Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 01-23-2008
gdavi1 gdavi1 is offline
Senior Member
gdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond reputegdavi1 has a reputation beyond repute
First take ever at recorderman method
http://www.lightningmp3.com/live/84195_atsself.mp3
I used
mxl 992 LDC for left overhead
mxl 993 SDC for right overhead
Shure Sm57 on snare
Shure Sm57 on bass
and it all went in to a behringer 1222fx usb mixer
Honestly how did it come out?
Old 01-23-2008
Greg_L's Avatar
Greg_L Greg_L is offline
Gregois Le Bloodshit
Greg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond reputeGreg_L has a reputation beyond repute
Dude, that sounds kind of weird. I use the recorderman method and it works. You did something wrong. You got the kick leaning to the left and everything else centered and slightly right. No stereo image at all and it just sounds out of kilter. Before you go miking the kick and snare, learn to get a good and natural recording from just the overheads. The recorderman method, like any other stereo overhead setup, is very dependent on perfect mic positioning. Get the O/H's right first and then mix in some kick and snare. Take your time and get it right.
Originally Posted by 60's guy View Post
Yeah! I'm a worthless fuck.
Originally Posted by The Ghost of FM View Post
Greg L is a real cool musician who offers great mixing advice in the mp3 clinic
Old 01-23-2008
Almy's Avatar
Almy Almy is offline
Guitar Guy
Almy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond reputeAlmy has a reputation beyond repute
I hear some clipping as well, you might be recording too loud. I notice you are using a USB interface. Does that mean you aren't able to record the tracks individually?
One thing you can do to try and troubleshoot the stereo image. Keep the kick mic and the snare mic in the center. Pan one OH hard left and one OH hard right. It's not the only way to do it obviously, but try that and you'll start to see the difference in what a stereo image can do.
Old 01-24-2008
coolsoundman coolsoundman is offline
Senior Member
coolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond repute
I would agree with the others, no offense. get rid of the snare and kick drum. recorderman's method was used with two mic's. I guess add the other mics for more punch.
Old 01-25-2008
Herm's Avatar
Herm Herm is offline
1K Silver Member
Herm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond reputeHerm has a reputation beyond repute
It sounds Dull to me. plus it sounds like the kick is stuffed full of something like a blanket thats way to big. Back the mic off of the rear head some it needs some air. Also is that a 20 inch kick?
Old 01-26-2008
Senior Member
it was an 18inch kick
Old 01-26-2008
Rimshot's Avatar
Rimshot Rimshot is offline
Force of Nature
Rimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond reputeRimshot has a reputation beyond repute
As I've said many times.......
You really need a good kick mic. Especially when you are working with a small gig-sized kick drum. Sure you can do all sorts of things after recording to make it sound better, but the SM 57 is a great mic, but not so great on kick. I know a lot of people use it for that, but it never really sounds good because it doesn't focus on the deeper frequency. There's a reason that they make kick mics, and when you are using a skeleton rig for recording (as I do), everything in your chain must be tops. An inexpensive kick mic like the ATM Pro 25 wuold give you a vaste improvement in your sound.... and yeah as was mentioned, let your skins breathe a lot more and loose a lot of the padding. "Garbage in-garbage out"
"There is no expedient to which man will not resort to avoid the real labor of thinking."
-Sir Joshua Reynolds
Old 01-26-2008
Senior Member
the only reason the drums sound like garbage is because they have sat in my basement since i left for school
and i didnt feel like tuning them up
Old 01-26-2008
MidiPunk's Avatar
MidiPunk MidiPunk is offline
Drunken Heckler
MidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond reputeMidiPunk has a reputation beyond repute
Talking
Originally Posted by gdavi1 View Post
the only reason the drums sound like garbage is [...] i didnt feel like tuning them
Can I PLEASE have your permission to print and frame that?
Old 01-26-2008
Rimshot's Avatar
Force of Nature
......uh.
I'm speechless................................
Old 01-27-2008
Senior Member
hahaha dont worry the kit i brought with me to school gets tuned often and i replace its heads once a month
  #12
Old 01-28-2008
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
I think I want to print THAT one.
I almost never change the heads on my kit. Yep, Blasphemy. But then again - I see these guys with dented up tom heads and I'm thinking - "Dude, what in the heck are you doing? learn how to hit the drum!" I stated playing drums 30 years ago, and the only time I ever had a dented up drumhead is when I tried using a snare-side head on the top of a drum. (I was a kid and didn't know it was an extremely thin head.)
To me, putting new heads on every month is just throwing your money away.
The only time I personally would put new heads on, would be if I were actually going to record and release a CD.
I haven't actually broken a drumhead since I was 18 - and even then I punched through the drum when my guitarist told us he was quitting the band.(I was pissed because we had a label interested in us.)
Tim
  #13
Old 01-28-2008
Senior Member
i hit hard and they take a beating and i always notice a great increase in sound and feel when i replace them
  #14
Old 01-28-2008
Greg_L's Avatar
I hit pretty hard, too hard probably, and I don't wear out a head in a month. I play every day and gig about 2 or 3 times a month. I'm thinking you're either lying, unnnecessarily changing heads too often, or don't know how to tune the drums if you're getting that drastic of a change in sound from a head change after one month..
  #15
Old 01-28-2008
Senior Member
i think that i sit around all day playing and playing
and seeing that every goes
its so expensive for heads and blah blah blah
i replace my snare batter and my floor tom
two drum heads
not that much
  #16
Old 01-28-2008
Greg_L's Avatar
two drum heads
not that much
Well it certainly hasn't helped your drum sound. Get back to work.
  #17
Old 01-28-2008
Senior Member
thats not my drumset i recorded
its my drummer's for my sideproject
and lets jsut chill out theres no reason to argue over drums
Recorderman vs. Glyn Johns drum recording methods frott Recording Techniques 6 11-05-2007 18:37
Recorderman OVH Question pezking Newbies 0 07-09-2007 17:31
Acoustic Panels = Bass Traps? Gear_Junky Studio Building & Display 39 04-07-2006 13:50
Recorderman Method revamp Microphones 8 11-06-2004 19:41
recorderman method revamp Microphones 7 10-20-2004 05:13
