16 E 4 Key Aftertouch 0000BDBA 1 -- AF 00 45 16 C -1 Key Aftertouch 0000BDBB 1 -- AF 40 0A 16 E 4 Key Aftertouch 0000BDE5 1 -- AF 00 37 16 C -1 Key Aftertouch 0000BDE5 1 -- AF 40 0C 16 E 4 Key Aftertouch 0000BE0A 1 -- AF 00 35 16 C -1 Key Aftertouch 0000BE0B 1 -- AF 40 0D 16 E 4 Key Aftertouch 0000BE36 1 -- AF 00 2B 16 C -1 Key Aftertouch 0000BE37 1 -- AF 40 0E 16 E 4 Key Aftertouch 0000BE5F 1 -- AF 00 16 16 C -1 Key Aftertouch 0000BE5F 1 -- AF 40 0F 16 E 4 Key Aftertouch 0000BE87 1 -- AF 00 1C 16 C -1 Key Aftertouch 0000BE88 1 -- AF 40 10 16 E 4 Key Aftertouch 0000BEB2 1 -- AF 00 15 16 C -1 Key Aftertouch 0000BEB2 1 -- AF 40 11 16 E 4 Key Aftertouch 0000BEDA 1 -- AF 00 05 16 C -1 Key Aftertouch 0000BEDB 1 -- AF 40 12 16 E 4 Key Aftertouch 0000BF05 1 -- AF 00 51 16 C -1 Key Aftertouch 0000BF06 1 -- AF 40 12 16 E 4 Key Aftertouch 0000BF31 1 -- AF 00 2F 16 C -1 Key Aftertouch 0000BF32 1 -- AF 40 13 16 E 4 Key Aftertouch 0000BF55 1 -- AF 00 0C 16 C -1 Key Aftertouch 0000BF55 1 -- AF 40 14 16 E 4 Key Aftertouch 0000BF7F 1 -- AF 00 53 16 C -1 Key Aftertouch 0000BF80 1 -- AF 40 15 16 E 4 Key Aftertouch 0000BFA8 1 -- AF 00 1D 16 C -1 Key Aftertouch 0000BFAB 1 -- AF 40 17 16 E 4 Key Aftertouch 0000BFD1 1 -- AF 00 4C 16 C -1 Key Aftertouch 0000BFD2 1 -- AF 40 18 16 E 4 Key Aftertouch 0000C000 1 -- AF 00 0A 16 C -1 Key Aftertouch 0000C000 1 -- AF 40 1A 16 E 4 Key Aftertouch 0000C027 1 -- AF 00 5F 16 C -1 Key Aftertouch 0000C027 1 -- AF 40 1A 16 E 4 Key Aftertouch 0000C04C 1 -- AF 00 50 16 C -1 Key Aftertouch 0000C04D 1 -- AF 40 1B 16 E 4 Key Aftertouch 0000C07D 1 -- AF 00 42 16 C -1 Key Aftertouch 0000C07E 1 -- AF 40 1C 16 E 4 Key Aftertouch 0000C09F 1 -- AF 00 0F 16 C -1 Key Aftertouch 0000C0A0 1 -- AF 40 1D 16 E 4 Key Aftertouch 0000C0C9 1 -- AF 00 4C 16 C -1 Key Aftertouch 0000C0C9 1 -- AF 40 1D 16 E 4 Key Aftertouch 0000C0F7 1 -- AF 00 2B 16 C -1 Key Aftertouch 0000C0F8 1 -- AF 40 1F 16 E 4 Key Aftertouch 0000C120 1 -- AF 00 21 16 C -1 Key Aftertouch 0000C121 1 -- AF 40 21 16 E 4 Key Aftertouch 0000C14A 1 -- AF 00 47 16 C -1 Key Aftertouch 0000C14A 1 -- AF 40 23 16 E 4 Key Aftertouch 0000C172 1 -- AF 00 3E 16 C -1 Key Aftertouch 0000C172 1 -- AF 40 25 16 E 4 Key Aftertouch 0000C19E 1 -- AF 00 34 16 C -1 Key Aftertouch 0000C19E 1 -- AF 40 27 16 E 4 Key Aftertouch 0000C1C3 1 -- AF 00 58 16 C -1 Key Aftertouch 0000C1C4 1 -- AF 40 30 16 E 4 Key Aftertouch 0000C1EF 1 -- AF 00 42 16 C -1 Key Aftertouch 0000C1EF 1 -- AF 40 42 16 E 4 Key Aftertouch 0000C214 1 -- AF 00 00 16 C -1 Key Aftertouch 0000C215 1 -- AF 40 75 16 E 4 Key Aftertouch Cannel 1 mute on then off 0000C87C 1 -- BF 74 20 16 --- Control Change 0000D07A 1 -- BF 75 20 16 --- Control Change <edit> too big for 1 post |
#12
Fader 2 Unity to full open then back to unity
0000D81C 1 -- AF 01 37 16 C#-1 Key Aftertouch 0000D81C 1 -- AF 41 4B 16 F 4 Key Aftertouch 0000D847 1 -- AF 01 58 16 C#-1 Key Aftertouch 0000D847 1 -- AF 41 30 16 F 4 Key Aftertouch 0000D870 1 -- AF 01 43 16 C#-1 Key Aftertouch 0000D870 1 -- AF 41 24 16 F 4 Key Aftertouch 0000D898 1 -- AF 01 5A 16 C#-1 Key Aftertouch 0000D898 1 -- AF 41 1F 16 F 4 Key Aftertouch 0000D8C2 1 -- AF 01 0F 16 C#-1 Key Aftertouch 0000D8C3 1 -- AF 41 1D 16 F 4 Key Aftertouch 0000D8EB 1 -- AF 01 05 16 C#-1 Key Aftertouch 0000D8EB 1 -- AF 41 1C 16 F 4 Key Aftertouch 0000D915 1 -- AF 01 47 16 C#-1 Key Aftertouch 0000D916 1 -- AF 41 1A 16 F 4 Key Aftertouch 0000D941 1 -- AF 01 4C 16 C#-1 Key Aftertouch 0000D942 1 -- AF 41 18 16 F 4 Key Aftertouch 0000D965 1 -- AF 01 14 16 C#-1 Key Aftertouch 0000D965 1 -- AF 41 16 16 F 4 Key Aftertouch 0000D990 1 -- AF 01 45 16 C#-1 Key Aftertouch 0000D990 1 -- AF 41 13 16 F 4 Key Aftertouch 0000D9B8 1 -- AF 01 3F 16 C#-1 Key Aftertouch 0000D9BC 1 -- AF 41 12 16 F 4 Key Aftertouch 0000D9E2 1 -- AF 01 41 16 C#-1 Key Aftertouch 0000D9E2 1 -- AF 41 11 16 F 4 Key Aftertouch 0000DA10 1 -- AF 01 2E 16 C#-1 Key Aftertouch 0000DA10 1 -- AF 41 10 16 F 4 Key Aftertouch 0000DA38 1 -- AF 01 1B 16 C#-1 Key Aftertouch 0000DA39 1 -- AF 41 0F 16 F 4 Key Aftertouch 0000DA5D 1 -- AF 01 29 16 C#-1 Key Aftertouch 0000DA5E 1 -- AF 41 0E 16 F 4 Key Aftertouch 0000DA8E 1 -- AF 01 54 16 C#-1 Key Aftertouch 0000DA8E 1 -- AF 41 0C 16 F 4 Key Aftertouch 0000DAB0 1 -- AF 01 31 16 C#-1 Key Aftertouch 0000DAB0 1 -- AF 41 0A 16 F 4 Key Aftertouch 0000DADA 1 -- AF 01 5E 16 C#-1 Key Aftertouch 0000DADB 1 -- AF 41 07 16 F 4 Key Aftertouch 0000DB09 1 -- AF 01 27 16 C#-1 Key Aftertouch 0000DB09 1 -- AF 41 05 16 F 4 Key Aftertouch 0000DB31 1 -- AF 01 2B 16 C#-1 Key Aftertouch 0000DB31 1 -- AF 41 03 16 F 4 Key Aftertouch 0000DB5B 1 -- AF 01 1B 16 C#-1 Key Aftertouch 0000DB5C 1 -- AF 41 01 16 F 4 Key Aftertouch 0000DB82 1 -- AF 01 00 16 C#-1 Key Aftertouch 0000DB83 1 -- AF 41 00 16 F 4 Key Aftertouch 0000E38C 1 -- AF 01 2A 16 C#-1 Key Aftertouch 0000E38C 1 -- AF 41 00 16 F 4 Key Aftertouch 0000E3B2 1 -- AF 01 33 16 C#-1 Key Aftertouch 0000E3B3 1 -- AF 41 01 16 F 4 Key Aftertouch 0000E3E0 1 -- AF 01 53 16 C#-1 Key Aftertouch 0000E3E0 1 -- AF 41 02 16 F 4 Key Aftertouch 0000E406 1 -- AF 01 04 16 C#-1 Key Aftertouch 0000E406 1 -- AF 41 04 16 F 4 Key Aftertouch 0000E433 1 -- AF 01 2F 16 C#-1 Key Aftertouch 0000E433 1 -- AF 41 05 16 F 4 Key Aftertouch 0000E45E 1 -- AF 01 03 16 C#-1 Key Aftertouch 0000E45E 1 -- AF 41 07 16 F 4 Key Aftertouch 0000E482 1 -- AF 01 34 16 C#-1 Key Aftertouch 0000E483 1 -- AF 41 08 16 F 4 Key Aftertouch 0000E4AC 1 -- AF 01 31 16 C#-1 Key Aftertouch 0000E4AD 1 -- AF 41 0A 16 F 4 Key Aftertouch 0000E4D7 1 -- AF 01 5E 16 C#-1 Key Aftertouch 0000E4D8 1 -- AF 41 0C 16 F 4 Key Aftertouch 0000E4FF 1 -- AF 01 0C 16 C#-1 Key Aftertouch 0000E500 1 -- AF 41 0E 16 F 4 Key Aftertouch 0000E527 1 -- AF 01 5D 16 C#-1 Key Aftertouch 0000E528 1 -- AF 41 0E 16 F 4 Key Aftertouch 0000E551 1 -- AF 01 18 16 C#-1 Key Aftertouch 0000E552 1 -- AF 41 10 16 F 4 Key Aftertouch 0000E57B 1 -- AF 01 27 16 C#-1 Key Aftertouch 0000E57C 1 -- AF 41 11 16 F 4 Key Aftertouch 0000E5A6 1 -- AF 01 32 16 C#-1 Key Aftertouch 0000E5A7 1 -- AF 41 12 16 F 4 Key Aftertouch 0000E5CF 1 -- AF 01 2F 16 C#-1 Key Aftertouch 0000E5CF 1 -- AF 41 13 16 F 4 Key Aftertouch 0000E5F5 1 -- AF 01 0A 16 C#-1 Key Aftertouch 0000E5F5 1 -- AF 41 15 16 F 4 Key Aftertouch 0000E627 1 -- AF 01 02 16 C#-1 Key Aftertouch 0000E627 1 -- AF 41 18 16 F 4 Key Aftertouch 0000E64C 1 -- AF 01 55 16 C#-1 Key Aftertouch 0000E64C 1 -- AF 41 19 16 F 4 Key Aftertouch 0000E673 1 -- AF 01 07 16 C#-1 Key Aftertouch 0000E674 1 -- AF 41 1B 16 F 4 Key Aftertouch 0000E69D 1 -- AF 01 05 16 C#-1 Key Aftertouch 0000E69D 1 -- AF 41 1C 16 F 4 Key Aftertouch 0000E6C7 1 -- AF 01 5A 16 C#-1 Key Aftertouch 0000E6C7 1 -- AF 41 1C 16 F 4 Key Aftertouch 0000E6EC 1 -- AF 01 33 16 C#-1 Key Aftertouch 0000E6ED 1 -- AF 41 1D 16 F 4 Key Aftertouch 0000E71A 1 -- AF 01 30 16 C#-1 Key Aftertouch 0000E71B 1 -- AF 41 1E 16 F 4 Key Aftertouch 0000E743 1 -- AF 01 56 16 C#-1 Key Aftertouch 0000E744 1 -- AF 41 20 16 F 4 Key Aftertouch 0000E76B 1 -- AF 01 1D 16 C#-1 Key Aftertouch 0000E76B 1 -- AF 41 22 16 F 4 Key Aftertouch 0000E798 1 -- AF 01 43 16 C#-1 Key Aftertouch 0000E799 1 -- AF 41 24 16 F 4 Key Aftertouch 0000E7BE 1 -- AF 01 0A 16 C#-1 Key Aftertouch 0000E7BE 1 -- AF 41 26 16 F 4 Key Aftertouch 0000E7EA 1 -- AF 01 2C 16 C#-1 Key Aftertouch 0000E7EA 1 -- AF 41 2C 16 F 4 Key Aftertouch 0000E813 1 -- AF 01 4D 16 C#-1 Key Aftertouch 0000E813 1 -- AF 41 39 16 F 4 Key Aftertouch 0000E83B 1 -- AF 01 42 16 C#-1 Key Aftertouch 0000E83B 1 -- AF 41 42 16 F 4 Key Aftertouch 0000E865 1 -- AF 01 37 16 C#-1 Key Aftertouch 0000E865 1 -- AF 41 4B 16 F 4 Key Aftertouch 0000E88E 1 -- AF 01 00 16 C#-1 Key Aftertouch 0000E88E 1 -- AF 41 75 16 F 4 Key Aftertouch Channel 2 mute on, then off 0000EE18 1 -- BF 74 22 16 --- Control Change 0000F311 1 -- BF 75 22 16 --- Control Change |
#13
Fader 16, unity, full open & back to unity
TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT 0002CDA2 1 -- AF 0F 00 16 Eb 0 Key Aftertouch 0002CDA3 1 -- AF 4F 75 16 G 5 Key Aftertouch 0002CDCD 1 -- AF 0F 42 16 Eb 0 Key Aftertouch 0002CDCD 1 -- AF 4F 42 16 G 5 Key Aftertouch 0002CDF2 1 -- AF 0F 21 16 Eb 0 Key Aftertouch 0002CDF2 1 -- AF 4F 35 16 G 5 Key Aftertouch 0002CE1C 1 -- AF 0F 00 16 Eb 0 Key Aftertouch 0002CE1C 1 -- AF 4F 28 16 G 5 Key Aftertouch 0002CE46 1 -- AF 0F 0A 16 Eb 0 Key Aftertouch 0002CE46 1 -- AF 4F 26 16 G 5 Key Aftertouch 0002CE6F 1 -- AF 0F 43 16 Eb 0 Key Aftertouch 0002CE6F 1 -- AF 4F 24 16 G 5 Key Aftertouch 0002CE96 1 -- AF 0F 4C 16 Eb 0 Key Aftertouch 0002CE96 1 -- AF 4F 22 16 G 5 Key Aftertouch 0002CEBF 1 -- AF 0F 56 16 Eb 0 Key Aftertouch 0002CEC0 1 -- AF 4F 20 16 G 5 Key Aftertouch 0002CEE9 1 -- AF 0F 5F 16 Eb 0 Key Aftertouch 0002CEEB 1 -- AF 4F 1E 16 G 5 Key Aftertouch 0002CF14 1 -- AF 0F 4C 16 Eb 0 Key Aftertouch 0002CF14 1 -- AF 4F 1D 16 G 5 Key Aftertouch 0002CF3D 1 -- AF 0F 1B 16 Eb 0 Key Aftertouch 0002CF3D 1 -- AF 4F 1D 16 G 5 Key Aftertouch 0002CF62 1 -- AF 0F 4E 16 Eb 0 Key Aftertouch 0002CF62 1 -- AF 4F 1C 16 G 5 Key Aftertouch 0002CF95 1 -- AF 0F 11 16 Eb 0 Key Aftertouch 0002CF95 1 -- AF 4F 1C 16 G 5 Key Aftertouch 0002CFB9 1 -- AF 0F 44 16 Eb 0 Key Aftertouch 0002CFBA 1 -- AF 4F 1B 16 G 5 Key Aftertouch 0002CFE0 1 -- AF 0F 07 16 Eb 0 Key Aftertouch 0002CFE0 1 -- AF 4F 1B 16 G 5 Key Aftertouch 0002D007 1 -- AF 0F 2E 16 Eb 0 Key Aftertouch 0002D007 1 -- AF 4F 1A 16 G 5 Key Aftertouch 0002D033 1 -- AF 0F 3D 16 Eb 0 Key Aftertouch 0002D033 1 -- AF 4F 19 16 G 5 Key Aftertouch 0002D058 1 -- AF 0F 4C 16 Eb 0 Key Aftertouch 0002D059 1 -- AF 4F 18 16 G 5 Key Aftertouch 0002D087 1 -- AF 0F 1D 16 Eb 0 Key Aftertouch 0002D087 1 -- AF 4F 17 16 G 5 Key Aftertouch 0002D0AD 1 -- AF 0F 07 16 Eb 0 Key Aftertouch 0002D0AE 1 -- AF 4F 16 16 G 5 Key Aftertouch 0002D0D2 1 -- AF 0F 62 16 Eb 0 Key Aftertouch 0002D0D3 1 -- AF 4F 14 16 G 5 Key Aftertouch 0002D103 1 -- AF 0F 52 16 Eb 0 Key Aftertouch 0002D104 1 -- AF 4F 13 16 G 5 Key Aftertouch 0002D125 1 -- AF 0F 33 16 Eb 0 Key Aftertouch 0002D126 1 -- AF 4F 13 16 G 5 Key Aftertouch 0002D14E 1 -- AF 0F 0C 16 Eb 0 Key Aftertouch 0002D14F 1 -- AF 4F 13 16 G 5 Key Aftertouch 0002D17C 1 -- AF 0F 3F 16 Eb 0 Key Aftertouch 0002D17D 1 -- AF 4F 12 16 G 5 Key Aftertouch 0002D1A2 1 -- AF 0F 13 16 Eb 0 Key Aftertouch 0002D1A3 1 -- AF 4F 12 16 G 5 Key Aftertouch 0002D1C8 1 -- AF 0F 46 16 Eb 0 Key Aftertouch 0002D1C9 1 -- AF 4F 11 16 G 5 Key Aftertouch 0002D1F6 1 -- AF 0F 0C 16 Eb 0 Key Aftertouch 0002D1F6 1 -- AF 4F 11 16 G 5 Key Aftertouch 0002D222 1 -- AF 0F 37 16 Eb 0 Key Aftertouch 0002D223 1 -- AF 4F 10 16 G 5 Key Aftertouch 0002D248 1 -- AF 0F 54 16 Eb 0 Key Aftertouch 0002D248 1 -- AF 4F 0F 16 G 5 Key Aftertouch 0002D270 1 -- AF 0F 12 16 Eb 0 Key Aftertouch 0002D273 1 -- AF 4F 0F 16 G 5 Key Aftertouch 0002D298 1 -- AF 0F 44 16 Eb 0 Key Aftertouch 0002D299 1 -- AF 4F 0E 16 G 5 Key Aftertouch 0002D2C3 1 -- AF 0F 0C 16 Eb 0 Key Aftertouch 0002D2C3 1 -- AF 4F 0E 16 G 5 Key Aftertouch 0002D2EC 1 -- AF 0F 35 16 Eb 0 Key Aftertouch 0002D2ED 1 -- AF 4F 0D 16 G 5 Key Aftertouch 0002D315 1 -- AF 0F 54 16 Eb 0 Key Aftertouch 0002D316 1 -- AF 4F 0C 16 G 5 Key Aftertouch 0002D33B 1 -- AF 0F 06 16 Eb 0 Key Aftertouch 0002D33B 1 -- AF 4F 0C 16 G 5 Key Aftertouch 0002D366 1 -- AF 0F 31 16 Eb 0 Key Aftertouch 0002D367 1 -- AF 4F 0A 16 G 5 Key Aftertouch 0002D38F 1 -- AF 0F 16 16 Eb 0 Key Aftertouch 0002D390 1 -- AF 4F 09 16 G 5 Key Aftertouch 0002D3B7 1 -- AF 0F 14 16 Eb 0 Key Aftertouch 0002D3B8 1 -- AF 4F 08 16 G 5 Key Aftertouch 0002D3E0 1 -- AF 0F 13 16 Eb 0 Key Aftertouch 0002D3E0 1 -- AF 4F 07 16 G 5 Key Aftertouch 0002D409 1 -- AF 0F 02 16 Eb 0 Key Aftertouch 0002D40A 1 -- AF 4F 06 16 G 5 Key Aftertouch 0002D434 1 -- AF 0F 58 16 Eb 0 Key Aftertouch 0002D435 1 -- AF 4F 04 16 G 5 Key Aftertouch 0002D460 1 -- AF 0F 62 16 Eb 0 Key Aftertouch 0002D460 1 -- AF 4F 03 16 G 5 Key Aftertouch 0002D483 1 -- AF 0F 1F 16 Eb 0 Key Aftertouch 0002D483 1 -- AF 4F 03 16 G 5 Key Aftertouch 0002D4AE 1 -- AF 0F 2F 16 Eb 0 Key Aftertouch 0002D4AE 1 -- AF 4F 02 16 G 5 Key Aftertouch 0002D4D6 1 -- AF 0F 45 16 Eb 0 Key Aftertouch 0002D4D6 1 -- AF 4F 01 16 G 5 Key Aftertouch 0002D4FF 1 -- AF 0F 60 16 Eb 0 Key Aftertouch 0002D500 1 -- AF 4F 00 16 G 5 Key Aftertouch 0002D52D 1 -- AF 0F 12 16 Eb 0 Key Aftertouch 0002D52E 1 -- AF 4F 00 16 G 5 Key Aftertouch 0002D553 1 -- AF 0F 00 16 Eb 0 Key Aftertouch 0002D553 1 -- AF 4F 00 16 G 5 Key Aftertouch 0002D99D 1 -- AF 0F 12 16 Eb 0 Key Aftertouch 0002D99D 1 -- AF 4F 00 16 G 5 Key Aftertouch 0002D9C5 1 -- AF 0F 48 16 Eb 0 Key Aftertouch 0002D9C5 1 -- AF 4F 00 16 G 5 Key Aftertouch 0002D9F4 1 -- AF 0F 1B 16 Eb 0 Key Aftertouch 0002D9F4 1 -- AF 4F 01 16 G 5 Key Aftertouch 0002DA16 1 -- AF 0F 57 16 Eb 0 Key Aftertouch 0002DA17 1 -- AF 4F 01 16 G 5 Key Aftertouch 0002DA42 1 -- AF 0F 41 16 Eb 0 Key Aftertouch 0002DA42 1 -- AF 4F 02 16 G 5 Key Aftertouch 0002DA6B 1 -- AF 0F 1F 16 Eb 0 Key Aftertouch 0002DA6B 1 -- AF 4F 03 16 G 5 Key Aftertouch 0002DA90 1 -- AF 0F 56 16 Eb 0 Key Aftertouch 0002DA91 1 -- AF 4F 03 16 G 5 Key Aftertouch 0002DAC1 1 -- AF 0F 40 16 Eb 0 Key Aftertouch 0002DAC2 1 -- AF 4F 04 16 G 5 Key Aftertouch 0002DAE7 1 -- AF 0F 1F 16 Eb 0 Key Aftertouch 0002DAE8 1 -- AF 4F 05 16 G 5 Key Aftertouch 0002DB0E 1 -- AF 0F 09 16 Eb 0 Key Aftertouch 0002DB0F 1 -- AF 4F 06 16 G 5 Key Aftertouch 0002DB34 1 -- AF 0F 5F 16 Eb 0 Key Aftertouch 0002DB35 1 -- AF 4F 06 16 G 5 Key Aftertouch 0002DB60 1 -- AF 0F 61 16 Eb 0 Key Aftertouch 0002DB61 1 -- AF 4F 07 16 G 5 Key Aftertouch 0002DB87 1 -- AF 0F 4B 16 Eb 0 Key Aftertouch 0002DB87 1 -- AF 4F 08 16 G 5 Key Aftertouch 0002DBB5 1 -- AF 0F 5C 16 Eb 0 Key Aftertouch 0002DBB5 1 -- AF 4F 09 16 G 5 Key Aftertouch 0002DBDC 1 -- AF 0F 08 16 Eb 0 Key Aftertouch 0002DBDC 1 -- AF 4F 0B 16 G 5 Key Aftertouch 0002DC01 1 -- AF 0F 10 16 Eb 0 Key Aftertouch 0002DC01 1 -- AF 4F 0C 16 G 5 Key Aftertouch 0002DC32 1 -- AF 0F 0E 16 Eb 0 Key Aftertouch 0002DC32 1 -- AF 4F 0D 16 G 5 Key Aftertouch 0002DC53 1 -- AF 0F 3F 16 Eb 0 Key Aftertouch 0002DC54 1 -- AF 4F 0D 16 G 5 Key Aftertouch 0002DC7D 1 -- AF 0F 16 16 Eb 0 Key Aftertouch 0002DC7D 1 -- AF 4F 0E 16 G 5 Key Aftertouch 0002DCAA 1 -- AF 0F 46 16 Eb 0 Key Aftertouch 0002DCAB 1 -- AF 4F 0E 16 G 5 Key Aftertouch 0002DCD1 1 -- AF 0F 12 16 Eb 0 Key Aftertouch 0002DCD1 1 -- AF 4F 0F 16 G 5 Key Aftertouch 0002DCFE 1 -- AF 0F 50 16 Eb 0 Key Aftertouch 0002DCFE 1 -- AF 4F 0F 16 G 5 Key Aftertouch 0002DD25 1 -- AF 0F 32 16 Eb 0 Key Aftertouch 0002DD25 1 -- AF 4F 10 16 G 5 Key Aftertouch 0002DD51 1 -- AF 0F 08 16 Eb 0 Key Aftertouch 0002DD51 1 -- AF 4F 11 16 G 5 Key Aftertouch 0002DD77 1 -- AF 0F 46 16 Eb 0 Key Aftertouch 0002DD77 1 -- AF 4F 11 16 G 5 Key Aftertouch 0002DDA2 1 -- AF 0F 1B 16 Eb 0 Key Aftertouch 0002DDA2 1 -- AF 4F 12 16 G 5 Key Aftertouch 0002DDC7 1 -- AF 0F 48 16 Eb 0 Key Aftertouch 0002DDC7 1 -- AF 4F 12 16 G 5 Key Aftertouch 0002DDF1 1 -- AF 0F 14 16 Eb 0 Key Aftertouch 0002DDF1 1 -- AF 4F 13 16 G 5 Key Aftertouch 0002DE1B 1 -- AF 0F 41 16 Eb 0 Key Aftertouch 0002DE1C 1 -- AF 4F 13 16 G 5 Key Aftertouch 0002DE44 1 -- AF 0F 0C 16 Eb 0 Key Aftertouch 0002DE44 1 -- AF 4F 14 16 G 5 Key Aftertouch 0002DE6B 1 -- AF 0F 0A 16 Eb 0 Key Aftertouch 0002DE6B 1 -- AF 4F 15 16 G 5 Key Aftertouch 0002DE95 1 -- AF 0F 5F 16 Eb 0 Key Aftertouch 0002DE95 1 -- AF 4F 15 16 G 5 Key Aftertouch 0002DEBD 1 -- AF 0F 50 16 Eb 0 Key Aftertouch 0002DEBE 1 -- AF 4F 16 16 G 5 Key Aftertouch 0002DEE9 1 -- AF 0F 4E 16 Eb 0 Key Aftertouch 0002DEEA 1 -- AF 4F 17 16 G 5 Key Aftertouch 0002DF10 1 -- AF 0F 33 16 Eb 0 Key Aftertouch 0002DF11 1 -- AF 4F 18 16 G 5 Key Aftertouch 0002DF37 1 -- AF 0F 0C 16 Eb 0 Key Aftertouch 0002DF38 1 -- AF 4F 19 16 G 5 Key Aftertouch 0002DF69 1 -- AF 0F 49 16 Eb 0 Key Aftertouch 0002DF6A 1 -- AF 4F 19 16 G 5 Key Aftertouch 0002DF8F 1 -- AF 0F 16 16 Eb 0 Key Aftertouch 0002DF8F 1 -- AF 4F 1A 16 G 5 Key Aftertouch 0002DFB2 1 -- AF 0F 3B 16 Eb 0 Key Aftertouch 0002DFB3 1 -- AF 4F 1A 16 G 5 Key Aftertouch 0002DFDC 1 -- AF 0F 07 16 Eb 0 Key Aftertouch 0002DFDC 1 -- AF 4F 1B 16 G 5 Key Aftertouch 0002E005 1 -- AF 0F 38 16 Eb 0 Key Aftertouch 0002E006 1 -- AF 4F 1B 16 G 5 Key Aftertouch 0002E02E 1 -- AF 0F 5D 16 Eb 0 Key Aftertouch 0002E02F 1 -- AF 4F 1B 16 G 5 Key Aftertouch 0002E05C 1 -- AF 0F 1D 16 Eb 0 Key Aftertouch 0002E05D 1 -- AF 4F 1C 16 G 5 Key Aftertouch 0002E081 1 -- AF 0F 42 16 Eb 0 Key Aftertouch 0002E082 1 -- AF 4F 1C 16 G 5 Key Aftertouch 0002E0A8 1 -- AF 0F 5A 16 Eb 0 Key Aftertouch 0002E0A9 1 -- AF 4F 1C 16 G 5 Key Aftertouch 0002E0D9 1 -- AF 0F 0F 16 Eb 0 Key Aftertouch 0002E0DA 1 -- AF 4F 1D 16 G 5 Key Aftertouch 0002E120 1 -- AF 0F 33 16 Eb 0 Key Aftertouch 0002E120 1 -- AF 4F 1D 16 G 5 Key Aftertouch 0002E14E 1 -- AF 0F 3F 16 Eb 0 Key Aftertouch 0002E14F 1 -- AF 4F 1D 16 G 5 Key Aftertouch 0002E177 1 -- AF 0F 58 16 Eb 0 Key Aftertouch 0002E177 1 -- AF 4F 1D 16 G 5 Key Aftertouch 0002E19E 1 -- AF 0F 00 16 Eb 0 Key Aftertouch 0002E19E 1 -- AF 4F 1E 16 G 5 Key Aftertouch 0002E1CB 1 -- AF 0F 5F 16 Eb 0 Key Aftertouch 0002E1CB 1 -- AF 4F 1E 16 G 5 Key Aftertouch 0002E1F1 1 -- AF 0F 5A 16 Eb 0 Key Aftertouch 0002E1F1 1 -- AF 4F 1F 16 G 5 Key Aftertouch 0002E21D 1 -- AF 0F 56 16 Eb 0 Key Aftertouch 0002E21D 1 -- AF 4F 20 16 G 5 Key Aftertouch 0002E244 1 -- AF 0F 1D 16 Eb 0 Key Aftertouch 0002E245 1 -- AF 4F 22 16 G 5 Key Aftertouch 0002E26D 1 -- AF 0F 18 16 Eb 0 Key Aftertouch 0002E26D 1 -- AF 4F 23 16 G 5 Key Aftertouch 0002E298 1 -- AF 0F 13 16 Eb 0 Key Aftertouch 0002E298 1 -- AF 4F 24 16 G 5 Key Aftertouch 0002E2BE 1 -- AF 0F 3E 16 Eb 0 Key Aftertouch 0002E2C0 1 -- AF 4F 25 16 G 5 Key Aftertouch 0002E2EA 1 -- AF 0F 39 16 Eb 0 Key Aftertouch 0002E2EA 1 -- AF 4F 26 16 G 5 Key Aftertouch 0002E30F 1 -- AF 0F 34 16 Eb 0 Key Aftertouch 0002E310 1 -- AF 4F 27 16 G 5 Key Aftertouch 0002E33B 1 -- AF 0F 58 16 Eb 0 Key Aftertouch 0002E33B 1 -- AF 4F 30 16 G 5 Key Aftertouch 0002E360 1 -- AF 0F 4D 16 Eb 0 Key Aftertouch 0002E360 1 -- AF 4F 39 16 G 5 Key Aftertouch 0002E38A 1 -- AF 0F 0B 16 Eb 0 Key Aftertouch 0002E38A 1 -- AF 4F 47 16 G 5 Key Aftertouch 0002E3B4 1 -- AF 0F 00 16 Eb 0 Key Aftertouch 0002E3B4 1 -- AF 4F 75 16 G 5 Key Aftertouch channel 16 mute, on then off 0002E984 1 -- BF 74 3E 16 --- Control Change 0002EE2A 1 -- BF 75 3E 16 --- Control Change |
#14
Function keys (transport control) from 7 to 1. Note F5 gives 2 command lines when pressed (this is the play key)
0002FB7B 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 7F 7F 06 44 02 00 08 F7 000305FE 1 -- F0 Buffer: 6 Bytes System Exclusive SYSX: F0 7F 7F 06 01 F7 000308E1 1 -- F0 Buffer: 6 Bytes System Exclusive SYSX: F0 7F 7F 06 02 F7 00030934 1 -- F0 Buffer: 8 Bytes System Exclusive SYSX: F0 7F 7F 06 4B 01 02 F7 00030E41 1 -- F0 Buffer: 6 Bytes System Exclusive SYSX: F0 7F 7F 06 04 F7 000311AC 1 -- F0 Buffer: 6 Bytes System Exclusive SYSX: F0 7F 7F 06 05 F7 0003141A 1 -- F0 Buffer: 13 Bytes System Exclusive SYSX: F0 7F 7F 06 40 06 01 60 00 00 20 00 F7 00031832 1 -- F0 Buffer: 9 Bytes System Exclusive SYSX: F0 7F 7F 06 4C 02 08 01 F7 LR Main fader from unity to full open and back to unity 000341DC 1 -- BF 0C 0B 16 --- Control Change 000341DC 1 -- BF 0D 47 16 --- Control Change 00034206 1 -- BF 0C 4D 16 --- Control Change 00034206 1 -- BF 0D 39 16 --- Control Change 00034231 1 -- BF 0C 2C 16 --- Control Change 00034231 1 -- BF 0D 2C 16 --- Control Change 00034254 1 -- BF 0C 05 16 --- Control Change 00034254 1 -- BF 0D 27 16 --- Control Change 0003427F 1 -- BF 0C 0E 16 --- Control Change 0003427F 1 -- BF 0D 25 16 --- Control Change 000342A6 1 -- BF 0C 4C 16 --- Control Change 000342A7 1 -- BF 0D 22 16 --- Control Change 000342CC 1 -- BF 0C 56 16 --- Control Change 000342CD 1 -- BF 0D 20 16 --- Control Change 000342FD 1 -- BF 0C 00 16 --- Control Change 000342FE 1 -- BF 0D 1E 16 --- Control Change 00034323 1 -- BF 0C 33 16 --- Control Change 00034323 1 -- BF 0D 1D 16 --- Control Change 00034349 1 -- BF 0C 5A 16 --- Control Change 0003434A 1 -- BF 0D 1C 16 --- Control Change 00034370 1 -- BF 0C 1D 16 --- Control Change 00034370 1 -- BF 0D 1C 16 --- Control Change 0003439B 1 -- BF 0C 38 16 --- Control Change 0003439B 1 -- BF 0D 1B 16 --- Control Change 000343C1 1 -- BF 0C 47 16 --- Control Change 000343C2 1 -- BF 0D 1A 16 --- Control Change 000343EF 1 -- BF 0C 25 16 --- Control Change 000343EF 1 -- BF 0D 19 16 --- Control Change 00034416 1 -- BF 0C 0F 16 --- Control Change 00034416 1 -- BF 0D 18 16 --- Control Change 0003443B 1 -- BF 0C 05 16 --- Control Change 0003443B 1 -- BF 0D 17 16 --- Control Change 0003446B 1 -- BF 0C 53 16 --- Control Change 0003446C 1 -- BF 0D 15 16 --- Control Change 0003448D 1 -- BF 0C 31 16 --- Control Change 0003448E 1 -- BF 0D 14 16 --- Control Change 000344B3 1 -- BF 0C 45 16 --- Control Change 000344B3 1 -- BF 0D 13 16 --- Control Change 000344E1 1 -- BF 0C 0C 16 --- Control Change 000344E1 1 -- BF 0D 13 16 --- Control Change 0003450A 1 -- BF 0C 2D 16 --- Control Change 0003450A 1 -- BF 0D 12 16 --- Control Change 00034530 1 -- BF 0C 4F 16 --- Control Change 00034531 1 -- BF 0D 11 16 --- Control Change 0003455D 1 -- BF 0C 40 16 --- Control Change 0003455E 1 -- BF 0D 10 16 --- Control Change 0003457E 1 -- BF 0C 47 16 --- Control Change 00034583 1 -- BF 0D 0F 16 --- Control Change 000345AF 1 -- BF 0C 30 16 --- Control Change 000345B0 1 -- BF 0D 0E 16 --- Control Change 000345D6 1 -- BF 0C 5E 16 --- Control Change 000345D7 1 -- BF 0D 0C 16 --- Control Change 000345FF 1 -- BF 0C 4E 16 --- Control Change 000345FF 1 -- BF 0D 0A 16 --- Control Change 00034628 1 -- BF 0C 34 16 --- Control Change 00034628 1 -- BF 0D 08 16 --- Control Change 0003464F 1 -- BF 0C 5F 16 --- Control Change 00034650 1 -- BF 0D 06 16 --- Control Change 0003467B 1 -- BF 0C 27 16 --- Control Change 0003467C 1 -- BF 0D 05 16 --- Control Change 000346A0 1 -- BF 0C 10 16 --- Control Change 000346A1 1 -- BF 0D 04 16 --- Control Change 000346CB 1 -- BF 0C 5F 16 --- Control Change 000346CC 1 -- BF 0D 02 16 --- Control Change 000346F1 1 -- BF 0C 57 16 --- Control Change 000346F1 1 -- BF 0D 01 16 --- Control Change 0003471B 1 -- BF 0C 5A 16 --- Control Change 0003471B 1 -- BF 0D 00 16 --- Control Change 00034744 1 -- BF 0C 00 16 --- Control Change 00034744 1 -- BF 0D 00 16 --- Control Change 00034C4D 1 -- BF 0C 4E 16 --- Control Change 00034C4E 1 -- BF 0D 00 16 --- Control Change 00034C72 1 -- BF 0C 33 16 --- Control Change 00034C73 1 -- BF 0D 01 16 --- Control Change 00034C99 1 -- BF 0C 1D 16 --- Control Change 00034C9A 1 -- BF 0D 02 16 --- Control Change 00034CC2 1 -- BF 0C 07 16 --- Control Change 00034CC3 1 -- BF 0D 03 16 --- Control Change 00034CEB 1 -- BF 0C 16 16 --- Control Change 00034CEB 1 -- BF 0D 04 16 --- Control Change 00034D11 1 -- BF 0C 27 16 --- Control Change 00034D12 1 -- BF 0D 05 16 --- Control Change 00034D3F 1 -- BF 0C 58 16 --- Control Change 00034D3F 1 -- BF 0D 06 16 --- Control Change 00034D65 1 -- BF 0C 0D 16 --- Control Change 00034D66 1 -- BF 0D 08 16 --- Control Change 00034D8A 1 -- BF 0C 2D 16 --- Control Change 00034D8A 1 -- BF 0D 09 16 --- Control Change 00034DBB 1 -- BF 0C 39 16 --- Control Change 00034DBC 1 -- BF 0D 0B 16 --- Control Change 00034DDD 1 -- BF 0C 04 16 --- Control Change 00034DDD 1 -- BF 0D 0D 16 --- Control Change 00034E05 1 -- BF 0C 02 16 --- Control Change 00034E06 1 -- BF 0D 0E 16 --- Control Change 00034E31 1 -- BF 0C 5D 16 --- Control Change 00034E32 1 -- BF 0D 0E 16 --- Control Change 00034E59 1 -- BF 0C 02 16 --- Control Change 00034E59 1 -- BF 0D 10 16 --- Control Change 00034E7F 1 -- BF 0C 5A 16 --- Control Change 00034E80 1 -- BF 0D 10 16 --- Control Change 00034EAC 1 -- BF 0C 4A 16 --- Control Change 00034EAD 1 -- BF 0D 11 16 --- Control Change 00034ED1 1 -- BF 0C 20 16 --- Control Change 00034ED2 1 -- BF 0D 12 16 --- Control Change 00034EFE 1 -- BF 0C 03 16 --- Control Change 00034EFF 1 -- BF 0D 13 16 --- Control Change 00034F25 1 -- BF 0C 38 16 --- Control Change 00034F26 1 -- BF 0D 13 16 --- Control Change 00034F4E 1 -- BF 0C 25 16 --- Control Change 00034F4E 1 -- BF 0D 14 16 --- Control Change 00034F77 1 -- BF 0C 5F 16 --- Control Change 00034F78 1 -- BF 0D 15 16 --- Control Change 00034F9E 1 -- BF 0C 29 16 --- Control Change 00034F9F 1 -- BF 0D 17 16 --- Control Change 00034FCA 1 -- BF 0C 0C 16 --- Control Change 00034FCA 1 -- BF 0D 19 16 --- Control Change 00034FEF 1 -- BF 0C 2E 16 --- Control Change 00034FF0 1 -- BF 0D 1A 16 --- Control Change 0003501A 1 -- BF 0C 2C 16 --- Control Change 0003501A 1 -- BF 0D 1B 16 --- Control Change 0003503F 1 -- BF 0C 11 16 --- Control Change 00035040 1 -- BF 0D 1C 16 --- Control Change 00035069 1 -- BF 0C 5A 16 --- Control Change 0003506A 1 -- BF 0D 1C 16 --- Control Change 00035093 1 -- BF 0C 3F 16 --- Control Change 00035093 1 -- BF 0D 1D 16 --- Control Change 000350BB 1 -- BF 0C 5F 16 --- Control Change 000350BB 1 -- BF 0D 1E 16 --- Control Change 000350E1 1 -- BF 0C 56 16 --- Control Change 000350E1 1 -- BF 0D 20 16 --- Control Change 0003510C 1 -- BF 0C 4C 16 --- Control Change 0003510C 1 -- BF 0D 22 16 --- Control Change 00035134 1 -- BF 0C 13 16 --- Control Change 00035134 1 -- BF 0D 24 16 --- Control Change 0003515A 1 -- BF 0C 0A 16 --- Control Change 0003515B 1 -- BF 0D 26 16 --- Control Change 00035185 1 -- BF 0C 05 16 --- Control Change 00035185 1 -- BF 0D 27 16 --- Control Change 000351AD 1 -- BF 0C 00 16 --- Control Change 000351AD 1 -- BF 0D 28 16 --- Control Change 000351D4 1 -- BF 0C 21 16 --- Control Change 000351D5 1 -- BF 0D 35 16 --- Control Change 000351FD 1 -- BF 0C 16 16 --- Control Change 000351FD 1 -- BF 0D 3E 16 --- Control Change 00035226 1 -- BF 0C 0B 16 --- Control Change 00035226 1 -- BF 0D 47 16 --- Control Change 00035251 1 -- BF 0C 00 16 --- Control Change 00035251 1 -- BF 0D 75 16 --- Control Change I hope someone can make sense of that and tell me how to translate it into something cubase understands. Thanks for taking the time, Alex |
#15
I found this on an old BB from years ago by doing a search......
You can but it isn't easy. You can get detailed documentation from A&H, I did about 5 years ago when I wrote a Mixer Map for Cubase (*this was before I saw the light*). I don't have a GS3V anymore but would be interested to see how you go, everything is SysEx so complex mixes can get VERY busy, if they had've used CC's it would've been awesome to edit automation with HyperEdit. As someone else mentioned the fader resolution is 14-bit but to overcome this there is two ways of controlling the VCA's ... there's Basic mode (which uses a single 7-bit integer where 127 = unity, and 0 = -117db attenuation). There's also an enhanced mode which uses one 7-bit integer to access the absolute position of the fader: unity->-117db, it also uses a second 7-bit integer to provide the fraction with a range of 0 -> -0.99db. The specification is quite extensive, and a creative (crazy ??) envrionment guru could build quite an amazingly comprehensive interface to the desk. calling all crazy enviroment gurus ![]() |
#16
looking at those values and reading the note it is pretty clear that the way they increased the resolution is it do a quasi MSB/LSB deal with each step being addressed as a note/aftertouch value or 2 cc channels which is why cubase is having a hard time interpreting it. See if you can get it to work in basic (7 bit) mode, here is the problem:
this is your main fader stream 000341DC 1 -- BF 0C 0B 16 --- Control Change 000341DC 1 -- BF 0D 47 16 --- Control Change OC and OD (data1) identify 2 separate CC's (12 & 13) incrementing at non-sequential values i.e. 12: 11, 77, 44, 39, 37, 34 etc 13: 71, 57, 44, 5, 14 etc so what is happening here is what the blurb you posted said it would, the first bit on ch12 is decrementing normally and the second bit on ch14 is just a representation of a fraction so it can jump around (probably based on how fast you move the fader) so what it is sending is a far cry from 0-127 like standard CC's and it is no surprise that cubase cannot interpret it correctly. In 7 bit mode you will have only 0-127 as possibilities and it should work correctly. The only work around I can think of with using the 14bit mode would be to write MAX patch to translate the 14 bit values into something more linear (not fun, HEX math makes my brain hurt). This type of thing is exactly why did gave up on trying to use MMC controls for cubase btw.
| Midi Controller Transport Controls | sbhntr | Newbies | 0 | 01-15-2008 15:10 |
| Can't Save Remote Transport Controls | justanotherjo | Cubase User Forum | 1 | 09-12-2006 14:51 |
| midi to key stroke program for transport controls? | VirtualSamana | Digital Recording & Computers | 0 | 11-13-2004 13:09 |
| Mixer MMC to control Cubase Transport? | LemonTree | Cubase User Forum | 2 | 11-10-2003 04:23 |
| Controling Cool Edit Pro's Transport Controls via Midi | iHateRegisteringAtSites | Cool Edit Pro / Adobe Audition Forum | 2 | 01-05-2001 05:27 |
