wet or dry recording on vocals
Hi all,
I was wondering, if have a very dead room where I record vocals. In my headphone mix I add reverb. I use the direct outs to record in my DAW. I don't have reverb in my recorded sound. Would you recommend to add little reverb in the recording sound? regards Steve |
No. Why be stuck with something you might want to change later (and won't be able to)?
Do whatever you need to do to make yourself comfortable when you sing, like adding reverb, etc....But don't record the effects. You can always do that after. |
What he said....You'd hate to render a good take unusable by applying effects that don't sound the way you want.
I won the internets...... |
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music. __________________ "Do yourself a favour just shut up, read up then put up." --muttley600 |
Record the vocals dry and add the effects later. You don't want to lock yourself into a reverb from the start. Reverb is one of those things that you will want to play with a lot when mixing.
http://www.misterpotts.com |
how about recording both? I use a tc helicon vocal create pedal for most of my vocal effects. So I record a wet and a dry track. That way I can still adjust the amount of reverb in the mix. I can also just go with the dry track if I decide I don't like the effect I used.
Shaken, not stirred, and yes....always dry.
well
guess I'll record dry ![]() thanks for the input |
Another good suggestion is to record it dry...
And add the effects later. You know, so you're not stuck with them. |
The fact that no one understands you doesn't mean you're an artist... |
| Some newbie questions about recording vocals... | Xpred | Newbies | 14 | 12-10-2005 22:09 |
| Recording the vocals .... somewhere else | robca | Recording Techniques | 9 | 10-08-2005 07:06 |
| Hear everything while recording vocals? | cincy_kid | Digital Recording & Computers | 7 | 07-05-2004 08:43 |
| Recording vocals | 4Music | Recording Techniques | 2 | 01-21-2003 02:43 |
| Recording from playstation + add vocals? | SerenityThen | Recording Techniques | 2 | 02-26-2002 06:25 |
