Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 01-16-2008
Jammer429's Avatar
Jammer429 Jammer429 is offline
Getting Stuff Done
Jammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond reputeJammer429 has a reputation beyond repute
Can I use Drumagog for live shows
I have drumagog and I would like to use it as a live setting does anyone know how I can do that
Old 01-16-2008
donkeystyle donkeystyle is offline
This place sucks now. Bye
donkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond repute
your best bet would probably be to use triggers and also make sure to set the latency to 4ms or less. You should practice playing with it before the show so that you can learn how to play in a way to get the least amount of missed and misfired hits possible.
Drumagog takes some tweaking to get it to trigger correctly which isn't a big deal when you're dealing with a recording that plays back the exact same way every time, but in a live situation it's going to be tough. Not impossible I'm sure. I have heard of people doing it, but I can't imagine that it was ideal.
It would probably be best to use triggers and a decent drum module instead.
This place is garbage.
Old 01-16-2008
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Triggers would be the key to getting it to trigger well. There will be way too much bleed from the stage coming into the mics to get decent triggering.
It would be easier to get triggers and a drum module that will allow you to load your own sounds. That way you can use the samples from Drumagog that you like.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 01-17-2008
DAS19 DAS19 is offline
Me, You, And Davey Too!
DAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond reputeDAS19 has a reputation beyond repute
It is the cheapest way to go though and I could see why someone would want to try it or use it over buying the triggers and then a module. You might be able to do it effectively. You just have to set up the out of your daw to the house mixer. Its not hard but youll have to fool with it to get them to trigger as you want.
Ps it will probably b e more effective on the kick drum considering all the leakage from amps and other things on the snare mic but theres only one way to find out.
Dave
Old 01-17-2008
Farview's Avatar
Not to mention the fact that everything would be different from show to show. One nasty reflection will ruin your day.
Jay Walsh
Old 01-17-2008
petermiller's Avatar
petermiller petermiller is offline
It is what it is
petermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond reputepetermiller has a reputation beyond repute
I would first off look at the reason you want to trigger in the first place, I mean tuning them and micing them propperly would be the most ideal approach. Secondly how much do you play live because I wouldn't trust the mixed results you would get on a day to day basis and the overall reliability of that approach meaning if you depend on that as your sound what do you have to fall back on? I agree the beat way to do this is get a module and triggers or use the mics as triggers. Its really not that expensive unless you have like a 39 piece drumset or something. I have been triggering drums live scince the 80's using just the mics on stage, you can get accurate triggering if you know what frequencies the drums produce individually and run them through a direct out of the channel on the mixer througha parametric or graphic eq to isolate a triggering frequency unique to each drum, then bring them back on channels seperate from the ones used for the mics and blend them together or use only the triggered sound. And to answer the rebuttles about how to get the snare to trigger accurately well lets just say chances are if you are triggering the snare in the first place you are probably not covering material with a lot of nuance and dynamics in the first place so I wouldnt really worry bout that except no false triggering and that it triggers at the appropriate velocities. Besides Ive never heard any module that can deliver an amazingly accurate press roll anyway.
Peter Miller
Fs: Drumagog Pro Discounted Drummerbones Free Ads for Music / Recording Equipment 5 04-13-2006 11:07
All-ages shows? (specifically Northern NJ) pointfive Marketing Your Music / Publicity 2 02-20-2006 12:16
Drumagog Help ryanformato Drums and Percussion 3 10-20-2005 13:19
Drumagog Freezing Up N-track Drummerbones Digital Recording & Computers 5 07-26-2005 07:38
Drumagog freezing up N-Track Drummerbones Digital Recording & Computers 4 06-20-2005 10:33
