Old 01-21-2008
Albertm's Avatar
Albertm Albertm is offline
Dedicated Member
Albertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond reputeAlbertm has a reputation beyond repute
Can't rid of guitar distortion
Use Amplitube for a while now. Set to clean and still distorted. Strange. Tried again without Amplitube and plugged straight into Tascam 1082. Still distorted. So not Amplitube issue I think. Why would the signal distort? Volumes are under the red. I've been doing it this way for a couple of years, did I screw with setting somewhere. Also notice sound is delayed just a tad. Sure that is a buffer thing but wanted to rid of distortion first. Any ideas. thanks
Sonar 5 PE
Sonar 5 PE
Tascam 1082
AT3035
Old 01-21-2008
Myriad_Rocker's Avatar
Myriad_Rocker Myriad_Rocker is offline
Registered Text Offender
Myriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond repute
Have you checked the gain on the input you're using?
The delay is called latency. You'll have to mess with the buffer settings in Sonar to minimize this.
Myriad Rocker
My Web Design/Production Company: Myriad Productions
My Band: Black Leaf Clover
Originally Posted by theblackBay View Post
I’m currently "one" of the best song writers in the world
Old 01-21-2008
Albertm's Avatar
Dedicated Member
I have guitar straight into board. All levels in the green. So I think all gains are good.
Strange thing about buffer thing. All my midi stuff isn't delayed. Just analog guitar and vocal?
Sonar 5 PE
Tascam 1082
AT3035
Old 01-23-2008
deshead deshead is offline
hometracked.com
deshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond reputedeshead has a reputation beyond repute
Dead battery? Faulty cable? Loose wire in the guitar?
Do you have an amp you can try the guitar through?
Old 01-23-2008
psychedelicsoun's Avatar
psychedelicsoun psychedelicsoun is offline
Newbie
psychedelicsoun is on a distinguished road
turn your amp down HAHAHAHAHHAA
okay not that funny
Old 01-24-2008
Whale Bone Whale Bone is offline
Senior Member
Whale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond reputeWhale Bone has a reputation beyond repute
Have you tried monitoring your guitar with headphones directly on the Tascam 1082? Is the distortion there? If so, it would seem to point to the Tascam or the guitar. If not, it's something with your audio driver/config on the computer, or like suggested above, the trim on the Sonar channel you're using is way too high. Have you tried with a new, clean (not from a template) project in Sonar?
Have you tried a different channel on the Tascam? A different source, e.g. mic, CD audio, etc.? Are you using channel 8 with the guitar switch? If so, have you moved the switch recently, i.e. move the parts and possibly restablish a good connection between the contacts. Have you unplugged and replugged all the cables for the same reason?
If you're in channels 1 or 2, maybe the insert jacks have a bad connection. Try inserting/removing a 1/4" cable a few times.
I would assume that when you set a sample rate in Sonar, it changes it on the Tascam appropriately, but if not, do the sample rates agree? Do you have a clock option? Internal vs. external? My Echo Mia distorts if my dbx 386 isn't the clock source because I can't change the external gear in my case from the computer. Of course, here, my connection is S/PDIF, not Firewire or USB.
Push-pull output stages michaelq Guitars and Basses 3 12-28-2005 11:16
Distortion guitar sounds "cheap" recorded nxtnctno Recording Techniques 9 08-02-2005 09:29
Recording distortion guitar nxtnctno Recording Techniques 7 07-18-2005 14:07
Recording accoustic guitar: Getting rid of pick noise Chibi Nappa Recording Techniques 29 04-24-2003 08:41
Crisp distortion and clean guitar sounds??? jbenishek Guitars and Basses 12 02-20-2003 19:10
