Old 02-20-2008
tddrummer tddrummer is offline
tddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond reputetddrummer has a reputation beyond repute
Cakewalk Problem, Help!
I've been using cakewalk to record some small acoustic demos to get a feel of the program. After recording 2 simple songs something screwed up.
I set an arm for recording, and then I press record, then I get a sort of hissing and popping that wasnt there before (i previously had a nice clear recording). It even happens with no line in plugged up, but goes away when I turn the soundcard down.
I've done several things to solve the problem, and expected a simple solution, but I'm having difficulties. I've tried uninstalling, and re-installing the program=no solution, still have popping. It is so severe that the audio I record fluctuates up and down and really sounds horrible.
The problem also happens when I import a file into cakewalk, and it dosn't occur on my other software, so I dont think it's a soundcard problem.
Please someome help! I really like this program, and really want to use it in the future. Thanks
Old 02-21-2008
rayc's Avatar
rayc rayc is offline
L'ancien escargot
rayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond reputerayc has a reputation beyond repute
Which cakewalk program?
Cheers
rayC
soundclick, unearthed, mspace & utub
Old 02-21-2008
warble2's Avatar
warble2 warble2 is offline
Not an expert
warble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond reputewarble2 has a reputation beyond repute
As asked already, what Cakewalk program?
PC?
What operating system?
What soundcard?
Have you installed the latest drivers for the soundcard?
This is just to get started helping you.
Old 02-21-2008
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
Your recorded wav-files are still OK (if you play them in some other program than "cakewalk")?
Have you run the audio profiler lately?
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 02-21-2008
I'm pretty shure its cakewalk music creator 3 (im at school right now)..I use a PC (dell)..im not quite shure what an audio profiler is...but I have recorded audio on the "sound recorder" program that comes with the computer and the problem didnt happen, so I'm shure it cant be the sound card, can it?
Old 02-23-2008
acidrock's Avatar
acidrock acidrock is offline
Purge's arch nemesis
acidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond reputeacidrock has a reputation beyond repute
Could it possibly be a hardware problem?I would eliminate that possibility right off the bat.
Also check your input routing,are you getting sound,just hiss or both?
Old 02-25-2008
Both, I have cakewalk music creator 2 as well and it works fine so the problem is only on this one...definetly not hardware
Old 02-26-2008
moskus's Avatar
Check Tools -> Audio and look for the "Audio Profiler".
Old 03-03-2008
mine dosnt list audio profiler any other suggestions...i really want to fix this.
Old 03-06-2008
kgirl72's Avatar
kgirl72 kgirl72 is offline
Hiya
kgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond repute
You are probably using the asio drivers. In the second tab, find where you can switch to wdm mode. You'll have to close down the program I think. Then when it opens up, it will run the wave profiler. I am NOwhere near moskus et al on Sonar, but I know this will show the wave profiler, unless I'm a nutjob. But, also, I use Sonar PE 6.2 so I may be unfamiliar with your version of software.
What?!
Old 03-11-2008
moskus's Avatar
The problem is that it is not Sonar we are discussing, it's Music Creator.
For all I know it doesn't have a Audio Profiler (but I find it unlikely if it supports audio)...
Cakewalk timing problem, techno song doesn't groove BeyondMusic Cakewalk / Sonar Forum 1 02-04-2002 23:00
Problem w/ Fruity - Cakewalk sync synergy Cakewalk / Sonar Forum 0 11-18-2001 11:06
Cakewalk Problem Belvee Cakewalk / Sonar Forum 2 10-15-2001 11:33
Cakewalk & Midi Timepiece AV Usb Problem! timhle Cakewalk / Sonar Forum 1 03-30-2001 23:47
problem stretching audio in Cakewalk PA9 chuchosay Cakewalk / Sonar Forum 4 01-13-2001 07:25
