Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 01-30-2008
skiz skiz is offline
Senior Member
skiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond reputeskiz has a reputation beyond repute
doubling up the kick?
hey guys
always struggle with my kick, getting it loud enough and cutting thru the mix
a friend of mine suggested i double up the kick (as in copy paste the kick track into a second track that will run simultaneously)
he said in the one track you can boost the lows and cut highs and in the second you can cut the lows and mids and get more attack in the 1k region. he said the doubling up will get the kick sounding louder too
just wondering if this is a valid method or a bad idea?
Old 01-30-2008
RAMI's Avatar
RAMI RAMI is offline
www.ramirami.com
RAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond reputeRAMI has a reputation beyond repute
Seems to me that doubling up the kik is exactly the same as simply making it louder. What I mean is, there's no difference between that and simply turning it up.
Old 01-30-2008
Senior Member
i duno, ive just tried it and it seems to make a huge difference
especially eqing the tracks differently to get lows on the one and the 1 - 1.5k attack region on the other
havnt been able to get it loud like this without it clipping till now
Old 01-30-2008
RAMI's Avatar
www.ramirami.com
I can't argue with you if you say it works for you.
But, if I just look at it on a logical level, I can't see how this would be any different than turning it up and boosting those frequencies you're talking about.
I'm not saying you're wrong, but I'd like someone to explain to me how it could be any different. The way I see it, doubling it up is simply giving us more of the same signal (=turning it up).
And I can't see how boosting of the high's on one and the low's on the other is any different than simply boosting them on one track.
I think it's something that SEEMS to make a huge difference simply because you doubled the volume of the track by copying it to another track.
But I'm might be 100% wrong.
Old 01-30-2008
Greg_L's Avatar
Greg_L Greg_L is offline
Gregois Le Bloodshit
Greg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond repute
I think Rami is right. Doubling the kick is just the same as making it louder unless you are adding additional processing to the copied track. You perceive that it's better because it is louder. You can achieve the same result with your one kick track by careful EQ'ing and probably turning the other tracks down. If you tracked everything correctly and you still can't hear your kick, then you probably have other tracks fighting with it for space.
Originally Posted by 60's guy View Post
Yeah! I'm a worthless fuck.
Originally Posted by The Ghost of FM View Post
Greg L is a real cool musician who offers great mixing advice in the mp3 clinic
Old 01-30-2008
msmales555's Avatar
msmales555 msmales555 is offline
Senior Member
msmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond reputemsmales555 has a reputation beyond repute
I think you are right as far as doubling the kick being the same as if you just turned it up in the mix. I think where there is a difference is that there is a limit to how much you can turn something up before your fader is maxed out and that tracks starts to clip or you can't turn it up anymore. creating a second track would allow you to add more volume without turning it up to the point that a track might clip or that you would run out of headroom.
Personally, I never really have much of a problem getting my kick to show up in the mix. I usually put a D112 about 3 inches form the batter head on the inside of the drum (18x22 tama birch drum) and between compression and reverb it gets big enough. As far as doubling it is concerned, I've actually put just a hint of delay on my kick before and that can make it jump out of the mix big time....however, that usually turns out to be way too much kick and I ended up taking it off or turning the delay down substantially.
Old 01-30-2008
Senior Member
heres what ive found, so it seems
if you have just 1 track and you boosting the lows and the midhighs, well the lows make the track clip more than the highs so i cant seem to boost the volume much as its clipping, so putting it into 2 tracks and cutting the lows and playing with the midhighs on the other lets me get the mid highs to come out more without it clipping and i can boost the volume and now im getting loads more attack which is def helping with the double kick parts
thats about all i can think of but it has helped
Old 01-30-2008
Senior Member
msmales, what delay are you using?
what settings do you use? never gotten a nice delay from the crap plugins that come with cubase
Old 01-30-2008
Greg_L's Avatar
Why are you boosting the lows so much? You're right about eating up all your headroom. It's a kick drum. It should be fat and low on its own. Maybe you need to play with your mic choice, mic placement, tune the drum properly, or all of the above.
Old 01-30-2008
Senior Member
im not boosting an insane amount, about 1.5 to 2 db boost in the 90 - 125 range
Old 01-30-2008
Greg_L's Avatar
Then I'm thinking you really probably only need to turn everything else down some. I mean, if you like doubling the kick, then by all means go for it. It's not necessary though. You can achieve what you want with one track. It just sounds like everything else is too loud. That's why it's called "mixing".
  #12
Old 01-30-2008
Yonce N Mild's Avatar
Yonce N Mild Yonce N Mild is offline
Voice of Sanity
Yonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond reputeYonce N Mild has a reputation beyond repute
That is exactly it. In theory it is just like adding volume but in practice it can be way more effective. If you don't believe me try it and take a listen, there is no way you get the same results just by turning up the kick and bringing the rest of the tracks down. Sure that would make the kick stand out but it wouldn't sound the same. Doubling up the kick makes it hit HARD especially if you eq both tracks a little differently. This is a pretty common technique in a lot of electronic generas.
  #13
Old 01-30-2008
RAMI's Avatar
www.ramirami.com
I still say it's the illusion of it hitting harder because it's louder. Just think, you're DOUBLING it up. Take your fader and double the output and I'm sure it will be the exact same thing.
If you're at a point where you have to turn your kik drum up so loud that there's no room on your fader, you need to go back and learn some basics about mixing...Because there is abslolutely NO GOOD REASON to ever be at that point.
  #14
Old 01-30-2008
VSpaceBoy's Avatar
VSpaceBoy VSpaceBoy is offline
..loading
VSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond reputeVSpaceBoy has a reputation beyond repute
I think the only doubling of a kick that's common is the New York style compressing of the kick OR a send to a channel with bass. Two copies of a kick for eq of volume is just a waster of CPU.
  #15
Old 01-30-2008
Greg_L's Avatar
Yall are confusing volume with sound quality. People naturally tend to think louder sounds better. Duplicating a kick track and EQ'ing it differently isn't really any different than having one track with the same EQ's applied. It's just louder. What you could do is to duplicate the kick, and then add some kind of compression to accentuate a certain characteristic you may want, and mix it in.
  #16
Old 01-30-2008
Voice of Sanity
don't knock it until you've tried it. Do it listen to it use your ears and then tell me you get the same effect from a single track.
Should you do it all the time? Of course not but sometimes it sounds awesome. Some songs just beg for it. You can get some pretty nasty sounding kicks by layering different kicks on top of each other. Don't tell me you guys have never heard of layering an 808 style kick over an acoustic kick to get some boom?
I would never do this on an acoustic kit for a standard rock or country type sound but it is very useful for metal/industrial/techno in certain situations.
That's what I'm talking about. I usually use eq on the individual tracks the bounce them to a single track and compress that track. I don't do my final mix with 2 separate kick tracks.
  #17
Old 01-30-2008
RAMI's Avatar
www.ramirami.com
Um...I'm right beside my equipment here. I tried it before my last post just to make sure. It's the exact same thing.
Copy your kik track, now you have 2 kik tracks. Play them both at the same volume.
Now, mute one and turn the other one up TWICE AS LOUD.
Exact same result.
  #18
Old 01-30-2008
Greg_L's Avatar
It's not the same. You're talking about mixing 2 totally different sounds as one. That's a whole different animal. We're talking about getting a good, usable kick sound from one mic, one kick drum, one track. It aint hard. If the original poster can't get a good kick sound on it's own, then I'm not gonna recommend getting all fancy with techno techniques.
  #19
Old 01-30-2008
RAMI's Avatar
www.ramirami.com
That's a completely different thing. We're talking about doubling the exact same track, not layering 2 different bass drums.
EDIT> Holy shit. Greg, we posted the same thing at the same time. Well, we started posting at the same time, probably, but it took me 6 minutes to post this. Weird.
  #20
Old 01-30-2008
TeyshaBlue's Avatar
TeyshaBlue TeyshaBlue is offline
Life is Sweet....
TeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond repute
You guys look alike too.
www.myspace.com/colabrei
I'm hung like a Naiant.
  #21
Old 01-30-2008
RAMI's Avatar
www.ramirami.com
I looked like me first.
  #22
Old 01-30-2008
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
So if you copy the same post and double it, does that make it twice as right?
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
  #23
Old 01-30-2008
TeyshaBlue's Avatar
Life is Sweet....
Holy crap! I'll be a genius by the end of the day.
  #24
Old 01-30-2008
RAMI's Avatar
www.ramirami.com
oooooooHHHHH..Now you're getting all esotoric on our asses.
  #25
Old 01-30-2008
Voice of Sanity
Exact same result.
You forgot the EQ.
Ah but if you eq them both differently then they begin to sound like 2 different kick drums. You can radically change the sound of a kick with eq can you not? For me it's a sound design thing more than a mixing thing though. Not that sound design isn't important to the final mix.
That would be awesome........ if I had a choice in mics a decent live room and more importantly an acoustic drum set. This is HOME recording after all. The most difficult thing to record properly in a home studio(IMHO) is drums because of the space requirements and the amount of noise. All my drums are either electronic, sample based or recorded somewhere else. Sometimes you need to get a little creative to work around the constraints of your setup.
I'm not sure what the original posters situation is but it may be similar. I'm also not sure what type of music he is making. This technique may be totally appropriate for his situation.
Sm57 For Recording Kick Drum ROCKNROLLRUSS Drums and Percussion 2 03-07-2004 08:27
wat it takes for kick.. mic or treatment. lbcstudios Drums and Percussion 11 02-27-2004 19:47
3mic drum set up. Centering the Kick? Booda Recording Techniques 1 02-01-2004 02:32
Kick drum vs. Bass Guitar Round 1 Scottgman Mixing / Mastering 11 01-29-2004 04:50
"Airy" Kick Drum moelar2 Recording Techniques 3 07-04-2001 20:14
