Hiss/buzz coming from DI out on bass.
My bassist's amp is buzzing when we record through the DI out on the back of his amp. I'm considering just mic'ing it up, but what I'm wondering is what is causing the buzz? Is it something with grounding?
I play lead guitar for a rock band called Indecision based out of Omaha, Nebraska. Check us out here |
Does it have a ground lift?
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
No ground lift available on his amp. I remember we were playing at a gig once and the guy plugged the amp into this power converter thingymabob and it fixed the problem? Something that had to do with that third pin on the power plug?
Probably a ground lift.
I've rarely heard any amp DI's that sound very good. Use an external DI and also mic the cab for best results.
Probably a ground loop. The amp is being grounded both by its own ground wire on the amp's power cable and by the ground connection of the amp's DI output, which is grounded through the preamp.
Get a 1:1 isolation transformer to run between the DI out and the preamp. |
| Muddy Bass using Sansamp driver | ardy77 | The Rack | 7 | 01-19-2006 06:02 |
| Q for Bass Players that use more than one bass | walkinbass | Guitars and Basses | 11 | 12-24-2004 20:59 |
| What bass and bass amp should I buy? | Mongoo | Guitars and Basses | 10 | 02-21-2003 21:49 |
| Spectral analyzers and mixing | Chris Fallen | Mixing / Mastering | 21 | 03-02-2002 19:02 |
