Old 02-03-2008
Croww's Avatar
Croww Croww is offline
Newbie
Croww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond reputeCroww has a reputation beyond repute
EQ in the Signal Chain
I know there is no "set in stone" answer here, but my question relates to EQ settings in the signal chain. I'm doing a very basic home recording (mics, mixer, computer interface, DAW, and back out to stereo amp for monitoring). Should I used balanced EQ settings thoughout the chain (including my monitors) and only tweak EQ on the DAW for the mix. I just need sort of a reference point for EQ so I'm not misrepresenting the levels on the monitors. I hope this isn't too confusing, I just need a starting point, whatever that may be.
Thanks in advance,
Old 02-03-2008
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
You certainly shouldn't be EQ'ing your monitors... If you need to fix the room, fix the room (and you aren't going to do that with EQ, no matter what certain marketing departments tell you).
The starting point of *any* recording rig is a good monitoring chain - and that includes the room, of course.
Other than that, I'm not even sure what you're asking...
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 02-04-2008
Lo-Fi Mike's Avatar
Lo-Fi Mike Lo-Fi Mike is offline
Dedicated Member
Lo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond reputeLo-Fi Mike has a reputation beyond repute
if you eq your monitors you might change the way your mix sounds thru the monitors, but you are not changing you actually mix.
your outputs should run straight into your Powered monitors ,unless you are using passive monitors, or something like a central station, but i don't think your monitoring set-up is that complex.
InOtherWords listen to Massive Master.
as far as EQing in the mix here is something that might get you started.
http://www.drtmastering.com/faq2.htm#moretips
by the way your title was EQ in the Signal Chain.
that means applying eq to the signal as it it being tracked.
www.MikeUlloa.com
Old 02-04-2008
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
I record flat, and try a listen first, with everything flat.....then maybe try tweaks in eq during mixing...and each song is different, and each part needs different tweaks.
I won the internets......
Old 02-05-2008
Croww's Avatar
Newbie
Ok, thanks everyone for your input.
Old 02-05-2008
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
Says who? That's not how I read it.
Old 02-05-2008
Lo-Fi Mike's Avatar
Dedicated Member
ok
yeah, i went back and read his question again. i guess i was throw off by the eqing the monitors part that i forgot he was also taking about the inputs as well.
www.MikeUlloa.com
signal chain rightbrainnow Other Equipment and Reviews 6 05-23-2006 01:13
a question about my signal chain ekwon The Rack 3 03-18-2006 07:48
DSD Vs PCM from the Head Engineer at Phillips BigRay Other Equipment and Reviews 0 12-08-2005 09:00
Rack signal chain order gnash The Rack 5 11-27-2005 18:41
Signal Chain & Tascam 564 Digital Portastudio Stratocaster TASCAM User Forum 3 03-29-2003 16:24
