Old 02-26-2008
gac gac is offline
Newbie
gac is on a distinguished road
Akai GX-620 Tape Counter Doesn't work?
Hey all,
I'm new here and new to the world of tape machines, so bare with me.
I own an Akai GX-620, and recently discovered that the tape counter feature is not working. By not working, I mean it no longer counts. I resetted it to no avail. It just wont count for me, basically.
Perhaps I am missing something very obvious (and of course will be completely embarassed if so), but I am open to your ideas for how to correct this.
I thank you all in advance for your time,
GAC
Old 02-26-2008
hungovermorning hungovermorning is offline
Windmill machine.
hungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond reputehungovermorning has a reputation beyond repute
I had a direct drive Kind Akai for a while (I believe a GX-630), I believe the counter is the only thing that is a belt so you probably just need a counter belt.
Pat Boone's Farm is a band that loves obscure tube amps, electric 12 string guitars, and vinyl: http://www.myspace.com/patboonesfarm
Cavetone Records is our wonderful vinyl-only label. http://www.cavetone.com
Old 02-26-2008
Dr ZEE's Avatar
Dr ZEE Dr ZEE is offline
Anti-Pro Circles Insider
Dr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond reputeDr ZEE has a reputation beyond repute
IS THIS IT?
if, so, remove (or open, if it is "openable"?) the cover and see what's there, you may be able to see the counter mechanism. There should be a belt spining the counter's mechanism. See if it looks ok.
I am just guessing here. I don't really know.
/good luck
Dr ZEE
MZE | ZDL | DZW
Old 02-26-2008
Dr ZEE's Avatar
see attached image
my guess is that you need to remover these two screws to remove the cover, I may be wrong, it's just looks to me like this is it
/later
Dr ZEE
MZE | ZDL | DZW
Old 02-26-2008
gac gac is offline
Newbie
Hey guys,
I opened it up and it looks like you all were right.
The belt was just resting there inside, not attached to anything. I'd show you pictures but the board wont let me till I make 5 posts!
So here are the inevitable questions:
1. Do I need to get a new belt? If so, where can I order one for this model?
2. How the heck do I install it? I'm trying to figure out how the belt works in relation to the counter and I can't picture it.
Thanks to everyone for helping so far, hopefully you can give a few more pointers!
GAC
Old 02-26-2008
Dr ZEE's Avatar
so just make three more posts, say something you don't mean, that'll do
if the old belt is not broken, I don't think you need new one. It should be easy to place it back. I am not sure that it would be possible to do from the front. I've no clue. You may need to get there from the back of the deck.
post pictures when you can
/respects
Dr ZEE
MZE | ZDL | DZW
Old 02-26-2008
gac gac is offline
Newbie
LOL, well here is 4...
Well, this one has snapped. It looks like it is weathered and aged. So I am certain I will need a new one. Any online purchasing suggestions?
GAC
Old 02-26-2008
gac gac is offline
Newbie
and so on...
Old 02-26-2008
gac gac is offline
Newbie
Here's the defunct belt:
And the insides:
I'm not sure what you can gauge from that image, but I hope it'll do to see what I'm working with here.
GAC
Old 02-26-2008
Dr ZEE's Avatar
ok, I was trying to make something up so you get a general idea, so here it is,
commonly the counter mechanism has a larger wheel, and belt is going around it and then to "something else" , that's depending on the machine's design,
now, that "something else" you need to find/figure out by looking inside the machine, you may need to open the back and see from there
see attached chart.
Dr ZEE
MZE | ZDL | DZW
Old 02-26-2008
Dr ZEE's Avatar
so you need new belt.
where to buy? I don't know. eBay is the one place.
This belt is not critical for the deck performance. Any similar belt of the same loop-length should do the work.
See the picture,
so I see the "large wheel", but I don't see from that photo what can there be the "something else"
..."it" may be somewhere close behind the metal face-plate ..???
Dr ZEE
MZE | ZDL | DZW
  #12
Old 02-26-2008
Dr ZEE's Avatar
this looks like maybe what you need, but I don't know for sure
the seller calls it "meter belt", so I guess that's it (???), but it is for 620D, which is similar machine, but I have no clue if the counter has exact the same design as 620.
You can contact the seller and ask specific question.
Here's the link:
http://cgi.ebay.com/AKAI-GX-620-D-Re...299071QQihZ014
Dr ZEE
MZE | ZDL | DZW
  #13
Old 02-26-2008
Dr ZEE's Avatar
aha! Gotcha!
Hete it is: Click For Full Size Photo
from this page,
so, it looks like you'll have to remove the front face-panel to get there
see attached picture:
Dr ZEE
MZE | ZDL | DZW
  #14
Old 02-26-2008
Dr ZEE's Avatar
btw, from what I see there, in order to remove the face-plate, you'd first have to remove pinch-roller, both tape guide /tension arms, control knobs, maybe couple other things. It's all doable, but see for yourself first and decide if you feel ok doing all that.
good luck what ever you do.
do not force anything, take it easy
Dr ZEE
MZE | ZDL | DZW
  #15
Old 02-27-2008
gac gac is offline
Newbie
Dr Zee, you are the best! So many informative posts from you. Thank you.
I asked the ebay seller if it'll work as the tape counter belt, and I'll be buying it right away if so.
I can't thank you enough again for your help.
I like this board already!
GAC
  #16
Old 02-27-2008
gac gac is offline
Newbie
Oh yes, and I'll keep you posted on the progress of this. Hopefully I'll have it up and running soon.
GAC
  #17
Old 02-27-2008
Dr ZEE's Avatar
uh, cool
You've hit it on a nice sunny day.
The Earth is moving, so
Just hang around...
Tomorrow it may be hurricane, a flood or even worse:
Dr ZEE
MZE | ZDL | DZW
FS:New and Used 1" tape marshman Free Ads for Music / Recording Equipment 1 01-29-2008 16:19
the Basics fuquam Mixing / Mastering 26 02-26-2007 18:45
calibration/service places in Ohio? puttinitonwax Analog Only 6 03-23-2006 08:14
456 or GP-9? For 1/4" 1/2track mixdown / mastering? Dr ZEE Analog Only 27 06-14-2005 06:28
Copyright Mumbo Jumbo Cooperman Marketing Your Music / Publicity 18 07-19-2000 17:07
