Tips for recording analog...
Lets make a thread with helpful recording tips for analog users. i just purchased a TASCAM 388 and Im trying to apply some of the things I learned with Pro Tools.
For one...In Pro Tools I always did a low cut with the WAVS EQ that really helped take the low frequency rumble out of my tracks and it made the mix sit a lot better. Can I do that with the 388 EQs? Do I just turn each one down a notch for this? Any help is appreciated. Thanks |
i just turn the low and its associated freq. knob all the way down on everything
except my bass tracks. (on my 388) |
Really? And you dont lose a lot of low end in your mix? What does the outside knob do in the EQ section?
Where is or was all this low rumble coming from?
What frequency range was it in? Does the new (old) recording medium have sufficient response at that range for the rumble to be a problem? My preferred medium (cassette) won't even reproduce the range where most of the flab lives. |
Those move (sweep) the peaking or shelving frequency.
Rickson, all of this (and much, much more) is covered in the 388 manual. It's a must read. You can download it here:
http://marjorie-plastille.com/ ------ |
Here's a difference between Pro Tools and the 388: in the digital domain, you want to stay the hell away from the ceiling, but on an analog tape machine, you might want to push the levels right up to saturation. Tape can start to break up in a nice musical way, while of course anything digital immediately sounds like utter hell when you cross the line.
Even if you don't push the levels to saturation, analog tape has a lot less SNR and headroom to burn (higher noise floor really), so you'll probably want to run hotter anyway. Not that I've done enough in the digital domain to say a whole lot about it. |
With the 388 (with noise reduction engaged), tape hiss is virtually non-existent and there is no benefit to 'pushing the meters' and may actually cause dbx encode / decode errors. You only want your signal peaks to briefly go into the red.
Yeah, I don't mean you should pin the dang things. It's just that in digital you never want to see red.
is it worth it to try to turn off the Dbx in the 388 for that tape saturation? Will it just be too noisy to get an effective recording like this?
#12
Yes, saturation fattens things up and strictly speaking produces noise and distortion, some of which can sound musical. Unlike in the digital domain, it's not an all or nothing proposition. You can push it a very little all the way up to way too much. I'd agree with leaving dbx on though. Tape saturation just occurred to me as one of the differences between analog and digital. And even if that's not what you're shooting for, I'd play a lot closer to the red in analog.
| Digital vs. Analog: Tell Us Something We Haven't Heard | Beck | Analog Only | 221 | 12-16-2006 23:23 |
| For all you old guys | guitarfreak12 | Recording Techniques | 52 | 10-24-2005 09:31 |
| Analog vs. Digital Need help.... | LTG | Analog Only | 32 | 09-16-2004 17:00 |
| Thread to discuss Digital Vs. Analog | Beck | Analog Only | 18 | 06-24-2004 03:29 |
| Vinyl - Is it Analog or Digital? | Rubo4 | Analog Only | 1 | 09-12-2001 17:01 |
