Old 01-31-2008
otobianki74 otobianki74 is offline
Junior Member
otobianki74 is on a distinguished road
a question regarding DI
last night I was recording a band and was having trouble routing the bass DI from the live room into my converters via my bay.
my question is two part I suppose (or two and a half).
1) the DI I was using is an avalon U5 instrument DI. if I was sending this signal from live room to tie lines to converter via my patch bay, am I supposed to go out mic level or line level?
2) for some reason, I couldn't get the signal working, so ended up going from the U5 into a great river mp-500nv mic pre. I think it was going out mic level into the great river. is that ok to go from instrument pre to mic pre? I would assume it would be better to use a passive DI box as opposed to the U5 (which I assume is active). correct me if I'm wrong.
however, with that being said, the signal sounded AWESOME!
thanks.
oto
Old 01-31-2008
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
If it sounded awesome then use it!
That sure sounds like a great signal path to me. My understanding is that the U5 is an active DI, not a preamp. Therefore, you used the equipment exactly the way it was designed to be used. DI into preamp.
Seriously, that must have sounded great.
http://www.misterpotts.com
Old 01-31-2008
Junior Member
right on, I hear ya.
but I just get confused as I most definitely have used it without a pre... maybe that's just the diff of line level vs. mic level.
oto
Old 01-31-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Your converters are looking for a line level signal.
So you Need to:
A. Come line out of the Avalon
OR
B. Come mic out of the Avalon and run it into a mic preamp to bring it up to line level
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 01-31-2008
oto
It's also possible that when you used it before without the GR, they were preamping it at the board.
an mp3 question Rusty K Marketing Your Music / Publicity 3 10-06-2007 18:57
question about mixer matt's bedroom Newbies 3 05-04-2006 05:24
Big Muff battery question! parkbirds Guitars and Basses 1 06-11-2003 10:47
Delta 1010 output question? henry_mullis Digital Recording & Computers 1 12-28-2002 11:12
stupid question about compression deathofamind Mixing / Mastering 10 12-13-2002 21:10
