Old 02-04-2008
katmandoo katmandoo is offline
Newbie
katmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond reputekatmandoo has a reputation beyond repute
Mastering Tip...
Hi all as usual use this info as you like...or don't :P
For mastering songs all I do is run the final mixdown through the 30 band graphic eq on AA1.5 which; is set totally flat across the board and if my mix is a little high on the db side of things, i will bring the overall eq gain down to say -4. What this does is give the whole mix what it lacks...EG: if your mix is missing some mids they'll be added by the eq, and if your mix is treble-y it will bring it down some with the gain reduction. I find this way I get the punchiest recordings that aren't compressed to hell. if you mix with your master volume (alt+2) down at say -4 you don't need to compress the final mix or limit it and it keeps its punchiness. try it, you'll like it Mikey
A writer writes...always
Katmandoo
Old 02-04-2008
danny.guitar
Guest
Posts: n/a
Running a song through an EQ that's set to flat, and decreasing the master gain on the EQ is the same as just lowering the main volume. Unless, of course, the EQ is doing some sort of processing on it anyway (like Ozone's Analog filter).
I just don't see the point of doing that when you can just lower the volume.
Old 02-04-2008
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
I know enough to know that I don't know anything.
But I like jello.
Old 02-04-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Originally Posted by RAMI View Post
I like jello.
And I understood that.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 02-05-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Most people would use a parametric EQ when a mix needed EQ.
Most people would use a volume control to adjust the volume.
I'm just sayin'...
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 02-05-2008
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Stick to writing, preferably about things other then audio engineering.
Old 02-05-2008
Newbie
Hey Texroadkill...there's no need to be rude and ignorant..if you don't like reading how I do things then just move on...This is a forum for all not JUST for you and your smart ass comments.
Old 02-06-2008
elly-d's Avatar
elly-d elly-d is offline
Senior Member
elly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond reputeelly-d has a reputation beyond repute
can i just jump i here and try and save this thread before someone shouts 'FIGHT', i was actually looking for some mastering advice. i have just recorded a friend of mine onto 1/2 tape, he makes very delicate folk music. it sounds great on tape and even when i transfered it to cubase to master it. anyway i stuck it on cd and listened in the car and it became apparent that it needs some compression but as its so gentile i didn't want to ruin the feel. any ideas chaps?
Old 02-06-2008
RAMI's Avatar
www.ramirami.com
Originally Posted by elly-d View Post
i was actually looking for some mastering advice.?
Then I suggest you leave this thread immediately and don't ever mention a word of this to anyone.
Old 02-06-2008
All you can do is to do what the mix tells you to do. If compression is ruining the feel, there you go. If parallel compression is making it to dense, there you go.
What is it lacking? Do that.
Old 02-06-2008
Jouni Jouni is offline
1K Silver Member
Jouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond reputeJouni has a reputation beyond repute
Since we're into tips here;
I recently started, "for the last step" ..running the mix through graphic EQ followed by the "loud brickwall" of Ozone. On the same bus on Reaper.
that way, I can EQ, and listen the result after EQ and brickwall while doing this. ...adjust vthe sound while keeping it to max db. at the same time..
Anyone know any pros/cons or what can I mess up with that??
IMO, it's a nice way to add the final boost.
\m/ WAR OUT!! \m/
  #12
Old 02-06-2008
LemonTree's Avatar
LemonTree LemonTree is offline
Suck 'em and see!
LemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond reputeLemonTree has a reputation beyond repute
It's also at the best of times a good place for people to learn. Feeding people wrong ideas doesn't lead to better mixing, it leads to more new people being missinformed and passing that down to the next generation.
Maybe if this cycle keeps going there'll be enough missinformed people out there mixing badly enough to keep the pro studios in business.
Swings n round-a-bouts
.....now where did I put my pultec plug again.... sounds great in bypass mode when I pull the volume down on the 2 buss
Lemontree Studio
Not bitter, not twisted!
  #13
Old 02-06-2008
Farview's Avatar
There is nothing terribly wrong with putting the limiter on the main buss, but I wouldn't bother with the EQ.
How do you decide how much EQ you need to what frequency until you are done mixing? If you're still mixing and you need more high end, why don't you just add the high end to the tracks that need it, instead of adding it to the entire song?
And again, a graphic EQ is not really the correct tool for this job. I don't know of any mastering engineers (that actually know what they are doing) that use a graphic EQ for this purpose. A parametric EQ would be the right tool for this job.
Jay Walsh
  #14
Old 02-06-2008
Farview's Avatar
I do spend a good portion of my online time cleaning up after misinformed people. It gets tiring becasue the truth is generally less sexy than the superstitous garbage that people come up with. It becomes harder and harder to get noobs to believe the real posts.
Being that I own a pro studio, maybe I should stop trying so hard to help everyone out.
Jay Walsh
My Mastering Perspective Autist Mixing / Mastering 27 07-26-2005 09:22
Mastering guys... bennychico11 Mixing / Mastering 10 06-19-2005 23:13
'homestudio mastering' versus professional mastering Alexander Jamal Mixing / Mastering 15 05-05-2005 10:05
NEWBIES - THE ART OF MASTERING YOUR SONGS (an introduction) manning1 Newbies 46 04-29-2005 14:06
Its so hot I can't touch it ! Stan Williams Mixing / Mastering 14 11-09-2000 18:10
